Stripped bolt on upper intake manifold
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ToyotaRacingDev, Jul 30, 2021.
  1. Jul 30, 2021 at 7:40 AM
    ToyotaRacingDev
    ToyotaRacingDev [OP] SWO Tacoma Enthusiast
    London, Ontario
    2008 Tacoma TRD Sport
    I have one 8mm allen bolt (rear) that is stripped on my upper intake manifold. Looking for advice getting it out. I'm doing the knock sensor harness replacement. Thanks
  2. Jul 30, 2021 at 7:43 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Geeves77 likes this.
  3. Jul 30, 2021 at 8:04 AM
    ToyotaRacingDev
    London, Ontario
    I don't think I could use that because the outside of the bolt ia round. I don't have access to a welder and I can't really fit a grinder in there. I don't want to pay toyota $1200 to replace the harness
  4. Jul 30, 2021 at 9:05 AM
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    You could probably JB weld an allen socket in there. Those bolts aren't mega tight.
    tacoman45 likes this.
  5. Jul 30, 2021 at 9:30 AM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    You could possibly use a dremel to cut a slot in the bolt head to make it a flathead bolt. I’ve had to do this with stubborn deck screws before haha
    pahaf likes this.
  6. Jul 30, 2021 at 9:32 AM
    mystert
    mystert Well-Known Member
    Eric
    Ventura CA
    2005 Tacoma TRD Sport 4x4 6spd
    I would suggest drilling the head of the bolt off. Then you can lift the intake manifold off you can get vice grips or a bolt extractor on it. If it’s stubborn you can heat it up after the plastic manifold is out of the way. After relieving the tension on the bolt from removing the head, it may come out by hand. After it’s out replace the bolt with a new one for from ace or Toyota. However you end up taking it out, it’s not going to be fun, so get a 6pack to celebrate once you finally do.
    blu92in99 likes this.
  7. Jul 30, 2021 at 9:37 AM
    tirediron
    Those will work on round heads, but looking at it a second time, you may not have the clearance for the wall thickness. The Dremel slot trick may work.
  8. Jul 30, 2021 at 10:00 AM
    mystert
    Eric
    Ventura CA
    If it’s so tight you rounded out the Allen head recess, do you really think a screw driver will get it out? I see broken screwdrivers tips and frustration in your future lol
  9. Jul 30, 2021 at 10:04 AM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
  10. Jul 30, 2021 at 10:23 AM
    tirediron
    I'm not confident that you would get enough of a bite just trying to use the cap socket.
  11. Jul 30, 2021 at 11:30 AM
    tacoman45
    Orygun
    Do you guys use a cutting fluid when you drill out a bolt?
  12. Jul 30, 2021 at 11:42 AM
    mystert
    Eric
    Ventura CA
    Just use some motor oil and you will be fine. Let the drill do the work and don’t push to hard on it, you will work harden the bolt and wear out your drills. Also start with a small drill and slowly increase the size until the head comes off. Spin the drill motor faster when using a small drill. On the Larger drills reduce the speed of the drill motor.
  13. Jul 30, 2021 at 11:53 AM
    tacoman45
    Orygun
    Good info. I’ve only used hand taps and extractors before. I was able to use some old RP Maxfilm as a cutting fluid in those cases but obviously loads were much lower compared to an automatic tool.
  14. Jul 30, 2021 at 12:12 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    If you get some left-handed drill bits, it may break it loose.
    Jimmyh likes this.
  15. Jul 31, 2021 at 1:09 PM
    jorb69
    jorb69 Member
    2007 Toyota Tacoma PreRunner Double Cab Long Bed
    It is corroded at the head. Chances are the threads inside also are--plus factory probably used a loctite-tipped bolt. A dremel cutting tool would fit that tight spot. Just avoid hitting the intake air surge tank. You can lift the intake air surge tank once you cut it. Be very extra careful; that air intake is made of plastic and any accidental trauma to it could give you lean codes. You case is similar to what happened to my 07 Toyota Tacoma 4.0L.
    When my fuel injector number 4 burst due to an out of place o ring, and therefore bled gasoline under the engine, I hurried to remove the air intake hoping I could fire it back quickly. I thought I was loosening the outer intake manifold bolt only to find out that I was actually over tightening it! It snapped at the base of the air intake! Before that, I stripped one of the fuel rail bolts. Ordered a used replacement intake manifold from Ebay and removed the old one with the snapped manifold and fuel rail bolts and replaced it with the used one. Also replaced the intake manifold gaskets. Problem solved. For this model you don't have to drain the coolant as long as the hoses under the throttle body are hooked; it is easy to shove it out of the way. Make it sure you clean the mating surfaces of the intake manifold before installing the replacement gaskets. BTW, since you are already there don't forget to clean the throttle body, air intake and mass air flow sensor; check the PCV valve too since you are removing it anyway. Just doing this will add an extra horsepower you thought your truck never had.
    If budget allows you to replace the entire intake manifold, you can find spares in a junk yard or salvage auto parts. You will possibly damage the threads on the stripped bolt and worse, crack the intake manifold while drilling. It has loctite. If you are manually dexterous and want to repair, take out the whole intake manifold and put it on a work bench/table. That way you eliminate the thought of leaving metal shards to you lower manifold. You can do what the rest here already suggested. Again, no coolant draining involved here unless you are flushing your radiator or removing the hoses under the throttle body.
    I am sharing this based on my experience on my truck, the fix, and the possible options and solutions. I understand every DIYer has a different experience, approach and solutions. Just pick what will work for your truck. Hope this helps.
  16. Jul 31, 2021 at 1:16 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I've found that there's a fine line between pressure and speed, where the drill actually cuts. And slower is usually better than faster.
    Too Stroked and jorb69 like this.
