Stuck lower ball joint removal
Discussion in '1st Gen. Tacomas (1995-2004)' started by steaktacos, Jul 22, 2016.
  1. Jul 22, 2016 at 8:34 AM
    steaktacos
    steaktacos [OP] Active Member
    1995 Tacoma 2.7 4x4 5spd
    So I'm working on replacing my lower ball joints. I have the 4 bolts that hold it out as well as the 24mm with the cotter pin out.
    Now I'm having trouble getting the lower ball joint to pop out of the lower control arm. I have tried pounding and pounding, also thought I could do it with a pickle fork, but mine wasn't wide enough. Tried some heat with a propane torch for shits and giggles with some more pounding but no luck. I have also tried putting a jack under the stud and applying up ward pressure while pounding but that didn't work and I was at the point where it was raising the truck off the jack stands so I stopped.
    I have one of these on hand because I thought I might need it for the uppers: http://www.autozone.com/loan-a-tool...t-u-joint-press-set/557231_0_0/?checkfit=true
    I wasn't how ever able to rig any thing up with it.
    So any body got any tips for getting a stuck lower ball joint out. I was thinking of trying a bigger pickle fork or maybe some sort of 2-3 arm puller like this:
    http://www.autozone.com/test-scan-a...ller/oem-jaw-puller/246387_0_0/?checkfit=true
    I have a autozone near by to rent from or a harbor freight, I was also wondering if pounding up on the stud is help full, I have mainly been pounding on the sides of the lower control arm as I would like to keep the studs threads intact in case I need to drive to a shop or something, I suppose I could put the castle nut on and pound on that?
    Thanks in advance for any help.
  2. Jul 22, 2016 at 8:37 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    you want these
  3. Jul 22, 2016 at 8:40 AM
    steaktacos
    Cool, Thanks, I'm off to autozone to look for one.
  4. Jul 22, 2016 at 8:44 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    dead blow hammer works well too. just hit the lower control arm with it and it will help to free it up. I use this method for outer tie rods as well.
  5. Jul 22, 2016 at 8:47 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Pitman puller. Works everytime.
  6. Jul 22, 2016 at 8:50 AM
    mhorton1911
    mhorton1911 Fightin' Texas Aggie Class of '19
    Mark
    Fort Worth
    2000 2.7 4x4 manual
    Trail Gear front and rear bumper, 5100's all 4 corners, Eibachs, toytec AAL 1980 Ford pickup horn, and lots of battlescars :)
    Tell me how hard/long it took you and what tools you needed to do the upper ball joint please? Mine needs to be replaced badly (wont even hold a cotter pin) and Im curious if I can do it with the tools I have.
  7. Jul 22, 2016 at 9:35 AM
    steaktacos
    Bennett707 likes this.
  8. Jul 22, 2016 at 9:58 AM
    boostedka
    James
    NM
    For uppers I used one of the autozone rental presses. Took a couple hours at least. Not fun. I think I even broke one of the press sleeves in the process. Good luck with those suckers
  9. Jul 23, 2016 at 9:24 PM
    JTB727
    JTB727 Well-Known Member
    Justin
    AZ
    35's and a Good Time.
    when you go to do the uppers, bolt the bottom back together and out a bottle Jack on your away bar mount that is on the lower control arm. Jack it up into the bottom of the upper control arm. Put some good pressure there and smack that spindle with a heavy hammer. Good solid smack on the side of the spindle. And it'll come right apart. About 5 minutes a side. Takes longer to get the cotter key out.
    boostedka likes this.
  10. Jul 24, 2016 at 8:28 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    This and use an impact. Just buy one, very usefull for all kinds of stuff.
  11. Oct 13, 2016 at 9:58 AM
    2008tacomaYYC
    2008tacomaYYC Member
    Hey steaktacos.....any problems getting the ball joint out of the control arm or did you replace the LCA entirely....i've been putting off installing ball joints on mine.....thanks !
  12. Oct 13, 2016 at 6:04 PM
    steaktacos
    For the lowers I just used a basic pitman arm puller like the one picture in the previous post, worked like a charm. The uppers were a process thought.
    First tried separating the knuckle from the UCA with a pickle fork, and wrecked the bushing and stud and did not mange to separate the ball joint.
    What I ended up doing was getting this puller from auto zone:
    http://www.autozone.com/loan-a-tool...-pitman-arm-puller/695090/?_requestid=6654355
    I then had to use it to separate the UCA from the knuckle, but it wasn't wide enough so I had to get longer bolts to go though it from the hardware store 4'' from 3.5" if I remember correctly. I then set it up with the jaws on either side of the UCA pushing down on the stud. That managed to separate the UCA from the knuckle. (I tried a 3 jaw puller before and wasn't able to get a grip on the UCA with it)
    Once the UCA was separated from the knuckle, I then removed the snap ring from the bottom of the ball joint and prepared to press the ball joint from the knuckle, I put the original bolts back in since the puller was now too wide, and hooked each jaw on the side of the knuckle and pressed down on the stud again.
    To reinstall the ball joint I used a flat bar like this guy did, couldn't fit any sockets in the pitman arm puller so had to use a flat bar:
    http://www.bajataco.com/tech/control_arms_04.html
    All and all it would have been much easier to uses a proper ball joint press with adapters. I just did it using what I could piece together from autozone, without buying extra tools.
    This is a handy video for the uppers:
    https://www.youtube.com/watch?v=p7GRR1PhwV4
