Stuff that breaks after installing a lift
Discussion in 'Suspension' started by ardrummer292, May 19, 2020.
  1. May 19, 2020 at 1:38 PM
    ardrummer292
    ardrummer292 [OP] 500k or bust
    Austin
    Virginia Beach, VA
    2015 DCLB V6 A/T 4x4 1D6
    Overbuilt daily driver
    I'd like to create a thread that lists all the potential issues that arise when installing a lift. I know this is something that weighs heavily on the minds of those of us considering getting such a mod done. Since I have no experience with this topic, I'd like some input from the TW hivemind.
    Here's what I've read.
    - Driveline vibrations: can be corrected with the methodology linked below, plus a carrier bearing drop kit or flip, axle shims, and single-piece driveshaft or two-piece double cardan driveshaft, as appropriate
    https://www.tacomaworld.com/threads...ved-step-by-step.244535/page-49#post-23988923
    - Accelerated driveshaft u-joint wear: likely results from failing to fix driveline vibrations in a timely manner
    - Blown CV axle boots: can be corrected with new high angle inner CV boots from Offroad Solutions or differential drop kit (the latter is not very effective, nor is it recommended)
    - Front differential needle bearing failure: can be corrected with ECGS bushing
    - Alignment issues: can be corrected with new high caster UCAs, usually only a problem for front end lifts over 2.5 inches
    - Blown wheel bearings: not really related to lifts, more to do with large/heavy tires installed on wheels/spacers with a large offset; can be corrected by installing @05Taco4x4 wheel bearings if/when your stock bearings go bad
    https://www.tacomaworld.com/threads/wheel-bearings-hubs-press-service-4x4-prerunner.537080/
    - Seized lower control arms (LCAs): this is a problem that is regularly encountered when trying to install a lift, so not a problem that is caused by a lift; can be corrected with coating LCA hardware with anti-seize (preventive) or installing new LCAs with anti-seize coated hardware (corrective)
    - Blown lower ball joints (LBJs): unclear if LBJ wear is accelerated by lift installation
    - Steering system issues: not really sure about the specifics of this issue, or what lift height makes these problems appear
    - Accelerated tie rod end wear: have only seen this mentioned a couple times, not sure what causes the issue or how to prevent/fix it
    - Brake lines overextended: only an issue with front- or rear-end lifts over 3 inches or with extended travel lift kits, can be corrected with extended brake lines
    - "Taco lean": problem caused by non-driver or passenger side-specific springs, can be corrected with a 1/4 inch spacer on the driver side to level the truck side to side
    - Rough ride/poor ride quality: spacer lifts are notorious for this; caused by limited down-travel, stiff shock valving, or excessively stiff springs; can be corrected with extensive research and proper parts selection
    - Driveline vibrations under acceleration: likely due to axle wrap, which is exacerbated by rear-end lift blocks; can be corrected by using a purpose-built leaf pack to provide rear-end lift instead of lift blocks
    - Sway bar interference: arises when aftermarket front shock/coil assembly is too large in diameter, can be corrected with sway bar relocate kit
    - Front end creaking/groaning noise: likely due to lack of grease on UCA bolt or LCA alignment hardware
    - Vehicle Stability Control (VSC) malfunctions: can cause loss of steering, which is extremely dangerous. Only reported to affect about 1 out of 5 people with lifted trucks. Can be corrected with a zero point VSC calibration.
    https://www.tacomaworld.com/threads/lift-with-vsc-answer.41215/
    - Probably lots of other stuff that I haven't thought about
    If you have clarification to provide on any of the above, or new points of your own, I'd be glad to hear it.
  2. May 23, 2020 at 6:26 PM
    ardrummer292
    Austin
    Virginia Beach, VA
    Bump. I know most of this information is available in other threads, but I think consolidating everything into one would make the process less daunting for the inexperienced. I'm hesitant to put together a guide myself, since I have zero experience with lifted trucks and their issues.
    OilCapital2021 likes this.
  3. May 23, 2020 at 6:28 PM
    Zersko
    Zersko Well-Known Member
    Northeast
    2016 Tacoma SR5
    Thanks
  4. May 24, 2020 at 8:47 PM
    krootz
    krootz Well-Known Member
    Justin
    Broadview Heights, OH
    2017 Tacoma DCSB Off Road
    OME 887, 5100s, Deaver single AAL, Spidertrax, 265/75R16 Duratracs
    Basically, if you plan on lifting your Tacoma...plan on spending just as much time and money on making everything else work correctly afterwards.
    Good info here OP
  5. May 24, 2020 at 8:50 PM
    GMAN62465
    GMAN62465 Well-Known Member
    Gary
    Fairfield County, Connecticut
    2015 White DCSB Off-Road Plus
    Thanks for posting this up.... Great stuff to think about!
  6. May 24, 2020 at 8:52 PM
    ardrummer292
    Austin
    Virginia Beach, VA
    Guys, as much as I’d like to take credit for creating the list of problems in my first post, it’s all just regurgitated information. I don’t have any experience with any of the issues listed. I was hoping to start an informed discussion about the topic with members who have some firsthand knowledge. I figure guys with newly-lifted trucks would be grateful for a one-stop shop for troubleshooting.
    That said, maybe I should just go back in my browser history and post links for each of my bullet points.
    Mike29th and TengoTaco like this.
  7. May 25, 2020 at 9:37 AM
    krootz
    Justin
    So I’ll kick this off. I added 5100/887 OME combo up front and single touted AAL out back. Stock rear shocks, stock UCAs and stock brake line length.
    To date (knock on wood) I’ve had zero issues with the needle bearing vibration up front. I was able to get the truck alignment dialed in and I’m happy to report no other issues popped up after wheeling in some pretty nasty situations.
    I actually expected to have more issues to correct based on what I’ve seen posted throughout TW.
    I must have lucked out and got a truck built on a good day after someone got a raise or something
    :woot:
  8. May 25, 2020 at 9:41 AM
    ardrummer292
    Austin
    Virginia Beach, VA
    @krootz, good stuff! It seems like you never hear about the success stories on here.
  9. May 25, 2020 at 9:42 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Few people are so pleased with their car starting each morning before their morning commute to make a post about it.
    It’s when the car doesn’t start that it’s anything they give notice.
    There’s a reason forums are usually more negatively biased, and it’s because things that work perfectly aren’t much to talk about.
  10. May 25, 2020 at 9:46 AM
    ardrummer292
    Austin
    Virginia Beach, VA
    Ain't that the truth. Reading through the forums, you'd think that altering your truck from factory specs makes things spontaneously combust. For the inexperienced among us (hi, that's me), hearing a few success stories would be welcome to bolster confidence or settle nerves.
    King76 likes this.
  11. May 25, 2020 at 9:55 AM
    Amanhowzit taco
    Amanhowzit taco Well-Known Member
    Adam
    Hawaii
    2017 sr5 4wd Tacoma
    265/75/16 tires only everything else stock.
    I don’t know why anyone would want to spend 2 grand plus on a nice suspension system and then have to worry about the draw backs.
    Thanks for posting this. It seems like it’s a hit or miss with some of these issues. Some people get them some don’t. I currently want to upgrade my suspension not for height but for better weight caring ability. Even that seems like a can full of worms.
  12. May 25, 2020 at 10:48 AM
    ardrummer292
    Austin
    Virginia Beach, VA
    You're spot-on, man. I imagine most of us buy Toyotas for one main reason: they make a drop-dead reliable vehicle, moreso than any other manufacturer. Any mods that reduce reliability negate the reason behind buying a Toyota, and are a colossally stupid idea.
    That said, if there are ways to fix the issues brought on by the mods, then the idea isn't stupid. It just takes a little more legwork to get the desired end result. This thread is that "legwork."
  13. May 25, 2020 at 11:18 AM
    krootz
    Justin
    I agree 100%. Knowing what you are REALLY if for as far as second and third order effects can be the difference. It was for me. I was careful to only mod the things that I needed to get the end result I wanted with (hopefully) minimal side effects.
    except my stereo speaker upgrade. Fuck that noise. Disaster. Bought $500 worth of speakers and wiring and sounds like shit in a paper bag
    :facepalm:
  14. May 26, 2020 at 9:26 AM
    ardrummer292
    Austin
    Virginia Beach, VA
    This. A million times, this. It's damn near impossible to get a feel for probable post-lift issues with the amount of misinformation and crap out there. It's almost enough to make one throw their hands up in the air and buy a single-piece driveshaft, high-angle CV axles, and brand new LCAs right out of the gate.
  15. May 26, 2020 at 9:29 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    This is why I hesitate to add a lift
    but as with any change, you have to accept risk that something else may get messed up. That’s just a fact.
  16. May 26, 2020 at 9:37 AM
    FuzzysTacos
    FuzzysTacos Well-Known Member
    Corey
    Wichita, KS
    Sold: 2017 TRD OR/2012 TRD Sport
    Don't take short cuts and you won't have problems. You also get what you pay for.
    Don't hesitate to do something, just do it right once. As mentioned, most problems are irregular and plenty of us are fine.
    Don't think of a lift "kit" as complete. Do your math and see what applies to you. Angles and geometry are important.
  17. May 26, 2020 at 9:59 AM
    TexasWhiteIce
    Texas
    I think a lot of people can’t accept this “You also get what you pay for”. I see so many post asking what the cheapest route for a lift is.
    Do you really want to place your life in the hands of a cheap lift parts while you’re driving 70mph on the highway?
    Mully and ardrummer292[OP] like this.
  18. May 26, 2020 at 10:15 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Great post OP, there really is alot more to lifting these trucks than just installing a set of coilovers or spacers.
    I did lots of research, listened to those that had experience and knew what they were doing. I took my time and it paid off 100%. I have absolutely no lift issues with my truck. Thanks TW.
  19. May 26, 2020 at 10:45 AM
    ardrummer292
    Austin
    Virginia Beach, VA
    Excellent point. TacomaHolic did a kinda clickbait-y video that covered a similar point. Basically, if your lift kit costs $1500, save up $3000 and get ready to troubleshoot. My baseline Dobinsons lift kit (ordered yesterday) came out to about $1600, and I’ve got another $1800 in preventive measures and expert assistance to go. That isn’t enough to cover all eventualities, so I saved an extra $1500 in case things go totally sideways. None of this is needed for a weekend toy, but it’s essential for a daily driver.
    For people who stumble across this thread in the future, here are the lift components I’m talking about:
    Lift kit and UCAs -
    - Dobinsons C59-350 coils on GS59-220 shocks with one PS59-4030 1/4" spacer, assembled
    - Dobinsons L59-111-R leaf packs with GS59-940 shocks and 1 pair SP59-001 greasable bolts
    - SPC UCAs
    Preventive measures, installed with lift kit -
    - ECGS bushing
    - Off Road Solutions ORS-HB201 high angle CV inner boot
    - SBR-129 sway bar relocate kit
    - OME carrier bearing drop kit
    - Headstrong Offroad 2 degree axle shim kit
    Corrective measures, if needed -
    - OEM LCAs with all new hardware
    - Tom Woods 4x4 single piece driveshaft
    tl;dr I’m not real big on taking risks
  20. May 26, 2020 at 10:50 AM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Nice writeup OP. I would venture to add the implications of increasing tire size, what’s needed to fit them, and to answer all the common questions asked by new members to help them instead of having to search or ask questions asked hundreds of times. This should be a sticky.
    ardrummer292[OP] likes this.
