Stripped Steering Rack Nut
Discussion in '1st Gen. Tacomas (1995-2004)' started by Skulking, Jan 8, 2023.
  1. Jan 8, 2023 at 10:56 AM
    Skulking
    Skulking [OP] Well-Known Member
    San Jose, CA
    1998 Xtra Cab v6 4x4 Manual
    Yesterday while I was tightening the lower bolt for the U-bracket on the steering rack I was getting close to torque, and then it suddenly got much easier to tighten. I immediately stopped and removed the bolt and when it came out I found the threads from the nut had come out with it. The bolt itself is undamaged, but I now need to deal with figuring out how to repair the threads so I can wrap up my front end work.
    I see three options available and I'd like to know what others may have experience with in a similar situation.
    Option #1 Drill out the remaining threads and then drill out the back side of the cross member and run a longer bolt all the way through with a nut on the far side of the cross member.
    Option #2 Cut open the bottom of the cross member, remove the old welded nut and replace it with a new one.
    Option #3 Use a helicoil kit to drill out and replace the destroyed threads.
    For Option #1, I'm concerned that the required torque for the bolt may deform the cross member without some sort of insert inside the cross member to take the load. For Option #2, I'd probably need to get the truck to a shop since I don't have the tools to do the repair. I like Option #3 the best, but I'm concerned about the helicoil's ability to the take the torque on the steering rack bolt (123 ft-lbs). Does anyone have experience with using a helicoil in a similar high torque capacity? Does anyone have any other suggestions for fixing this?
  2. Jan 8, 2023 at 11:16 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    I had the same thing happen to me. I used a long bolt through the whole crossmember. Maybe not the best solution, but it’s been working for 5 plus years now….
  3. Jan 8, 2023 at 11:19 AM
    Skulking
    San Jose, CA
    Do you remember how much you had to drill out the the cross member? I know there is a hole on the back side that at least seems to partially line up, were you able to use that or did you need to drill a new hole? Did you stick with an M14 bolt? How long was the bolt you ended up using?
  4. Jan 8, 2023 at 11:55 AM
    COMAtized99
    North Carolina
    99 DCLB v8
    Oof…. You are testing my memory now. I want to say I went to Lowe’s and bought a bolt that was the same as what I started with but longer. I don’t remember drilling anything out. If I remember right, the welded nut broke loose. I managed to get the bolt out. I then used a magnetic to wiggle the nut out. I measured the length from underneath and went with it.
    Bivouac and Skulking[QUOTED][OP] like this.
  5. Jan 8, 2023 at 12:01 PM
    Skulking
    San Jose, CA
    I appreciate the information.
    COMAtized99[QUOTED] likes this.
  6. Jan 8, 2023 at 8:10 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Simplest fix would be move up to a barely larger bolt.....maybe even sae...
    tap and use that.....what have u got to lose.....
    1997tacomav6 likes this.
  7. Jan 9, 2023 at 12:19 AM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    There’s a sleeve on the inside of the center bushing, you’ll either have to go to a bolt size that negates the sleeve and goes inside diameter of the bushing or go hunt for a sleeve with the right inner and outer diameter. I’ve got the same issue, I’m planning to cut off the stripped out nut on the crossmember and weld on the correct size nut, not the funnest sounding task
    Bivouac likes this.
  8. Jan 9, 2023 at 7:51 AM
    Skulking
    San Jose, CA
    Based on hole sizing, it looks like I'd need to move up to an M16 in order to have a pilot hole size large enough to remove all of the old threads. It's possible, but it would also require drilling out the hole in the bracket to accommodate the larger bolt and I don't know if I'd be compromising the integrity of the bracket to take the force at that point.
    I think we may be dealing with two separate nuts. The one I stripped is the lower one for the u shaped bracket on the passenger side. It doesn't have a sleeve through the bushing. It sounds like you are dealing with the vertical bolt in the center of the rack? That one does go through the bushing, and you have access to the back side of the nut because it isn't inside the cross member.
  9. Jan 9, 2023 at 9:40 AM
    Laxtoy
    Maltby, WA
    You are correct, I’m talking about the vertical bolt.
  10. Jan 11, 2023 at 9:11 AM
    Skulking
    San Jose, CA
    Bumping this to see if anyone else has any thoughts. Right now my plan is to start with the helicoil and see how that works since doing that first leaves me with both other options still on the table if it doesn't work.
    Andy01DblCabTacoma likes this.
  11. Jan 11, 2023 at 9:59 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Send it on the helicoil. my only 2 cents, get the "real" ones from a good supplier... not the junk crap metal ones from ebay or Amazon.
  12. Jan 11, 2023 at 10:38 AM
    Skulking
    San Jose, CA
    Yeah, I figure if I'm going to do it for something this important I'm going to spend the money on a good setup, so I dropped the money for the kit I linked to in my original post from McMaster-Carr.
  13. Jan 17, 2023 at 10:32 AM
    Skulking
    San Jose, CA
    For whatever it's worth so far, I helicoiled it, and it was fine when torqued to spec. I'll update if I ever have any problems with the repair.
    Bivouac and 3JOH22A like this.
  14. Jan 18, 2023 at 5:44 AM
    1997tacomav6
    Denver
    Because that bolts gets 125lbs torque
    I would go with a new nut rated for that amount of torque
  15. Mar 17, 2023 at 10:22 PM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    I'm gonna revive this one as I've run into the similar situation.
    When I started to tight up the bolts they go loose then start to tighten up again.
    Are the Helicoils still holding up?
    Has anyone cut the bottom or sides to replace the nuts?
    Has anyone remade the bracket with stronger material?
    Thanks for your help.
  16. Mar 18, 2023 at 8:58 AM
    Skulking
    San Jose, CA
    It's holding up fine so far. For what it's worth while working on the repair I realized that I had swapped the vertical center bolt and the horizontal bolt for the bracket. That meant that the bolt in the center vertical spot on the rack was too long and poking through the cross member, and the bolt going through the bracket was shorter than it should have been and couldn't get enough thread engagement which was why it stripped out. I put in the helicoil and corrected that mistake and everything seems okay now.
  17. Mar 20, 2023 at 2:50 AM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    Well I helicoiled it. I got a set form orilles , had to buy the drill bit too. It took me two tries. I was able to torque the bolts down without them pulling out so it's golden for now. But I see a rebuilt mount in my furniture.
    Kevins60 likes this.
  18. Mar 20, 2023 at 8:49 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    https://333fabrications.com/products/hd-billet-rack-clamp
  19. Mar 20, 2023 at 9:15 PM
    1997tacomav6
    Denver
  20. Mar 21, 2023 at 8:29 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Why? You hit the torque spec right? I wouldn't screw with it unless you absolutely had to.
