Stuck drive shaft yoke
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kidthatsirish, Apr 22, 2023.
  1. Apr 22, 2023 at 8:35 PM
    kidthatsirish
    kidthatsirish [OP] Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    16822209418293962972769427590958.jpg So I finally got around to replacing my carrier bearing for the drive shaft tonight.
    The splined yoke is stuck. I can't remove it and need to in order to get the old bearing off. I've tried tapping it using a wooden block and heavy mallet and it won't budge.
    Any tips would be appreciated.
  2. Apr 22, 2023 at 8:37 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
  3. Apr 22, 2023 at 8:38 PM
    kidthatsirish
  4. Apr 22, 2023 at 8:42 PM
    ZColorado
    13 DCSB OR 6MT
    Get a bigger hammer, maybe some WD40 or PBblaster or something too.
    Superdave1.0 likes this.
  5. Apr 22, 2023 at 8:46 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Did you take the nut off?
    ZColorado likes this.
  6. Apr 22, 2023 at 8:50 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    You can see it in the background. Next to his .40 cal hollow point.
    winkel, TnShooter and ZColorado like this.
  7. Apr 22, 2023 at 8:51 PM
    kidthatsirish
    It is slowly...and I mean very slowly coming apart....I am worried that I will have a challenging time getting it back together at this point.‍♂️
  8. Apr 22, 2023 at 8:52 PM
    kidthatsirish
    LOL!!!!!!
    True! Funny thing is I don't even have a 40! A buddy of mine left that in my truck cupholder on the last range visit.
    How on earth did you realize it was a 40 without seeing the headstamp? You got a nice eye for dimensions and proportions!
  9. Apr 22, 2023 at 8:53 PM
    Superdave1.0
    SoCal
    Them 40's go bang! :quickdraw:
    wilcam47 likes this.
  10. Apr 22, 2023 at 8:55 PM
    Superdave1.0
    SoCal
    Whatever you do try to avoid hitting the splined axle itself. Focus on hitting just the carrier bearing/yoke. My co-worker thought it would be a great idea to put the carrier bearing in a vice, then he AIR hammered the shaft. Well that was a $500+ mistake as the axle was destroyed.
  11. Apr 22, 2023 at 8:56 PM
    kidthatsirish
    Seriously making some kindling...
  12. Apr 22, 2023 at 9:01 PM
    Superdave1.0
    SoCal
    Lucky guess. I've owned a bunch of .40 cal Sig Sauer pistols. Have shot thousands of .40 rounds.
    Bivouac and wilcam47 like this.
  13. Apr 22, 2023 at 9:09 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You’re going to need momentum.
    Something like a slide hammer effect.
    Get creative with it, it will come off.
    Steves104x4 likes this.
  14. Apr 22, 2023 at 9:14 PM
    kidthatsirish
    1682223276470688333509582804073.jpg No for the bearing!.....thanks for the encouragement! Sometimes ya just gotta use the bear paws.....that being said....it's gonna suck putting this thing back together I bet.‍♂️
  15. Apr 22, 2023 at 9:40 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Not sure if there's a master spline or not but if there's not then make sure you line the yokes up so they are phased correctly.
    Steves104x4 and Tbasch like this.
  16. Apr 22, 2023 at 9:52 PM
    Tbasch
    Tbasch Well-Known Member
    Tanner
    Orange County, California/ Forth worth, Texas
    2008 DCSB Tacoma
    edit: nvm I see he has it marked
  17. Apr 23, 2023 at 1:46 AM
    kidthatsirish
    Finally done with that job... hopefully this bearing lasts a lot longer than the last one....I went ahead and replaced all the u joints while I was at it...they turned out to be just fine actually, but I figured if I had off the center I mine as well do all of them. Went ahead and did a fresh grease job on the slip yoke as well.....truck drives so much smoother now!
    Fortunately this time I remembered to set up the u-joints so all the grease points are in line with each other. That way when I grease them when doing oil changes it's much easier.
    And....I managed to figure out the wiring gremlin with the wife's expedition!!!! Winning!
    ....now to start a backyard s'mores fire with all my kindling!:rofl:
  18. Apr 23, 2023 at 6:21 AM
    Madd Matt
    Madd Matt Well-Known Member
    Between the Brandywines S.E. Penna.
    2015 Blue Tacoma TRD Sport 4.0 6 speed manual
    Persistence pays off. Enjoy the s’mores, you deserve them!
    winkel likes this.
  19. Apr 23, 2023 at 8:54 AM
    TacoTuesday1
    FL
    thing I wish I knew when taking mine for a rebuild, that ended up back in stock configuration
    is that apparently if you rebuild it backwards on purpose, with the slip yoke placed to the other side, it's a common mod to:
    1. reduce vibration
    2. gain more clearance in rear
    BigCountry762x39 likes this.
  20. Apr 24, 2023 at 2:33 PM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    get a piece of flat stock throw a bolt though it and a nut on the back side of the bold then put a box wrench on the bolt and tighten from the top. unless you own a bearing puller, I've also used a jaw type puller. ive also used a propane torch to heat up the splined area. can help to cook some of the crap out of the splines. once you put it back together you can smear some anti seize in the splining.
    but if you can spray some penetrant into that area like some PB blaster, or some ATF and acetone mixed together and let it sit. but I've been able to pop mine with a jaw type puller
    get a good wire brush on your splines and you're golden now that you've gotten it free
