STUD EXTENDERS
Discussion in 'Suspension' started by Tacorriendo, Aug 10, 2015.
  1. Aug 10, 2015 at 9:30 PM
    Tacorriendo
    Tacorriendo [OP] Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    Hello, does anybody know where can I get stud extenders for the strut bolts?
    I added a 3/4" spacer on the driver side only that I made out of aluminum to give me the right height, but the bolts barely make it thru the top hat and there is not enough tread for the nut. I know daystar level kits come with the extenders I need, but can't see to find a place where I can only purshase three bolt extenders by themselves. I know they sell the extra long studs to replace the fctory ones too, but I do not want to dissasemble the strut if I don't have to. Any help is appreciated!
  2. Aug 10, 2015 at 9:44 PM
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    You could try something like Bolt Supply?
  3. Aug 10, 2015 at 9:58 PM
    Tacorriendo
    Fred
    Texas
    I did, but the 10mm 1.25 pitch seems to be a unicorn no bolt & nut supplier has personally seen. Only heard of it in fables. Standard coupler, bolt or nut tread is usually 10mm 1.50 pitch. That is all you are going to find out there. even thought of buying a Tap and make my own couplers, but is even harder to find the tap with those specs!
  4. Aug 10, 2015 at 10:01 PM
    millertime89
    Erik
    Saskatchewan
    Yes sir
    Shoot, I'm not too sure then... maybe someone else will chime in with their thoughts. Good luck!
  5. Aug 10, 2015 at 10:01 PM
    Tacorriendo
    Fred
    Texas
    Thanks millertime89!
  6. Aug 11, 2015 at 7:13 AM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    those are the 1.5" top plate bolts. They also have 2" extended.
  7. Aug 11, 2015 at 11:45 AM
    Tacorriendo
    Fred
    Texas
    Thanks LTDSC. I had seen those, but that would mean I have to remove the top plate and then replace it which is a PTA. I was trying to avoid that by just cutting the existing bolts half way and put bolt extenders.
  8. Aug 11, 2015 at 11:56 AM
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    good luck with that.
