Stripped U-Bolt Nuts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ZachPrerunner, Dec 6, 2015.
  1. Dec 6, 2015 at 5:30 PM
    ZachPrerunner
    ZachPrerunner [OP] Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Welp, you guessed it. I stripped my U-Bolt nuts while attempting to torque them this weekend. How? By using a twelve-point socket because I didn't have a six-point on hand. Now that my pride is out of the picture, where can I pick up some new nuts to install? I meant to stop by Lowes this evening to see if they carried any, but is this something that has to be ordered online? It's not the factory U-Bolts because the ready lift block kit came with new ones, so I installed them. Any advice is appreciated. :anonymous:
  2. Dec 7, 2015 at 11:13 AM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Lowes and HD didn't carry large enough in metric when I had to try to find temporary nuts for my UCA's when I destroyed the castle nuts doing something retarded. I ended up finding them at a local tractor supply chain called CAL Ranch, until I could get them from a local dealership. Something as simple as the ubolt nuts should be able to be found there.
    ZachPrerunner[OP] likes this.
  3. Dec 7, 2015 at 11:14 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I have my stock U bolts and nuts if you want them.
  4. Dec 7, 2015 at 11:16 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    You could try a smaller Hardware store in your area. I find that they tend to have more of the random pieces like that. But rather than drive around town looking for something so specific, wouldn't it be easier to just order online? Not sure who sells only the nuts without the bolts though.
  5. Dec 7, 2015 at 11:23 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Ace Hardware FTMFW
  6. Dec 7, 2015 at 11:28 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    unless you have a thread guage you will need to remove one of the nuts and bring it into a store with you to find out exactly what size and thread pitch it is or you could just try to call Ready lift and ask them what size it is. Since it is not OE and it is a ready lift U Bolt more than likely it is an SAE size.
    TacoMitch93 likes this.
  7. Dec 7, 2015 at 11:30 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I would just replace the ubolt and nuts completely with new hardware.
    TacoMitch93 and 12TRDTacoma like this.
  8. Dec 7, 2015 at 11:38 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You probably ended up using a socket that was just a bit larger than the nut itself, thought it fit well at the time and proceeded to destroy the nut.
    Well, attempt to find yourself a six point from somewhere, maybe Harbor Freight if they exist where you live? Get the right size and have at it. Hopefully it was just one because then you can negotiate the mounting plate and u bolts off if you get the other three nuts off. If worse comes to worse, bust out the cutoff wheel and enjoy destroying your leaf spring mounting hardware.
  9. Dec 7, 2015 at 11:45 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Local spring shop made a new ubolt with nuts for me. Took <5 minutes and about $10.
  10. Dec 7, 2015 at 11:47 AM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    You can grind down two sides of the nut and use a crescent wrench to undo striped nuts
  11. Dec 7, 2015 at 12:07 PM
    ZachPrerunner
    Southeast TN
    They're relatively new because I had the block kit installed last summer. They replaced the unbolts with it, so I don't think it's wise to purchase a whole new kit.
  12. Dec 7, 2015 at 12:08 PM
    ZachPrerunner
    Southeast TN
    I can still get them off I believe with the right socket. The socket I used was a twelve point 3/4" socket. I need to go get a six point I believe. Thanks for the info though!
  13. Dec 7, 2015 at 12:10 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Yeah if it just the nut, get the nut off and replace. I'd make quite sure it's the right grade and type though. Don't want to put on junk quality hardware. Sometimes this can be difficult to do hence, why I would replace all with known good hardware.
  14. Dec 7, 2015 at 12:11 PM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    You're fired
  15. Dec 7, 2015 at 12:11 PM
    ZachPrerunner
    Southeast TN
    Thank you for the offer. I'm going to see if I can find the nuts at a local hardware store. If I can't find them there, I'll let you know.
  16. Dec 7, 2015 at 12:13 PM
    ZachPrerunner
    Southeast TN
    How do I judge the grade? By feel or certain material?
  17. Dec 7, 2015 at 12:15 PM
    devkurf
    devkurf Member at Large
    midwest
    get the nuts off then take them and the ubolt to a Grainger and they will set you up with what you need
  18. Dec 7, 2015 at 12:18 PM
    ZachPrerunner
    Southeast TN
    Can I still drive the truck with the unbolts off? :D
    On a serious note, I'll look into it.
  19. Dec 7, 2015 at 12:23 PM
    devkurf
    midwest
    My stockers look like grade 8's, with the two slotted dash marks on the far right. They had quite a bit of wear, so some of the markings may have worn off though.
    Crom and ZachPrerunner[OP] like this.
  20. Dec 7, 2015 at 12:45 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    look for ASTM, SAE, and/or ISO industry standard markings...they tell you the grade of material
    no marks, do not touch
    unless you have secondary confirmation it is appropriate
