Strange noise, like a can of coins, from engine compartment
Discussion in '1st Gen. Tacomas (1995-2004)' started by dylandercole, Feb 11, 2014.
  1. Feb 11, 2014 at 9:44 AM
    dylandercole
    dylandercole [OP] Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    My 2003 6-speed v6 started to make this noise while on the freeway. At random intervals, about 10-15 minutes apart, I hear a sound that is similar to a can full of coins shaking, or chains rattling, for maybe 2 seconds and then it stops. It sounds like it is coming from the engine compartment. Any help?
  2. Feb 11, 2014 at 9:59 AM
    jspansel
    jspansel Just duct tape it
    Jay
    Central OR
    01 V6 Xtra Cab Tacoma, 5 Speed, 4x4, Lifted
    5100s front at 2.5" with Moog replacement springs, 5100s in rear with 2" Wheeler's AAL
    Does it do it at idle, or while revving while not moving? See if you can get a sound clip/video of it.
  3. Feb 11, 2014 at 10:06 AM
    dylandercole
    Dylan
    So far I've only heard it while driving on the freeway, but it only just started this morning. I'll try to grab a clip after work, but I'm not sure yet how to recreate the noise. On first observation I would say it seems to happen when I let off the gas on the freeway, but not everytime.
  4. Feb 11, 2014 at 10:10 AM
    jspansel
    Jay
    Central OR
    I'd poke around and see if any brackets, etc are loose. Skid plate? Weird..
  5. Feb 11, 2014 at 10:13 AM
    Razgriz
    Razgriz wtf am i reading
    San Jose, CA
    2013 White TRD 4x4
    Is that a brush guard on the front? Maybe that has come loose somewhere.
  6. Feb 11, 2014 at 10:13 AM
    dylandercole
    Dylan
    Will do. I replaced my master and slave cylinder about a month ago and my clutch is starting to slip in 4th and 5th, if that's relevant at all
  7. Feb 11, 2014 at 10:17 AM
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    exhaust shield if its a 2.7
  8. Feb 11, 2014 at 10:25 AM
    dylandercole
    Dylan
    Nope, 3.4
  9. Feb 11, 2014 at 10:29 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Either way slap the edge of them like a tuning fork and see if that's it. My V6 did this and i had to replace a fastener. Mine did it only hitting bumps though.
  10. Feb 11, 2014 at 10:36 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    it's a real high pitched, rapid squeaking? sounds like carrier bearing starting to go bad. letting off the gas is the major clue, at least for me. that was the first symptom for mine.
  11. Feb 11, 2014 at 10:39 AM
    dylandercole
    Dylan
    It's not high pitched at all. It literally sounds like someone shaking a can of coins right in front of the pedals, but clearly outside of the truck. Two shakes of the can and done.
  12. Feb 11, 2014 at 2:18 PM
    dylandercole
    Dylan
    So I didn't hear anything on my commute back from work. On the way there it was cold and there was thick fog, so maybe its temperature/moisture related?
  13. Feb 11, 2014 at 2:27 PM
    Jhodgman
    Jhodgman ...
    Justin
    So Cal
    13 4x4 DCLB tacoma V6 TRD Sport
    5100 Bilstiens set at 1.75, progressive leaf pack, BFGs, All-Pro rear Bumper(white), Storm troopered out
    Cat? Idk if its anything like my 2gen but when the cat went out it sounded like a few coins were rattling around somewhere and it took my some time to identify. Best part is it only happened when the truck was warm (driving for about 20+ minutes).
  14. Feb 11, 2014 at 2:37 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Ditto, here. It might be the cat converter has disintegrated inside. Mine did that years ago, and really scared me. Awful noise. At first, I thought my engine was toast.
  15. Feb 11, 2014 at 2:43 PM
    Jhodgman
    Jhodgman ...
    Justin
    So Cal
    If it inside peices get stuck they can clogg the exhaust and kill you engine. I drove it straight to a shop to get it fixed.
  16. Feb 11, 2014 at 5:04 PM
    dylandercole
    Dylan
    Should I just pop the cat off and take look inside? Between work and school I wont have time to look at it until thursday night, is there significant danger of me causing more harm by driving it ~100 miles more?
  17. Feb 11, 2014 at 6:14 PM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    Could be a rock or something in a skid plate or heat shield, tap on your cat before you take it off. I had this prob on a 87 extra cab it was a exhaust bracket that came loose. I'd get under your truck and start banging on skid plates exhaust ect ect. Hopefully this will help you locate the noise. I totally understand rattles and squeaks suck!!!
  18. Feb 11, 2014 at 6:20 PM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    im thinking carrier bearing. does it do it at highway speed when you let off the gas?
  19. Feb 12, 2014 at 8:02 AM
    tan4x4
    Rick
    Folsom, CA
    If its the cat, you should hear it while parked and revving up a warm motor.
  20. Feb 12, 2014 at 8:43 AM
    Jhodgman
    Jhodgman ...
    Justin
    So Cal
    It just depends on exatly whats wrong with it. if youve heard it for a few days and it still runs i would just try to baby it until I figure it out but i wouldnt stop driving it. I AM NOT SAYING YOU SHOULD DO THIS. im just telling you what i would do. it could be just a rock or one of the other things mentioned above.
