Stripped the 10mm bolt on the diff
Discussion in '2nd Gen. Tacomas (2005-2015)' started by boxxed, Aug 28, 2021.
  1. Aug 28, 2021 at 6:29 PM
    boxxed
    boxxed [OP] Well-Known Member
    Denver, CO
    09 Off Road
    What the trick to fix the strip of the star bold. Just wondering how to get that bolt out.
    Any ideas?
    Its the lower one.
    Thanks
  2. Aug 28, 2021 at 6:43 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    Welllll it’s an Allen not a star….
    hammer on a torx and see if you can turn it.
    Taco-Grinder and SR-71A like this.
  3. Aug 28, 2021 at 6:51 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    MGMDesertTaco and MikefromCT like this.
  4. Aug 28, 2021 at 6:52 PM
    boxxed
    Denver, CO
    09 Off Road
    i mis-spoke. Thanks. I’ll try that
  5. Aug 28, 2021 at 6:53 PM
    boxxed
    Denver, CO
    09 Off Road
  6. Aug 28, 2021 at 6:55 PM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
  7. Aug 28, 2021 at 6:59 PM
    TnShooter
    Deogee
    STOCK
  8. Aug 28, 2021 at 7:02 PM
    MikefromCT
    CT
    2013 TRD OR DCSB
    SR-71A and TnShooter[QUOTED] like this.
  9. Aug 28, 2021 at 7:03 PM
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    Get some computer dust off, the cans of compressed air. Turn can upside down and blast the liquid on it for a few seconds. Flashes off at about -50F.
    Then give it a little tappy tapp tapp with a hammer, and it should back out with whatever you can hammer in the striped plug.
    https://m.youtube.com/watch?v=rljUld-ptvI
    SR-71A and Key-Rei like this.
  10. Aug 28, 2021 at 7:03 PM
    TnShooter
    Deogee
    STOCK
    No, I would get a new seal washer for it though.
    It’s the big brass looking one if I remember correctly.
    Key-Rei likes this.
  11. Aug 28, 2021 at 7:05 PM
    MikefromCT
    CT
    2013 TRD OR DCSB
    Washers required for diffs and xfer cases.
  12. Aug 28, 2021 at 7:06 PM
    Gutentight
    IL
    ^ Same goes for ECGS bushing, separating suspension ball joints, rusted bolts… it’s great stuff. Basically the reverse of torching things so you don’t F up your truck as easily
  13. Aug 28, 2021 at 8:12 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I've used an air chisel, manual chisel and hammer and I have welded 22mm lug nuts to front Toyota diff drains.
    They kinda suck.
    I got a Lexus 12mm internal and a SnapOn 12mm allen socket and so far that's good, but if it breaks again next time I'll get the gold (phosphate?) lexus one with a 24mm external hex.
    Best thing you can do for these front plugs is put a little heat to them, always replace the crush washer under it, have a spare on hand, and pray you don't need it.
    6 gearT444E likes this.
  14. Aug 28, 2021 at 8:36 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I also only hand tighten them sum guns. I think while I have mine drained I'm going to weld a grade 8 nut to it for good measure. I hate hex fittings in those applications, they also fill with dirt/crud easily and make it difficult to get the allen key seated properly.
    tacotoe likes this.
  15. Aug 30, 2021 at 1:00 PM
    Steamy Longbottom
    Steamy Longbottom Well-Known Member
    1LT Browneye
    East TN
    '21 Army Green TRD O/R 6MT
    Modifications are bad and only bad people modify.
    I have been looking for a flat 10mm Hex socket for the 10mm allen plugs with a flat face, confirmed with the company that this one is completely flat on the end and not rounded like 99% of them. It's also slightly rough around the areas for grip. If you order $25 worth of stuff it's free shipping. This ought to help some people in the future.
    https://www.ebay.com/itm/323103118643?mkpid=0&emsid=e11051.m43.l1123&ch=osgood&euid=a09b050a8bec44df876422dd2c01580d&bu=43538762199&osub=-1%7E1&crd=20210830113027&segname=11051&sojTags=ch%3Dch%2Cbu%3Dbu%2Cosub%3Dosub%2Ccrd%3Dcrd%2Csegname%3Dsegname%2Cchnl%3Dmkcid
    Message,
    "hello,
    yes, the item has the 6 sides and the tip completely flat, as showing in the picture.
    let me know if you have any other questions.
    thank you"
    Key-Rei likes this.
  16. Aug 30, 2021 at 1:09 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Happened to me on my old truck a couple years ago. I ended up taking it to my local garage. They welded a nut onto it, problem solved. Cost me $15
    Steamy Longbottom likes this.
  17. Aug 30, 2021 at 1:12 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I’ve used a chisel to notch the plug and then an air hammer chisel to turn the plug, it’s worked 100% of the time for me
  18. Aug 30, 2021 at 3:11 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
  19. Aug 30, 2021 at 3:34 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    No one has mentioned soaking in PB Blaster or Aero Kroil yet, would be step number one…
    boxxed[OP] and Steamy Longbottom like this.
  20. Aug 30, 2021 at 4:31 PM
    boxxed
    Denver, CO
    09 Off Road
