Stripped idler pulley bolt
Discussion in 'Technical Chat' started by cmf21, Dec 26, 2010.
  1. Dec 26, 2010 at 1:03 PM
    cmf21
    cmf21 [OP] Well-Known Member
    Arizona
    04 4x4 dbl cab trd
    Replaced my idle pulley bearing today but when I put the nut back on, I think the bolt stipped and now I can't remove the nut because it just keeps spinning around.
    Is it possible to get a hacksaw or sawzall in there to cut the bolt?
  2. Dec 26, 2010 at 1:21 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    You need to get a grip on it (literally) with vise grips if neccessary either the nut or the bolt & try to loosen with it not spinning around , you may get lucky & re cut the bad threads when backing off the nut/bolt, try this first....:cool:
