Stuck in trailer mode
Discussion in '4th Gen. Tacomas (2024+)' started by Jrzydvl, Apr 11, 2024.
  1. May 10, 2024 at 11:57 AM
    #101
    CGRudy
    CGRudy New Member
    Silver Tacoma TRD Sport Premium
    Hello everyone. My first post on this forum.
    I joined the trailer problem club last month. Borrowed a friend’s utility trailer (7pin) and my 24 Tacoma TRDsport got stuck in the trailer mode. About two weeks later, I took it to the dealership and they kept it for two days and finally got it unstuck after borrowing a trailer and being on the line with Toyota technical numerous times. The solution was to disconnect the trailer with the truck turned off and then drive the truck above 30 miles an hour for a mile or so. Reportedly it is the Blindspot monitoring system that detects the trailer and has nothing to do with the connector pins.
    But yesterday I towed my kayak trailer (4pin), disconnected it while the truck was turned off, and I am again stuck in trailer mode. Drove it a good 30 miles and turned it on and off half a dozen times. So I am back in the club!
    Note that when it is stuck in trailer mode, you lose your back up sensors and also your lane centering assistance.
    Called my dealership and told them I’ll wait till there’s a fleet wide fix before I bring the Tacoma back in again.
  2. May 10, 2024 at 12:24 PM
    #102
    Jrzydvl
    Jrzydvl [OP] Well-Known Member
    2024 Tacoma SR5
    Try hooking up to a 7pin trailer
    Set up as a new utility trailer and drive it around a couple right and left turns.
    Park it, disconnect it with truck running.
    Go in and tell tow mode that it is disengaged, then return out of tow mode and shut engine off, open and close drivers door, restart and drive away.
    That is what I did the first time this happened and it's been fine since.
    Tdkrum5 likes this.
  3. May 10, 2024 at 12:36 PM
    #103
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Damn, that sucks. See, this is why you don't beta test new generations. Actually this level bug would be an alpha bug in my book. I bet they don't get this fixed before the 2025's roll off the assembly line.
  4. May 10, 2024 at 12:55 PM
    #104
    Jrzydvl
    2024 Tacoma SR5
    I'm looking for a 7pin plug that is a simulator or test plug so I can take it out like I have a trailer. A little work around until they fix it at Toyota.
  5. May 12, 2024 at 5:59 PM
    #105
    dapperdan
    dapperdan Well-Known Member
    Dan
    Wisconsin
    '24 Off Road Underground
    Method 703 W/Mickey Thompson Baja Boss, 1up HD 4 spot bike rack....more to come
    Might have already been covered, but I was stuck in trailer mode as well after bringing mine back from storage over the winter. I simply hooked it back up, drove it part way down my driveway....Truck asked me if I had a trailer, I said nope, confirmed and all is good. Did all this with the 4 prong installed from trailer to truck. Been fine ever since.
  6. May 13, 2024 at 5:47 AM
    #106
    Jrzydvl
    2024 Tacoma SR5
    I think my problem was I answered the yes or no question wrong, could be me but others read the question as I did. Japanese to English thing. Even engineer said it reads a little weird.
  7. May 13, 2024 at 6:14 AM
    #107
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    Maybe if it was worded as a question instead of a statement it would be easier to know which response would satisfy the situation. It looks like a “yes, we have no bananas” kind of thing.
    Toyko Joe likes this.
  8. May 13, 2024 at 7:19 AM
    #108
    mitt22
    mitt22 Well-Known Member
    Interesting even a bike rack can trigger it. Makes me think it is a monitoring thing VS a 4 or 7 pin connector thing.
    SR-71A likes this.
  9. May 13, 2024 at 8:24 AM
    #109
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    That kind of makes sense from a programming and functionality standpoint. Using the camera or sensors (or whatever 4th gens have) instead of using the trailer connector
  10. May 18, 2024 at 2:09 PM
    #110
    Jrzydvl
    2024 Tacoma SR5
    Ok so I was able to fix the original issue by doing what I suggested to the Toy engineer and tech. Plug into and set up a trailer with a 7 pin plug, it worked.
    until you hook up and trailer a 4 pin again, accept this time I answered the deselect question correctly, then shut off and then restarted and drove a mile, shut off and the messege is still there and light is on in right corner again. restarted and drove two more times still there. Arrgghhh!!
  11. May 18, 2024 at 2:11 PM
    #111
    Jrzydvl
    2024 Tacoma SR5
    Oh yeah after I set up trailer and drove with right and left turns when I backed up the brakes slammed on for no reason, as if tow system not on...????
  12. May 18, 2024 at 2:12 PM
    #112
    Korywithak
    Korywithak Well-Known Member
    Central Pa
    2024 TRD Sport Premium in Windchill
    That sucks. I haven’t towed since I got my turned off again. It’s definitely some kinda software glitch.
  13. May 18, 2024 at 4:07 PM
    #113
    Jrzydvl
    2024 Tacoma SR5
    I like the concept but this is starting to suck. I know new model blues.
    Bandit and SR-71A like this.
  14. May 28, 2024 at 3:31 AM
    #114
    McLovin70
    McLovin70 New Member
    Christopher
    2024 Tacoma Underground TRD Sport
    New member here and yup, I just joined this annoying club. I towed a 4 pin utility trailer and now stuck in trailer mode. Any new solutions on this issue?
  15. May 28, 2024 at 11:41 AM
    #115
    Jrzydvl
    2024 Tacoma SR5
    After the instrument cluster asks you if there is no trailer and you say yes, then you must drive vehicle three different times and for at least 5 minutes before the light goes out and all is well.
    Or you can just hook up to a seven-pin trailer. Set it up, drive it around the corner. Make a right and a left turn unplug it disconnect answer. Yes, it's disconnected and then all is well.
  16. May 28, 2024 at 2:21 PM
    #116
    McLovin70
    Christopher
    I never got that message ever, I made an appointment with my dealership, there there's no way that Toyota designed this that way, it's got to be a bug in the system. Technology is supposed to make things idiot proof. So far I'm disappointed with this setup I shouldn't have to go through everything you just did to get a light to clear and my functions back in operation. Thank you very much for the fast response. I'll post back what the dealership tells me.
    TOMRR and Vitamins like this.
  17. May 28, 2024 at 2:26 PM
    #117
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Silverado Crew Cab Z71, 5.3 made from real Tornado's!
    A few additions to make me feel cool.
    What if you were to pickup 2-3 fat people in the first 500 miles? Anything in the manual for that scenario?
  18. Jun 2, 2024 at 7:29 AM
    #118
    Korywithak
    Central Pa
    Just an fyi. I don’t know if it was a fluke or worked how it was supposed to. I bought a 7 pin adaptor for my 4 pin boat trailer. Used it yesterday. Came home last night. And put the boat in the garage. Pulled out the driveway. Drove about 50 yards and it said no trailer was detected. Hit ok. All is right!
    Sagebrush likes this.
  19. Jun 2, 2024 at 5:51 PM
    #119
    Korywithak
    Central Pa
    Ok. Decided to be brave and try it without the 7 pin adaptor. It worked flawlessly. I don’t get it. Then I thought of something else. I didn’t select a trailer from the menu either time. Just hooked it up. Let the truck detect it. Then unhooked when I was done. And the truck detected it wasn’t there. I have no idea if not selecting a trailer with length and all that has anything to do with it. But I thought I would share it.
    TOMRR and Sagebrush like this.
  20. Jun 5, 2024 at 5:16 PM
    #120
    hoffer21
    hoffer21 New Member
    2024 Tacoma Sport w/premium package
    After reading this thread and doing some experimenting I found something that works for me. I have two trailers and a boat and this works for all three.
    When I’m done with the trailer and ready to park I back it up 5 or 6 feet further back then where I want it to be ( I know this won’t work for everyone but I have a fix that works for that too). I use a 7 pin to 4 pin adapter, it doesn’t work on a 4 pin. With truck still running, disconnect the 7 pin adapter, go in and unselect trailer. Drive forward 5 feet or so and when it pops up saying it detects a trailer , select no trailer. For me the trailer mode goes off. Unhook and drive away.
    I can’t do it the same way with the boat because it backs into a shed. I back it all the way to the tire stops, disconnect 7 pin adapter and unselect boat. Drive it straight forward, answer no trailer. At this point, make sure you drove it straight out. Slowly back it straight back. If you turn at all it will slam on the brakes because it detects an object (the boat). Once it’s all the way back again, unhook and drive off.
    This has worked for me about 6 times with different trailers and boat. It’s still a pain to have to go through these steps, but better that being stuck in the trailer mode I was stuck in for several weeks. Hope this works for you.
