Stripped Bolt Hole
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BluegrassMedic18, Feb 1, 2022.
  1. Feb 1, 2022 at 7:36 PM
    BluegrassMedic18
    BluegrassMedic18 [OP] New Member
    Alain
    2020 Red Tacoma SR5
    Bullbar with lights, nerf bars, Bed Molle Rail
    While attempting to install a cab rail and Rough Country Molle board, I believe I have stripped the holes to the bolts. Is there a way I can fix this or know if a way so I can continue adding these two things to my truck.
    (Molle board is on, 2 of the bolts are fine, middle and driver side bolt, not so much).
  2. Feb 1, 2022 at 7:38 PM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Pics?
  3. Feb 1, 2022 at 7:38 PM
    BluegrassMedic18
    Alain
    2020 Red Tacoma SR5
    Unfortunately right now it is currently 10:38 at night and picture will be horrible.
  4. Feb 1, 2022 at 7:40 PM
    crashngiggles
    Jared
    Was it an existing hole or one that made for the mounting? Exactly which hole was stripped?
  5. Feb 1, 2022 at 7:42 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    You’ll need to drill and tap it for a larger fastener if it’s truly stripped.
  6. Feb 1, 2022 at 7:50 PM
    BluegrassMedic18
    Alain
    2020 Red Tacoma SR5
    The existing hole is what’s stripped.
  7. Feb 1, 2022 at 7:56 PM
    Murd3rd
    Murd3rd I believe I Toyota harder than most
    Your Mom's House, USA
    00.5 Reg Cab Slammed, Turbo'd/19 TRD OR 6MT S/C
    1st gen - it's got a built engine, a turbo, and waaaaaaay too much to list. 3rd gen - basic-bitch lift, S/C, Pro Wheels
    Heli-coil kits are easy to use and will help you to retain the same bolt size. Also adds strength.
    PhogDog likes this.
