Strut left vs. right
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mastiff37, Jan 9, 2021.
  1. Jan 9, 2021 at 8:12 AM
    Mastiff37
    Mastiff37 [OP] Well-Known Member
    Tucson, AZ
    2011 Regular Cab 4x4
    I'm working on installing these struts from a 2020 on my 2011. I thought red/green is supposed to be driver's side, but the coil spring alignment is backwards that way. My understanding is that the bottom end of the coil spring should be toward the back when installed (my current ones are that way). This can be accomplished by putting the red/green on passenger side. Can anyone say for sure? These came to me assembled.
    asuchemist likes this.
  2. Jan 9, 2021 at 10:23 AM
    Mastiff37
    Tucson, AZ
    Anyone have any advice? I'm at the point of deciding. Here's the old ones and new ones side by side. If I want to coils to line up the same way, the red/green needs to go on passenger side. I have them laid out so the top studs line up and the coils line up. Driver's just removed is far left.
    tacotoe likes this.
  3. Jan 9, 2021 at 11:39 AM
    4ast4orward
    4ast4orward Well-Known Member
    WA
    2014 Tacoma DCSB 4x4
    I installed mine red green on drivers side, they came pre assembled from factory if the bottom end of the coil should be towards the back then i installed mine wrong maybe someone else can chime in but i believe that was the only way too line them up.
    Jeffch and tacotoe like this.
  4. Jan 9, 2021 at 11:58 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  5. Jan 9, 2021 at 12:54 PM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    CamFair87 and tacotoe like this.
  6. Jan 9, 2021 at 12:58 PM
    BlkDakDave
    David
    CC TX
    And watch this video and play close attention to from the 3:00 mark to the 4:10 mark. He pulled the red/green from the PS
    https://youtu.be/XmxhVNabrD0
    CamFair87 and jeminyned like this.
  7. Jan 9, 2021 at 1:12 PM
    TnShooter
    Deogee
    STOCK
    BlkDakDave[QUOTED] likes this.
  8. Jan 9, 2021 at 1:20 PM
    Mastiff37
    Tucson, AZ
    Good deal. I put red/green on passenger side and it worked out. This pic of my install is like the one above, but different colors. Moral: go with coils, not color.
    BlkDakDave likes this.
  9. Jan 9, 2021 at 1:21 PM
    Taco? Who knows
    Taco? Who knows Well-Known Member
    New England
    2009 DCSB Off Road
    Go with the colors.
    Supposedly the spring rates are different. The Red and Green is meant for the DS to correct for Taco lean.
  10. Jan 9, 2021 at 1:25 PM
    TnShooter
    Deogee
    STOCK
    It’ll either have a lean or it’ll have more lean. .....eventually.....
    Throw them on and drive it.
    A year from now you’ll probably know what side whet where.
    3 years from now, you’ll never know.
  11. Jan 9, 2021 at 1:42 PM
    Taco? Who knows
    New England
    2009 DCSB Off Road
    LOL, true.
  12. Oct 28, 2021 at 4:15 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    @4ast4orward
    Any issues with being red/green drivers?
    I just did this with mine also.
  13. Oct 28, 2021 at 4:48 PM
    4ast4orward
    WA
    I had no issues, I even took them off too see if I could orient them to face the end of the spring towards the rear of the vehicle and no cigar. Truck drove fine with them how I had them wich is green/ red on driver with coil end facing the motor.
  14. Oct 28, 2021 at 6:01 PM
    BlkDakDave
    David
    CC TX
    Just following what the service manual states...
  15. Oct 29, 2021 at 10:35 AM
    patchesj
    patchesj Well-Known Member
    Would really like to see installed height measurements both ways. this is definitely to correct taco lean (battery/fuel tank/driver weight distribution).
  16. Sep 22, 2022 at 5:49 PM
    04 xcab
    04 xcab Member
    I thought the spring was supposed to be facing towards the back. Did you have any problems with that?
  17. Sep 22, 2022 at 8:14 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    It is facing towards the back (the lower end of the coil spring that is).
  18. Sep 22, 2022 at 9:46 PM
    04 xcab
    04 xcab Member
    What about passenger side faced towards the back too?
  19. Sep 23, 2022 at 1:13 AM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
  20. Sep 24, 2022 at 10:43 PM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    I can speak from 1st hand experience. This is from purchasing 2 sets of Off Road strut assemblies and rear shocks that were both removed as assemblies. If the coil/strut assemblies are direct take-offs and have not been disassembled then the colors do not mean anything. I bought a 2021 set, with 27k miles, and the color dots were blue/red and green/red. I bought another set, with under 200 miles, and the colors did not match the 2021 set at all. They only mount 1 way. You know from all TW threads that the dots and coil start point on the bottom face the rear of the truck. The installation is based on the top hat stud locations relative to the dots facing the rear. The 2022 set had a brown/white and red/green dot. When I started the install, on the driver side, the studs on top were oriented so the dots would have faced forward thus it was moved to the passenger side. The 2nd strut studs were oriented correctly with dots facing the rear for the driver side. No issues whatsoever. On each side the 2 studs face the wheel and the single stud is facing the engine with the dots facing the rear. I added a driver side 1/4" lean correction spacer. No spacer on the passenger side. After roughly 1 week of driving, and settling, I have gained 1-3/8" lift and there is no lean.
