Stripped transmission drain olug
Discussion in '1st Gen. Tacomas (1995-2004)' started by cr500taco, Aug 6, 2022.
  1. Aug 6, 2022 at 2:20 PM
    cr500taco
    cr500taco [OP] Well-Known Member
    D
    Northridge
    4WD
    The drain plug is stripped on my trans pan.
    First, how do I remove it to drain the fluid? It just spins and doesn't back out or tighten down.
    Second, once I get the plug out, can the hole be retapped for a new plug or do I need to replace the pan?
  2. Aug 6, 2022 at 2:22 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Here for pictures of strippers
  3. Aug 6, 2022 at 2:26 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Tranny strippers
    Nessal and Superdave1.0 like this.
  4. Aug 6, 2022 at 2:27 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    My favorite.
    Nessal likes this.
  5. Aug 6, 2022 at 3:14 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    1. Pry outward on the bolt head with a screwdriver or prybar while loosening the plug with an impact.
    2. There's usually enough material around the hole to drill and tap for a larger size. You can also drill, tap, and helicoil the hole to use a new stock-size plug. Helicoil kits tend to be expensive if you're just doing one though. Cheapest option would be removing a pan from a local salvage yard, if you find a Taco or 4Runner there with the same transmission.
    surfishjoe, lynyrd3, TACOTU3 and 2 others like this.
  6. Aug 6, 2022 at 3:16 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    What can be done depends on what you find once the pan is off.
    Can you weld ??
    I make a piece 3"x3" 1/8" piece ( anything I have that is close in size) install a new drain plug then weld it to the transmission pan.
    There are a few different ways to make or buy a drain plug.
    Works for oil pans as well.
    surfishjoe likes this.
  7. Aug 6, 2022 at 3:26 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    The easiest way IMO is to remove it and tap it for one size larger then buy the correct drain plug.
  8. Aug 6, 2022 at 3:28 PM
    Superdave1.0
    SoCal
    I'd want a new/used pan. Welding in a new drain bung or tapping a larger hole are options. I like to keep things original.
    Area51Runner likes this.
  9. Aug 6, 2022 at 4:09 PM
    cr500taco
    D
    Northridge
    4WD
    Ha, meant to put stripped in the title..
    Superdave1.0 likes this.
  10. Aug 6, 2022 at 4:16 PM
    cr500taco
    D
    Northridge
    4WD
    Does anybody know, what size the original plug is and what's the next size up?
  11. Aug 6, 2022 at 4:33 PM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    Id get a new pan...Or if its not leaking leave it and wonder. What do you guys think about sanding the area, acetone wipe, and epoxy it
  12. Aug 6, 2022 at 4:40 PM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    New pan or if your lucky a donor pan from the junk yard.
  13. Aug 6, 2022 at 5:06 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    There are M12 and M18 plugs according to Rock Auto. Some pans have front and rear plugs? Does the head take a 14mm or 24mm socket? That'll be the quickest way to know. M12 plug usually has a 14mm head. M18 plug usually has a 24mm head.
    If it's a M12 plug, you can drill and tap for M14x1.5, which is a common engine oil pan drain plug thread size for Honda, Mazda, VW, etc.
    treyus30 likes this.
  14. Aug 6, 2022 at 6:40 PM
    cr500taco
    D
    Northridge
    4WD
    I was wondering if a helicoil kit can be used. I think I'm going to do that, so I can use keep the original plug size. It wouldn't hurt to have a kit around for other things, as well. I've bought other size kits in the past and still have them.
  15. Aug 6, 2022 at 6:45 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Still waiting on pics of strippers :evil:
    Bivouac and Superdave1.0 like this.
  16. Aug 6, 2022 at 7:20 PM
    Nessal
    Texas/Bay Area
    Might be too thin to helicoil. It's a stamped steel pan. I can't imagine it being thicker than 1/8" if even that.
    DGXR and Superdave1.0 like this.
  17. Aug 6, 2022 at 8:46 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Honestly your best solution is probably to replace the whole pan and change your filters and clean your magnets while you're at it.
  18. Aug 7, 2022 at 5:50 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I'd drop pan and clean filter......put back together and never touch again...
    I have a $15 hydraulic transfer pump with long straw.....it sucks out whats in the pan...via dip tube...
    and then put 2 qts back in......everyother oil change....takes less then 5 min....
    I end up with a complete tranny fluid change over about 30K.........
    mine's still ruby red......what color is yours........
    The screen filter does nothin, would only catch something if some major component is disintegrating in tranny at which you'd be screwed anyways.....
    If you want to see a nasty screen, go look at an oil pickup tube off some engine that went way past the 4K change mark......
    Complete waste of time changing any more....magnets only thing doing anything. Asian trannys dont fall apart like hydromatic fords and chevys......
    Instead....I use the inline Raybestos mag filter.....swap every 25K.......no more dropping pan....or stripping plugs......
    Complete flush and switched to Maxlife syn ATF 20K ago.....along with new trans cooler hoses thats suppose to be replaced every 4 or 5 yr.....
    Amazon.com: HYDDNice 12V 60W Oil Change Pump Extractor Diesel Extractor Scavenge Suction Transfer Pump for Truck RV Boat ATV : Automotive
    TACOTU3 and Potomus Pete like this.
  19. Aug 8, 2022 at 5:55 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    There's usually a steel donut welded to the inside of the pan, around 1/4" thk, to provide extra meat for the threads.
  20. Aug 8, 2022 at 2:10 PM
    gzig5
    gzig5 Well-Known Member
    Mequon, WI
    2002 Tacoma PreRunner 2WD
    Steel pans are easy to repair via welding once they are off. Aluminum pans can have a custom or commercial thread insert installed. May need to add material via welding to give it something to grip. I make a SS bushing to repair BMW E39 M5 oil pans. It screws in and is secured with a nut on the inside. Common problem on those cars and at $450+ for the pan, this repair makes sense and will never strip out again.
