Stripped a T30 bed screw, any advice on which screw extractor & bit size to use?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bondn3, Sep 11, 2021.
  1. Sep 11, 2021 at 5:48 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Can’t you reach under the rear quarters to spray the bolts with penetrating oil. I know I’ve sat under/inside these spots before
  2. Sep 11, 2021 at 5:48 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Those t30 screws are terrible.
    actually all torx screws suck
    KRUD, ndoldman59 and bondn3[OP] like this.
  3. Sep 11, 2021 at 5:51 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    I used to hate torx, that was until I got a decent set of torx bits. Now I use them for everything. Way better than Allen, Flat or Phillips. What I do hate are the inverse torx bolts BMW insist on using, they suck.
    hfjeff, Shellshock and Bleep100 like this.
  4. Sep 11, 2021 at 5:53 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Sounds like a good excuse to buy one to me.
    bondn3[QUOTED][OP] likes this.
  5. Sep 11, 2021 at 5:56 PM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    Maybe hammer in a right-sized flathead screwdriver and turn.
    Silentshredr likes this.
  6. Sep 11, 2021 at 6:06 PM
    nhpoke
    nhpoke Well-Known Member
    jason
    nh
    21 DCLB OR AG
    At least in smallish sizes I still prefer a good Robertson head, but yeah, there's nothing natively wrong with Torx.
    Also... Many things from Japan, that we think are Phillips head screws are not actually Phillips head. They are JIS, which is different. JIS bits fit JIS screws much better than Phillips head bits fit JIS Screws.
  7. Sep 11, 2021 at 6:08 PM
    IndyTac
    IndyTac Well-Known Member
    Indianapolis
    2019 TRD OR DCSB w/JBL
    Total Chaos bed stiffeners CaliRaised bed tie-downs CaliRaised 0-degree, bolt-on rock sliders Meso Customs Gas Hole JDM console and dash organizer Ceramic front tint Ceramic windshield coating Ziebart underbody and rust proofing Taco Garage Dashtop Multi-Mount (DMM) Black SR5 Grille Surround Swap Tacos4cheap Grille Badge Redarc Tow Pro Liberty Brake Controller Car Solutions Anytime Camera Mod TacoMods Radio Knobs Desert Does It Seat Jackers
    How tight is it? Any way to 2-part quick-cure epoxy a sacrificial bit in there, chuck it, and back it out?
  8. Sep 11, 2021 at 6:13 PM
    Laosy
    Laosy Well-Known Member
    CFL
    2017 White DCSB OR
    basic build
    I got a harbor freight set when i stripped mine.
    TacoGeeloor, davidstacoma and nhpoke like this.
  9. Sep 11, 2021 at 6:17 PM
    nhpoke
    jason
    nh
    21 DCLB OR AG
    Left handed drill bits aren't the worst of ideas for screw extraction. You do have to make sure that you can keep the drill perpendicular to the screw, but it is a pretty good tool to have in the box.
  10. Sep 12, 2021 at 3:30 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Pretty simple if you know the bolt thread size diameter. Just use a bit a bit smaller to drill the bolt, and use the biggest extractor to fit the hole. Torx bolts imo are the easiest to extract...you already have a good center spot to begin to drill. Just be sure your bits are harder than the bolt your drilling.
    KRUD, Shellshock and davidstacoma like this.
  11. Sep 12, 2021 at 4:11 PM
    rangers12
    rangers12 Well-Known Member
    West Texas
    I’d use an easy out and replace the screw. Deal with this all the time at my shop.
    KRUD, Bodyguard89, zoo truck and 2 others like this.
  12. Sep 12, 2021 at 4:40 PM
    nhpoke
    jason
    nh
    21 DCLB OR AG
    Yeah. Easy outs, when they work, are great.
    When they don't work, and when they break off are a much bigger problem.
    Rather than drilling steel, now you have to drill carbide.
    Slots, with flat head screwdrivers or cold chisels would come first for me.
    Left handed drill bits would be next.
    Easy outs next.
    If none of that works, I'm going to start trying to figure out how to fixture whatever this is in a mill, or otherwise weld "something" onto the the end of it which I can put more torque on.
  13. Sep 12, 2021 at 4:42 PM
    bondn3
    bondn3 [OP] Well-Known Member
    Southern California
    2021 White TRD OR 4x4
    Thanks everyone! A dremel and a flat did the job.
    wouldn’t be a project if nothing went wrong :bowdown:
    InChrist, Sdtrueblue, MAD777 and 5 others like this.
  14. Sep 12, 2021 at 4:47 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    There is always so much bad advice in threads like this it amazes me. Jb weld? Epoxy? Angle grinder with a cut off wheel? Have some of you ever used a tool before?
    Sharpish, KRUD, Spacecoast and 2 others like this.
  15. Sep 12, 2021 at 4:52 PM
    #35
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Get a square bit, hammer it in there and reverse it out. I did the same thing. Thought it was in reverse but it was in forward and stripped the shit out of it when putting on my bakflip.
  16. Sep 12, 2021 at 5:05 PM
    #36
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    Congrats OP!
  17. Sep 12, 2021 at 5:39 PM
    #37
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I use an angle grinder with a cutting wheel all the time to cut slits in bolt heads…. Apparently you have never used one.
  18. Sep 12, 2021 at 5:50 PM
    #38
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    No. Do woodworking. Torx is a winner.
  19. Sep 12, 2021 at 5:53 PM
    #39
    Wyckedan
    Dan
    Woodinville WA
    You're telling me that you looked at the picture of that small screw in his bed rail, and thought an angle grinder was the right tool for the job?
    Does this look correct to you too?
    Sharpish, KRUD and davidstacoma like this.
  20. Sep 12, 2021 at 5:57 PM
    #40
    Louisd75
    Louisd75 Well-Known Member
    Northwest Washington
    '02 Xtra Cab, '15 DCSB
    You gotta do what you gotta do with what you have :cool: I'm a fan of left hand drill bits with the cordless drill on the hammer drill setting. Sometimes the vibration combined with the drilling is enough. If not, I've had excellent luck with these extractors at work: https://www.amazon.com/Irwin-Tools-...t=&hvlocphy=1027510&hvtargid=pla-385024363678
    KRUD likes this.
