Stuck after washing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by danbarone1994, Aug 14, 2020.
  1. Aug 14, 2020 at 9:59 AM
    danbarone1994
    danbarone1994 [OP] Well-Known Member
    Daniel
    2019 Toyota Tacoma Gray TRD OR V6 double cab
    LED headlights, TRD PRO grill, Spacer kit 2 in lift front
    I’ve had this issue 2 or 3 times now I wash the truck and then move it back into the garage and park it. I use the parking brake every time I park. When I go to drive it again sometime the next day sometimes the same day a couple hours later my rear tires are locked up and the truck won’t move. Anyone else have this issue or just my truck the rear shoes may be the issue if it’s just my truck. Everything is original only 4K on the truck.
  2. Aug 14, 2020 at 10:09 AM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Rear brake drums locked up from water. Pretty common. If you're in a colder area grab a mallet and hit it a few times if it doesn't unlock.
    If you take her for a spin after washing it'll work the water out pretty quickly before parking.
  3. Aug 14, 2020 at 10:11 AM
    tacoWithstickyrice
    tacoWithstickyrice Well-Known Member
    '19 DCSB TRD OffRoad 4x4
    I found what works for me is to mess with the parking brake cables. Give the cables a couple tugs and activate the handle a couple times. That usually releases it for me. I have since started driving my truck a couple miles after washing it in the hope that it gets the water out.
    02Duck likes this.
  4. Aug 14, 2020 at 10:13 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    no less they will ice weld in the winter from Low Temps
    ive worked for several 1st response companies
    we never use parking brakes overbite
    actual company policy
    in a garage normal situation i never use my parking brake
    out & about on a grade etc i wouldas necessary
    Taco4XStock likes this.
  5. Aug 14, 2020 at 10:38 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Stop using the parking brake,its for your truck being parked uphill or downhill.
    kahanabob, sbx22, Taco4XStock and 3 others like this.
  6. Aug 14, 2020 at 10:42 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    This^^
  7. Aug 14, 2020 at 10:44 AM
    MOC221_
    Frank
    Well, we don't know if his truck is M/T or not..
    02Duck likes this.
  8. Aug 14, 2020 at 10:44 AM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    I’ve had the same issue. After I found out it most likely happens when rears are wet I adjusted my use of the pbrake accordingly. Never happened again.
  9. Aug 14, 2020 at 10:58 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Where's that guy that just replies "M/T" to nearly every thread?
  10. Aug 14, 2020 at 11:25 AM
    Txexplorer
    Txexplorer Well-Known Member
    Cameron
    Etx
    Bilstein 6112/5160 Icon AAL Level mk6
    Just drive it after washing it...
    GillyLink likes this.
  11. Aug 14, 2020 at 11:34 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    He doesn't need the E brake in his garage .
  12. Aug 14, 2020 at 11:37 AM
    Kairide
    Kairide Well-Known Member
    2020 White SR5
    Just use the search function, this and the "My Rubber Molding Flew Off in the Car Wash" topics have been covered numerous times.
    There are actually numerous articles and blogs about the pros of using a parking brake on automatics routinely. Is it a necessity like a manual, no, but is it a good habit to get in to, yes. Some manufacturers don't even make it optional anymore. All Teslas automatically engage the parking brake when you put the vehicle in to park, there is no separate electronic or manual parking brake.
  13. Aug 14, 2020 at 11:56 AM
    MOC221_
    Frank
    Yes, I know.
    It's a habit, and a good one, if you're driving a M/T though. Muscle memory.
    He need not worry about it, again, if he just drives the truck after washing it.
    It's Friday, so I know where this is headed..
  14. Aug 14, 2020 at 12:53 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I always drive the truck after hand washing it so that I can get all the water and soap out of the wheels and rust doesn’t form on the rotor braking surface.
    Malvolio, turbosnail, Boghog1 and 2 others like this.
  15. Aug 14, 2020 at 1:12 PM
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    I use my parking brake all the time just out of habit as well so that when offroading it's second nature. Don't want your parking pawl to fail and then you watch your truck roll down the side of a mountain.
    whatstcp likes this.
  16. Aug 14, 2020 at 1:17 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Tesla doesn't have a traditional parking pawl like an auto so it needs the brakes to hold it.
    https://leandesign.com/tearing-down...ext=Did you know that the,such as the BMW i3.
  17. Aug 14, 2020 at 1:20 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Never used the E brake on my tundra....when i went to use it, the cable was rusted sold...even the actuator levers on the brake drums that pivot inside were rusted tight. Ask the dealer if the E brake in those new toyota pickups still had issues....of course they said would you expect anything less. After looking how the e brake system is designed its only a matter of time before they do.:frusty:
  18. Aug 14, 2020 at 3:50 PM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    Someone in one of the other threads about this issue had some trick for unsticking it, wherein they pressed the brakes, pulled the lever, released the brakes, and then lowered the parking brake, or maybe a different order, and that freed it multiple times. Strange issue
    As far as rusty ebrake cables, thats more likely to occur on vehicles that almost never see the parking brake engaged. Use it or lose it
    Tullie D and Chew like this.
  19. Aug 14, 2020 at 7:52 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    My wife will pull the damn parking brake like she is trying to stop a freight train. Are you maybe giving it the old steroid jerk?
    brandon78lusch and AKGSD like this.
  20. Aug 14, 2020 at 10:07 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    I've had it stick a few times when it was really cold. I had to jiggle the e-brake cable where it goes into the brake drum. The only time that it got stuck when it was wet, I just went into reverse, then drive a few times and it broke free.
    AKGSD[QUOTED] likes this.
