Stuck rear wheel
Discussion in '1st Gen. Tacomas (1995-2004)' started by Drewboto, Jan 7, 2014.
  1. Jan 7, 2014 at 5:32 PM
    Drewboto
    Drewboto [OP] Well-Known Member
    Drew
    Missouri
    Base model ಠ_à²
    (Former Tacoma owner) 17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    Got an '04 5 lugger with automatic transmission. 87k on odometer.
    Rear driver's side wheel seems seized under certain conditions.
    Story:
    Normally when I let off the brake when given the green light, the truck will idle forward and I ease onto the gas to get up to speed as we all do.
    About a week ago, I would let off the brake (on any flat surface) and the truck would not idle forward. I'd give it up to 5% throttle and then it would start rolling then drive as it always had. Upon rolling to a stop with light brake usage, the truck would kind of lurch to a stop once speed dipped to less than 2 mph.
    A few days go, by then I notice the truck won't idle forward even on a slight decline. It would roll forward in neutral through, and could idle up the slope in reverse. It seems to defy physics somehow. I give it a bit of gas (in forward gear) like I've done in the past. At about 5-10% throttle, something popped and gave way and then truck starting driving as normal until it lurches to stop less than two miles per hour at a stop light. That popping action when taking off was a first.
    Then it snowed and the roads were covered.
    Upon, getting the green light the first morning with snow, The truck does not idle forward as it should. I give it a bit of throttle to break whatever loose so it will drive. On snow, It only causes the passenger side wheel to spin with the driver's side wheel stuck like an anchor. Perhaps the passenger wheel side of things are slicker than the driver's side. I put it in reverse to back up. Truck backs up under idle power without wheelspin or wheel drag. I put it in drive again. Driver's side wheel won't turn the the passenger wheel spins on the snow. Upon being pushed by some kind pedestrians, I was able to get rolling the rest of the way to work.
    For the trip home for work, same thing happened, except, I had to wait for my brother's rig to pull me home with a tow strap. He recalls seeing the driver's side rear wheel locked up when pulling about 15 mph on the snowy road. The drive was only about 3/4 of a mile at most.
    I lifted the rear axle with a jack to lift both rear wheels. After some testing, I've concluded:
    Turn (by hand) the driver's side wheel forward: Passenger wheel turns backward. Good
    Turn (by hand) the driver's side wheel backward: Passenger wheel turns forward. Good
    With truck in neutral:
    both rear wheels will turn freely forward in unison with a second set of helping hands. Good
    Same results when turning backward in neutral. Good
    With the truck running, holding brake, shifting to drive and letting off brake: driver's side does not spin :confused:, but passenger side freely spins. What?
    With truck in drive, apply brake, shift to reverse, let off brake: Both rear wheels spin in reverse. Good
    With the truck in reverse, apply brake, shift to neutral, let off brake: Wheels coast to a stop, then ever so slowly spin forward. About 1 full rotation every 20 seconds. Wheels can be stopped by hand and spun freely forward or back opposedly single handedly or in unison with a second set of helping hands. They go back to a super slow forward rotation after handling them. Completely expected except for the slow forward rotation.
    With truck in neutral/park/reverse (doesn't matter) and applying minimal brake (just enough to let the shifter unlock) and shifting to drive, both rear wheels sometimes spin forward. The passenger wheel will always spin, the driver's side: not always.
    So it appears that by trying to drive forward from a stop (with brake use), that causes the rear wheel to lock up until enough torque is provided to break it loose (then it drives normally until stopped again)
    It also appears if the brake not being applied seems to sometimes prevent the wheel from locking up.
    It's been super cold here in missouri lately. I haven't been offroading as it's just a 5 lugger and it has never done this until this week. It has snowed previously this winter and in seasons past as well.
    I've concluded that it's either something with the differential, bearings, or brake.
    Anyone have any ideas?
  2. Jan 7, 2014 at 5:46 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Pull the brake drum. Sounds like the pad is gone and the shoe is digging into the drum maybe.
  3. Jan 7, 2014 at 5:50 PM
    Xaks
    Xaks Cranky & often armed sysadmin
    Xaks
    Oklahoma City area
    work beast '06 reg cab 4 cyl 5 spd
    Also check the ebrake parts, if they are on that wheel
  4. Jan 7, 2014 at 5:56 PM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    You have a leaking axle seal, and the 90 weight gear oil is on the drum/shoes, and it acting like Elmer's glue. New oil seal needed, either clean the living crap out of shoes, or just put in new ones, they are cheap.
  5. Jan 7, 2014 at 5:58 PM
    Xaks
    Xaks
    Oklahoma City area
  6. Jan 7, 2014 at 9:32 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    Yep, mine did hte exact same thing. Busted rear axle seal/bearing
    Luckily i was heading to the dealership to buy a oil filter, when suddenly my back end started shaking like all kinds of hell.
    1/4 mile away from the dealership.
    I had to get it up to 2500rpm, just to go forward...
  7. Jan 8, 2014 at 5:41 PM
    Drewboto
    Drew
    Missouri
    Base model ಠ_à²
    Thanks guys. I noticed that if I'm only holding the brake just enough to stop and just enough to keep it rolling, usually the brake won't seize up. At least I'm rolling now until it warms up enough to open it up and fix it.
  8. Jan 8, 2014 at 6:35 PM
    Rickalders
    Rickalders Well-Known Member
    For the amount of time it takes to jack up one wheel and remove the drum (15 mins), I wouldn't wait. If you're having brake issues in slick weather, it could ruin your whole day let alone cause more expensive damage. Could be the best 15 mins in the freezing cold you ever spent.
  9. Jan 10, 2014 at 6:45 PM
    b0ules
    b0ules Fresh frame!
    Ottawa, Canada
    Speedway Blue 06 TRD Off-Road
    Leer 100XL Topper OME 885X/Nitrocharger Sport Front Dakar Leafs/Nitrocharger Sport Rear
    Yep, I'm in the same boat. Had a passenger-side seal blow out about 4 years ago. Seals and bearings were replaced but shoes weren't replaced, just cleaned up a little. Was told I was good to go. Well, this winter when the good cold hit, I've now got the glue thing going on.
    It's super awesome. So fun. FML.
    Picked up new shoes and I'm heading out to the garage to replace them as soon as I click submit. Too bad I didn't put the truck in the garage and light the woodstove hours ago, but at least I don't think the freezing rain has started yet.
    Going to degrease the f*ck out of the sticky drum and backer plate then put it all back together. Good times...
  10. Feb 2, 2014 at 7:08 PM
    b0ules
    b0ules Fresh frame!
    Ottawa, Canada
    Mine's fixed now, btw. Degreased the inside of the drum and put new brake shoes in.
  11. Feb 2, 2014 at 8:37 PM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    Possibly you have a brake lining separated from the shoe and it's getting hung up causing your problem. I've seen this happen before.
  12. Feb 3, 2014 at 4:16 AM
    b0ules
    b0ules Fresh frame!
    Ottawa, Canada
    If you're replying to me Pakrat, no, the cause is exactly as I described.
  13. Feb 3, 2014 at 6:16 AM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    What parts are needed for this? Any special tools required? Time requirement? My PS rear is doing this. Started about two weeks ago.
