Strut Mount Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jetta.the.hut, Oct 1, 2013.
  1. Oct 1, 2013 at 7:19 PM
    jetta.the.hut
    jetta.the.hut [OP] B4nn3d
    Aren
    Aberdeen,NC
    2013 Access Cab Long Bed 4x4
    So i have all my parts sitting in boxes except the Strut mounts, i want to pull out the old and just throw in the new. I have a guy who can compress the springs and install the mounts for me(OME 885 and Bilsteins) but the ordering the parts is confusing to me.
    I have 2 parts numbers:
    KYB Part # SM5640
    http://www.rockauto.com/getimage/ge...l=http://www.rockauto.com/info/KYB/sm5640.jpg
    and
    MONROE Part # 907921
    http://www.rockauto.com/getimage/ge...ttp://www.rockauto.com/info/Monroe/907921.jpg
    the look simular but are not priced accordingly and theres another Monroe listed for 13 dollars.
    http://www.rockauto.com/getimage/ge...ttp://www.rockauto.com/info/Monroe/907927.jpg
    and toyota only shows the part simular to the KYB mount, which comes with no bolts :(
    So which one?
  2. Oct 1, 2013 at 7:25 PM
    jetta.the.hut
    Aren
    Aberdeen,NC
    these are the struts and springs
  3. Oct 2, 2013 at 9:02 AM
    jetta.the.hut
    Aren
    Aberdeen,NC
    so no ones ordered top strut mounts that can help a brother out???
    I guess I'll order the KYB's tonight and find out for my self.
  4. Oct 2, 2013 at 9:23 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    We have the Top-Plates available. $48.00 Each. You will also need the Coil Isolators they are $11.00 Each.
  5. Oct 2, 2013 at 11:55 AM
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    You most likely won't need to replace the mounts unless they are in really poor condition like very rusty or corroded. you can use the same mounts just replace the rubber bushing # 22 in the Toyota diagram. The mounts in my 2005 TRUCK were still in good condition to use one more interval so I know they should be good in a 2010 Tacoma unless you been driving in salty roads or something. That is the rubber bushing #22 with the red arrow in the picture. just order that at toyomotorparts.com. The second picture is what I and most folks are putting in their tacomas these days, billlies 5100's
    good luck man
  6. Oct 2, 2013 at 12:17 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    just use the ones from the stock struts..
  7. Oct 2, 2013 at 5:49 PM
    jetta.the.hut
    Aren
    Aberdeen,NC
    I'll go check it dan, thanks! You guys at wheelers have been great!
  8. Oct 2, 2013 at 6:01 PM
    jetta.the.hut
    Aren
    Aberdeen,NC
    The main reason was to keep from having to remove,compress,uninstall mounts,compress the new,reinstall mounts,reinstall struts.
  9. Feb 12, 2014 at 2:20 PM
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    subd, using this info so I don't start a new thread
  10. Feb 13, 2014 at 12:24 PM
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
  11. Feb 13, 2014 at 1:11 PM
    jetta.the.hut
    Aren
    Aberdeen,NC
  12. Oct 17, 2016 at 8:15 PM
    300AACTaco
    300AACTaco Well-Known Member
    Alaska
    Black '15 DCSB TRD Off Road 4x4
    ARB Old Man Emu 90000s and 60091s OME 886s, Trim Packer, Icon Tubular Uniball UCAs, CMC, Invisible Sway Bar, Dakar Rear Leaf Packs, Timbren Rear Bumpstops, All Pro U-bolt flip up kit, Method Race Wheels NV 16X8 4.5BS, Cooper ST Maxx LT285/75/16, DEPO Black Tail Lights, Weathertech Floormats, Cascadia Vehicle Tents Mt. Shasta in Earth Tone Green, Custom Green Tree Fabrication Bed Rack, N-Fab Spare Tire Bed Mount
    reviving an old thread, does the KYB kit work? like it has all you need?
  13. Oct 18, 2016 at 2:19 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
