Stripped Subwoofer Mount Hole in Fiberglass Sub Box?
Discussion in 'Audio & Video' started by rhallmcp, Mar 30, 2019.
  1. Mar 30, 2019 at 2:28 PM
    rhallmcp
    rhallmcp [OP] Well-Known Member
    Upstate NY
    2018 Trd Pro
    i have a fiberglass sub box that has been sounding really bad lately, and sounded like its leaking air. Sure enough, i pulled it out today and the seal isnt great and is leaking. it appears that one of the screws isnt tightening down and the fiberglass is stripped out.
    Any ideas on how to resolve this? im thinking of just packing it with epoxy and drilling it out again?
  2. Mar 30, 2019 at 4:44 PM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    Are you screwed right into the fiberglass? If so maybe consider drilling those holes out & use threaded inserts & machine screws. I've found inserts work best when you use some sort of adhesive to secure them.
  3. Mar 30, 2019 at 6:30 PM
    rhallmcp
    Upstate NY
    2018 Trd Pro
    right after i posted this, i went to lowes and bought some of those threaded sleeves with the teeth on the bottom to stay in place. drilled it out and worked great. now im finding a small leak in the flat part of the box, so im trying to figure out how to seal that next. i seriously shouldnt have to do this with a JL audio stealthbox!!
