strut spring compressors
Discussion in 'Suspension' started by CVYota, Oct 15, 2011.
  1. Oct 15, 2011 at 9:54 PM
    CVYota
    CVYota [OP] Damaged goods
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Not sure if I should trust the small spring compressors I could borrow from the local auto store. And the shops all want about $100 to assemble the springs/Struts. Found 2 choices on line (I stay away from Harbor Frieght, it is all cheap Chinese built poor quality). For $129:
    Needs to be mounted on the bench, assemble the spring/shock together then compress.
    Or:
    OTC 6494 Clamshell Strut Spring Compressor
    $154 Portable, well made, but more expensive and best used with an air tool. You can compress the spring, and leave it compressed while you swap out the shock.
    Anyone used these?
  2. Oct 16, 2011 at 8:50 AM
    CVYota
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
  3. Oct 16, 2011 at 8:52 AM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    Haven't used either of those
  4. Oct 16, 2011 at 1:25 PM
    CVYota
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
  5. Oct 16, 2011 at 4:59 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    i trust the auto zone ones. ive used them like 4 times to help people compress their springs and it hasn't exploded on me.
  6. Oct 16, 2011 at 5:03 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    I usually use the kragen/orielly or autozone ones. They work, I haven't been killed or injured, and they loan them for free
  7. Oct 16, 2011 at 5:06 PM
    CVYota
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    I saw they were free, it is a much better deal, OK i will save my money and go with those. TY
  8. Oct 16, 2011 at 5:09 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    I just helped a friend assembling and installing OME shocks with their 556 springs. We used the Oreily compressors and it scared the crap out of us. The bolts were bending really bad. It didn't break, but I wouldn't trust it again. It worked fine for the stock springs though.
  9. Oct 16, 2011 at 5:09 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    I have a clamshell type compressor........doesnt work good at all on the first or second gen springs. I've used the cheap ones from autozone without a problem tho.
  10. Oct 16, 2011 at 9:19 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Ive used the Orielly Strut compressor like 2 times with ease, no problems
  11. Oct 16, 2011 at 9:25 PM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    I just used the Autozone ones for free
