Stuck oil filter housing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Texas-Gorilla, Feb 22, 2025.
  1. Feb 22, 2025 at 4:21 PM
    Texas-Gorilla
    Texas-Gorilla [OP] Well-Known Member
    Thomas
    2016 Tacoma TRD OR
    Doing an oil change on my new-to-me 2016 TRD Off road today and couldn't get the oil filter housing off. However changed the oil before really put the monkey on the oil drain plug as well, but I was able to remove it.
    I already own two 4Runners and I thought I had the specialty removal tool but I couldn't find it. Of course, I had already drained the oil from the pan so I just left the old filter on there and ordered a new wrench from Amazon.
    I'm assuming it will be fine to just change the filter when the wrench arrives tomorrow. I have enough oil left over since I bought 7 quarts.
    Barsoom likes this.
  2. Feb 22, 2025 at 5:03 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Yes you will be fine . Suggestion
    Go to a Toyota dealer and get yourself a new oil filter housing in case you crack it getting it off. Also get the motive filter wrench.,and put the socket on the big nut, on the wrench . Better leverage. Apply even steady pressure . Some of these oil change dummies put it on way too tight
  3. Feb 22, 2025 at 7:48 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    what the motive wrench?
  4. Feb 22, 2025 at 7:55 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    This one time, I bought the wrong size filter so I put the used filter back on and changed the oil...all went well until the next oil change.
    The MotivX worked well...I bought a different style wrench but was able to remove without any issues.
  5. Feb 22, 2025 at 7:56 PM
    dryheat
    dryheat Well-Known Member
    MotivX or whatever I'm assuming.
    usmc2msu and RIX TUX[QUOTED] like this.
  6. Feb 22, 2025 at 8:18 PM
    TruckGuy63
    Gilbert
    New York
    Yes motiv x I believe it’s called .Try not to use the one that grabs the ears . They have a tendency to break the housing
    kahanabob and Texas-Gorilla[OP] like this.
  7. Feb 22, 2025 at 8:23 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
  8. Feb 23, 2025 at 7:00 AM
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    I have the Motive-X tool, and could not break loose the housing on our RAV4.
    I took it to my regular shop who installed the filter too tight and said "fix it".
    They fired the monkey who tightened it down to Godzilla levels of torque.
    They use the Snap-On heavy duty forged steel tool and a 36-inch half-inch drive breaker bar.
    I could not get it loose with my tools, nor an impact gun.
    This plastic housing is supposed to be torqued to 18 ft-lbs.
    For some reason, rack monkey vastly over tighten these.
    Texas-Gorilla[OP] and TacoTime55 like this.
  9. Feb 23, 2025 at 7:11 AM
    OPTIMUM
    OPTIMUM YotaWerx Authorized Retailer OptimumTuning.com
    Grand Rapids, Michigan
    Have someone tap it while you try to loosen it. This method works with the metal housing version. Not sure how it'll fair with the plastic version.
    Texas-Gorilla[OP] likes this.
  10. Feb 23, 2025 at 8:37 AM
    PoorWhiteBoi
    PoorWhiteBoi Active Member
    2022 SR5
    Had the same problem, went to change the oil myself for the first time and the previous change was done using my last free oil change at the dealer. Broke the plastic housing trying to get it off with a breaker bar and a pipe added for leverage, the nimrod that changed it last tightened it to a million ft lbs for some reason. Went back to the same dealer and raised hell in the service dept in front of customers, holding the broken housing, and got a replacement housing and 2 oil filters for free.
    Kolohe07, IronratPR, eerok and 4 others like this.
  11. Feb 23, 2025 at 8:40 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Since you stated you don't have a tool, did you try to remove by hand?
  12. Feb 23, 2025 at 9:32 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    'who promptly killed himself in the parking lot because all humans are useless piles of excrement.'
    i'm still convinced that thermal expansion over the course of 3k-10k miles tightens up the assembly, not any installation process from anyone. but it is fun to blame others.
    i've done my own oil changes the last two times, being very intentional to install the filter housing by hand(not even 10ft pounds), with new o-rings, and applying oil to o-rings, and every time i've removed it, it's taken a large wrench to remove because it's far tighter than it was installed at.
    Speedbird, Evostaco, TS4x4 and 3 others like this.
  13. Feb 23, 2025 at 9:59 AM
    Texas-Gorilla
    Thomas
    2016 Tacoma TRD OR
    I have other filter tools that worked on my 4Runner but I couldn’t get them to budge the Tacoma filter. There’s no way it’s coming off by hand unless I suddenly turn into Popeye or the Hulk.
    I’ll pick up a new housing from a local dealership this week and take care of it next weekend. I don’t trust the knock off stuff being sold on Amazon or eBay.
    t0p_d0g likes this.
  14. Feb 23, 2025 at 10:10 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
  15. Feb 23, 2025 at 10:32 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
  16. Feb 23, 2025 at 12:05 PM
    Vlady
    Issy, WA
    It is the same. If you cannot get it off using it, none of those fancy ones will help you
  17. Feb 23, 2025 at 1:23 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    When you go to put the new one on a little oil on your finger and rub on the threads and ring.
  18. Feb 23, 2025 at 2:24 PM
    soundman98
    NW Indiana
    it's cheaper, and made of steel. i haven't seen a direct comparison between the two though in terms of fit/finish.
    personally, i went with the entire motivx kit, with the wrench, funnel, and filter drain. the drain comes with a ton of extra silicone hose, that split in half, happens to fit perfectly on the fumoto valve drain hose adapter clips. which means i can literally do my entire oil change in an expensive suit if i wanted. though my investments in oil dry have pretty much tanked. many are pretty pissed at the dramatic drop in their sales..
  19. Feb 23, 2025 at 4:13 PM
    RayInAalaska
    RayInAalaska Well-Known Member
    Alaska's interior (near Fairbanks)
    2023 Tacoma TRD Off Road, sort of green color
    I looked at the two spanner wrenches shown above, and it seems that they don't fit the oil filter housing of the 2023 Tacoma, at least according to the Amazon "proper fit app." I do have a couple of these wrenches (other brands). Two of these fit the Tundra 5.7L but are too large for the 2016 RAV4 V6 engine. The wrench I use for the RAV4 V6 fits the 2012 Corolla 1.8L engine. I am assuming that this one will fit the 2023 Tacoma V6, but I will have to wait until ready to replace the Tacoma's oil & filter by mid April or so, in which case I will first make sure the wrench fits before draining the oil.
    This Tacoma shows a little over 2,000 miles by the odometer, but I had the dealership replace the oil last year before the 2-year Toyota Care expires. Regardless, I will replace the oil and filter myself just like I do with the RAV4 and Tundra, both done by April each year (after the long hours of winter idling).
    By the way, I have replaced the oil and filter of the RAV4 since 2013, and the ones on a 2012 Corolla from 2013 until 2023 when I sold it. I have been replacing the oil & filter of my 2013 Tundra 5.L, so the housing and the housing's drain plug come right off as they should.
    The only times when the filter housings have been over-tightened has been when done at the dealership. In fact, the aluminum plug that is used to drain the filter housing before removing it from the engine, was overtightened at the dealership long ago, and since I didn't want to damage the housing I decided to leave it alone several years ago. I can get it off and replace the O-ring on the next oil change, but that will require a friend of mine to hold the housing while I crank the plug out using a ratchet & 3/8" extension. He's a big guy, so maybe it will work :)
    bgavin likes this.
  20. Feb 23, 2025 at 4:18 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    Biggest pain i have with the cap removal tool is getting it off the filter cover after tightening it. Do they make a removal tool to get the removal tool off! LOL
