Stripped oil pan drain plug
Discussion in '2nd Gen. Tacomas (2005-2015)' started by laigepeavitt, Jun 20, 2020.
  1. Jun 20, 2020 at 9:45 AM
    laigepeavitt
    laigepeavitt [OP] Member
    2011 Toyota Tacoma Off Road V6 Double Cab Short Bed
    2011 Tacoma v6 stripped drain plug solutions?!
    The bolt is able to be removed, it just won’t tighten(in one rotation it’ll tighten then loosen, tighten then loosen). What are some solutions for this? If the pan needs replaced, can the skid guard get removed then it can drop down or Ive seen other threads saying you have to move around or remove the differential??
  2. Jun 20, 2020 at 9:47 AM
    hualampeter
    hualampeter Well-Known Member
    Peter
    Chester, MD
    TRD Off Road
    Fox 3" Lift, Total Chaos UCA, and Wheelers Bumps.
    drop the pan use a razor and remove all gasket material. Of course reference guide for tightening. Yes 4 bolts removed skid.
    laigepeavitt[OP] likes this.
  3. Jun 20, 2020 at 9:58 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Buy a fumoto valve, wrap the thread in Teflon tape, install. Should solve it for you as you’ll never need to remove it again.
    DR_CA68, TegoTaco, Blockhead and 6 others like this.
  4. Jun 20, 2020 at 10:04 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    You can also try a spot welded nut on top ?
  5. Jun 20, 2020 at 10:08 AM
    88Taco
    88Taco Well-Known Member
    Michigan
    Black 08 DCSB TRD Off-road.
    Rear diff breather mod. Block heater
    Are the threads on the plug stripped or is it the threads in the pan? If it’s the plug just buy a new plug. If it’s the pan I’m very sorry for your luck. Maybe see if a junk yard has a Tacoma you can pull a pan from.
  6. Jun 20, 2020 at 10:30 AM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    I second this. I did this on my mustang and the pan was fine, it was just the plug that had stripped. Bought a new one and no issue the rest of the time I had the car
  7. Jun 20, 2020 at 10:59 AM
    laigepeavitt
    I’m unable to look at the bolt right now so I should’ve done that! But
    I am able to screw the entire bolt all the way in just fine and remove it just fine, but it's just the final tightening when it feels like it's gonna be tightened all the way but then loosens again, and then i twist some more to tighten it and then when it gets past a point then it loosens again.
    Does that sound like the bolt or the actual pan being stripped?
  8. Jun 20, 2020 at 11:01 AM
    Shellshock
    Iowa
    I’d just take the bolt out and look at it. Should be easy to tell then which it is
  9. Jun 20, 2020 at 11:02 AM
    suaveflooder
    if you are out and about, just grab a new bolt and washer. My guess is that it’s the bolt. Those pans are pretty sturdy
  10. Jun 20, 2020 at 11:06 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Helicoil if it's the pan.
  11. Jun 20, 2020 at 11:09 AM
    Filip38507
    Filip38507 Well-Known Member
    Filip
    Lynnwood Washington
    2019 Tacoma TRD Offroad
    Grab a re threading kit and just rethread it
  12. Jun 20, 2020 at 11:16 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    All these bandaid suggestions seem iffy. If the bandaid fails, there goes your expensive engine.
    If not the plug that is stripped, consider seriously a new oil pan installation.
  13. Jun 20, 2020 at 11:18 AM
    Filip38507
    Filip
    Lynnwood Washington
    Or just save your money buy a $35 rethreading kit from home depot and it will be like new lol
  14. Jun 20, 2020 at 11:19 AM
    Filip38507
    Filip
    Lynnwood Washington
    And if the bolt is stripped just get it replaced they’re cheap
  15. Jun 20, 2020 at 11:52 AM
    Big_Red_Taco
    Big_Red_Taco Well-Known Member
    SoCal
    Rad Red '08 DCSB TRD Off Road
    Mostly stock: AP rear plate bumper, CR D-Lights, 4600s
    I did this about 6 months ago, putting the plug back in after an oil change and stripped it so it wouldn't come out. 2008 truck, probably over 100 rough cycles, that would do it. I thought I was hosed.
    Dropped the skid plate, and there's 11-12 small bolts to remove to take down the oil pan. It's actually the "lower" oil pan subassembly that the bolt screws into. Took that off, and cleaned the surface from old black gasket material. I bought a new pan, plug, and gasket (liquid FIPG I think it's called, comes in a tube - the dealer should know) for ~$125. Resealed and reinstalled in less than an hour. Nothing to it.
    Only hairy part was I got to the parts desk less than 10 minutes before they closed for the weekend. That was close.
    Oh, and take it easy reusing the small bolts - pretty easy to snap.
  16. Jun 20, 2020 at 11:58 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Whatever method you use to repair it just remember that with a new crush washer EVERY change, 25 lbs/ft torque will never leak.
  17. Jun 20, 2020 at 7:41 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Just buy a new pan if the threads on the pan itself are stripped out,its easy too install.
    laigepeavitt[OP] and Muddinfun like this.
  18. Jun 21, 2020 at 4:45 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Let me guess, you had the oil changed at the dealer several times, right?
    I truly believe they either use a impact gun or a breaker bar to reinstall the plug. For some odd reason, they can't get it through their pea-brains that isn't a stressed bolt.
  19. Jun 21, 2020 at 2:24 PM
    laigepeavitt
    Update: the bolt is stripped, I bought a new bolt but it won’t thread in at all. So now I’ve got the old (stripped) bolt on with a new gasket and it tightens pretty snug.
    JimIowa likes this.
  20. Sep 15, 2020 at 4:32 PM
    laigepeavitt
    Final update: had to replace pan costing about $350 for the mechanic to do so. Hope this helps.
