Stuck Spark Plug
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LeftCali22, Jul 29, 2024.
  1. Jul 29, 2024 at 9:23 PM
    LeftCali22
    LeftCali22 [OP] New Member
    Tom
    Treasure Valley ID
    13 PreRunner TRD Sport DoubleCab 2X
    Hey All,
    New to the forum, between here and Youtube, I was looking to alleviate potential problems with maintaining my vehicles, instead of paying someone else to do the work. Since I’m writing this, you know that might not be the case.
    Basic back ground – I bought the truck from a dealer 4 yrs ago with 90000 miles, it now has 124000, and, by no stretch of the imagination would anyone consider me a grease monkey.
    I decided to replace the plugs, starting on the passenger side rear, and first one was a little stiff, took 3-4 complete rotations before it loosened up. The second one I have about 8 full rotations and it has yet to loosen. I did spray some penetrant around the plug, but that did not seem to help.
    My concern is that it may be damaging the threads and I really do not want to replace the head. The remaining plugs came out similar to the first.
    I was able to fit the coil over the stuck plug and the engine seems to be running fine.
    Any thoughts are appreciated.
  2. Jul 29, 2024 at 9:25 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Is it backing out or just spinning?
    I found having the truck a little warm, not Hot and not Cold helps the spark plugs come out.
    R0dzilla75 likes this.
  3. Jul 30, 2024 at 4:41 AM
    LeftCali22
    Tom
    Treasure Valley ID
    I am assuming that it is spinning.
    I did not think of measuring to see how far it has come up compared to the other plugs.
  4. Jul 30, 2024 at 6:52 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Sounds to me like these are original plugs.
    Use a little more penetrating lube, and keep gently working it back and forth.
    Superdave1.0 and ToyoTaco25 like this.
  5. Jul 30, 2024 at 6:55 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    This right here.
    Also use one of the plugs thats already out to measure how many turns it takes to completely remove or install.
    Its definitely a long thread, but I want to say its 10-12 turns total so you might be close
  6. Jul 30, 2024 at 6:59 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    If its already been cross-threaded, taking it out isnt going to hurt it more. might just be corroded...its a gamble!
  7. Jul 30, 2024 at 7:02 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Anti seize is your friend when you get it out.
  8. Jul 30, 2024 at 8:02 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I had a seized plug in daughter’s 07 Corolla. It turned, maybe, an eight of a turn initially. I sprayed a generous amount of a penetrating spray and let it soak overnight. An old trick on seized bolts is to strike the head repeatedly with a hammer. I placed my plug socket over an old plug to make sure I wouldn't be smashing the plug into pieces, that all the shock went to the threaded part of the plug. It all looked good, and, in the morning, I proceeded with several hammer strikes. Firm strikes, not super hard. It’s the old percussive shock treatment.
    I made some errands, and with the engine at full temperature, I did some more striking and proceeded to attempt removing the plug. I immediately felt it start to unscrew easier and after 2-3 turns, she came out. No doubt I was sweating it the whole time. Hope you get it out also.
  9. Jul 30, 2024 at 9:49 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Second this.
  10. Jul 30, 2024 at 12:28 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    About 16 turns if you go by Denso's picture.
    tacoman45 and b_r_o like this.
  11. Jul 30, 2024 at 12:34 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Absolutely not. In fact, maybe someone has done this in the past and that’s why OP can’t get them to come out easy.
    OP, since your truck is running fine now, just take it to a shop or have someone experienced come and help you.
    Cue the anti seize and torque wrench on spark plugs crowd lmao
    b_r_o and 2024OffRoad like this.
  12. Jul 30, 2024 at 12:41 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Silverado Crew Cab Z71, 5.3 made from real Tornado's!
    A few additions to make me feel cool.
    Are you perhaps confusing Loctite and Anti-seize? As had anti-seize been used previously he would not have this problem now. More than likely they are original plugs. Just remove them, apply a dab of anti-seize and reinstall being carful not to cross thread. I do not recommend running around with one plug backed more than halfway out of the head. Whatever the issue (I doubt you actually have one) stopping halfway is not going to solve it.
    tacoman45 and t0p_d0g like this.
  13. Jul 30, 2024 at 12:44 PM
    2024OffRoad
    2024OffRoad Well-Known Member
    My understanding is plugs with silver coated threads should not have anti seize applied.
    crazy joker likes this.
  14. Jul 30, 2024 at 12:47 PM
    TireFire
    Olympic Peninsula
    Came like cue’d.
    Lmao, no, I did not mean loctite. MAYBE a tiny amount (like nothing thicker than fog on your windshield) will be fine but I’ve seen what combustion heat does to antiseize on spark plug threads.
    There’s no reason to use it either.
    2024OffRoad likes this.
  15. Jul 30, 2024 at 12:53 PM
    JJ Customs
    Jay
    NV
    To each their own I guess. I do recommend using a very little bit, just a dab and only the copper or nickel that is rated for temps in excess of 1800 degrees. On aluminum heads anyway.
    Chuy likes this.
  16. Jul 30, 2024 at 12:57 PM
    JJ Customs
    Jay
    NV
    It is widely accepted to use antisieze on a plug with black threads and that it is not necessary on ones with zinc or similar coatings. At the end of the day it's more of a preference thing. People just like to plant flags on the little shit that does not matter one way or the other on the internet.
    Funny no one is batting an eye at this cat running around with his plug backed out 8 turns though. Those last few threads of that plug hanging on for dear life... LOL... This place is wild sometimes.
    Jakerou, bkhlrTaco's, Jimmyh and 4 others like this.
  17. Jul 30, 2024 at 1:21 PM
    TireFire
    Olympic Peninsula
    Well, that last bit was exactly why I suggested a mechanic or experienced friend…
  18. Jul 30, 2024 at 9:10 PM
    LeftCali22
    Tom
    Treasure Valley ID
    Hello All,
    Thanks for all of the sage advice.
    When I reviewed the thread on my lunch break I was feeling pretty good about my chances of removing the plug without any issues. But…then came the after-lunch crowd, then I started having my doubts again.
    I decided to throw caution to the wind and attempt to remove the plug. Things were not looking promising when I pulled the coil off, as the boot had flared out about a quarter inch.
    I took Chuy’s advice and gave the plug a couple of love taps, then proceeded to back it out. It was still a little stiff to turn but, after about 4-5 complete turns it came loose (Not quite hanging on by a thread JJ, but damn close, I dodged a bullet on that one).
    The plug did not seem to be any worse than the other plugs and there did not appear to be any damage to the head threads. All of the old plugs were Denso K20HR U11. I replaced them with Denso Iridium’s, and I also replaced the coils (Denso). And, as I had already put copper anti-seize on the first 5, before I started this thread, I went ahead and anti-seized the last one.
    Thanks again for the encouragement and entertainment.
    PS - Chuy - I get a chuckle whenever I see your avatar.
    As a native San Diegan I had the opportunity to commute up the 5 to Irvine in the early 90's, so that sign is very familiar. Even more so when one morning, around 5am while cruising along 65-70mph in the fast lane, I got to see that scenario live, when a family came out of the darkness about 75 yards ahead of me trying to get to the center divide. This was long before they installed the fence in the center divide.
  19. Jul 30, 2024 at 9:16 PM
    2024OffRoad
    If you have a v6 iridiums are no bueno
  20. Jul 30, 2024 at 9:23 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Get the engine HOT!
    Then try to remove immediately.
