Straightening steering Wheel after Alignment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Monster1, Jun 2, 2013.
  1. Jun 2, 2013 at 8:48 PM
    Monster1
    Monster1 [OP] Well-Known Member
    San Antonio, Texas
    2012 Texas Edition DC Tacoma 4WD
    Weathertech digitals front and rear, TRD exhaust, Coverking dash mat, Oem Tacoma bedmat, Better Built tool box, bed extender, Toytec 1 1/2" AAL, Bilsteins front and rears, fronts set at .85, K&N filter, aluminum skid plate, EGR vent shades, locking tailgate handle, TRD emblems, Cal Trend seat covers front and back.
    I took my 2012 Tacoma DC for an alignment after installing front 5100 Bilsteins and Eibachs, my question is should worry about my steering wheel being off and I'm guessing like about 5 degrees off center to the left? What would Tacoma World forum members do? I could take it back, which is the obvious answer, besides that what? Open to suggestions, thanks for all replies.
  2. Jun 2, 2013 at 8:49 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Yeah I'd just take it back. Or if you're feeling ambitions you could adjust each tie rod by the same amount until the wheel is straight.
  3. Jun 2, 2013 at 8:52 PM
    Bmack04
    Bmack04 Active Member
    Ohio
    04 DC trd 4x4
    deck plate mod, grey wire mod, 5100s front w/OME 881s, 5100s rear w/wheelers 5 leaf, 265/75R16 Firestone Destination A/Ts
    If your steering wheel is not straight while driving straight on a flat road, the alignment was not set properly. Take it back to your shop, if it drives straight just the wheel crooked, it is more than likely that toe is off.
  4. Jun 2, 2013 at 8:56 PM
    Bmack04
    Ohio
    04 DC trd 4x4
    If u dont get it set properly, it will chew up your tires. Dont try to set it yourself, it will just frustrate you and cause u to drink excessively.
    Harry likes this.
  5. Jun 3, 2013 at 5:07 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The toe in maybe correct but the guy that did the alignment was lazy get them to make it right.
  6. Jun 3, 2013 at 6:31 AM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    WWTWFMD
    Nice touch :)
    /spam post
  7. Jun 3, 2013 at 6:38 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    not really related to toe or any other part of alignment
    (if it is, then alignment was really badly done)
    centered wheel is about tie rod ends
    steering wheel being centered is as easy as turning nuts
    on left and right tie rod ends the same direction and same number of threads
    you can make the steering wheel aim anywhere you want and still
    be perfectly aligned...it is all about tie rod 'takeup' as long as you do
    both ends the same number of turns and lock them down afterward
  8. Jun 3, 2013 at 8:37 AM
    Monster1
    San Antonio, Texas
    Does the truck need to be jacked up at the time of tie rod adjustments? Thanks
  9. Jun 3, 2013 at 8:43 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    no, I adjust mine by just crawling under with two large channellocks, pretty easy to dial the steering wheel to perfection...I, too, am a bit anal when it comes to my wheel being straight....
  10. Jun 3, 2013 at 8:44 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    it should be, but not required. try 1/4 turns at first, each side.
    but if you make one mistake and you are a little off on one side, it'll
    need another alignment...so be super careful to be equal turns on both sides
    mark everything before turning you'll be all set
  11. Jun 3, 2013 at 9:19 AM
    Rollntoys
    Rollntoys Member
    Upstate NY
    Tacoma TRD Sport
    Stock
    If you don't know what you're doing I would take it back and tell them center the steering wheel. It's easy to screw everything up with just a turn of the tie rods.
  12. Jun 3, 2013 at 7:47 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Take it back. Mine was off after dealer alignment after spring tsb. I have had this problem several timed and always took it back. Hate a crooked steering wheel.
  13. Jun 3, 2013 at 8:23 PM
    Hot Taco
    Hot Taco Well-Known Member
    Richfield, WI
    2013 Base Regular Cab
    Beefed Taco 3" Lowering Blocks DJM 3" Front Lowering Kit Custom C-Notch Intermittent Wipers LED tail lights
    I used to do alignments with my Dad when he was a mechanic and getting the wheel straight was pretty difficult. I basically had to turn the wheel left, then right, over-and-over until it felt centered. After a road test, if it wasn't centered, we had to get the car on the alignment rack and do it all again... quite the pain in the butt.
  14. Jun 4, 2013 at 4:33 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    This^^ The steering wheel should have been locked on center before the toe was adjusted other wise you'll never get it centered the alignment was done improperly make them fix it you payed for some thing you didn't get.
  15. Jun 4, 2013 at 8:16 AM
    Grieby54
    Grieby54 Horsebit
    Sam
    Castle Rock, CO
    '13 TRD Off Road 4x4 DCSB MGM JBL/Entune/Nav
    WeatherTech Digital Liners, ImMrYo rear view mirror bracket, color matched grille, Tacoma door sill protectors, OEM hood protector, clear bra, tint, OEM roof rack, trimmed front mud flaps to match rear clearance, debadged, color matched grille, Plasti Dipped front Toyota emblem, OME 884X coils with trim packer on driver's side, OME Nitro Sport 9000 shocks, Deaver/ToyTec AAL with OME N182 shocks, 265/75/16 Duratracs, ProComp 7032 16" wheels
    Funny that this thread pops up today. My truck has ALWAY been a bitch to align apparently. The few times that I've had it done it took a handful of tries to get the wheel straight. I'm considering doing the tie rods because it's only just a HAIR off of center to the right.
    So, if my wheel is just a touch off to the right, which way should I be spinning each tie rode?
  16. Jun 4, 2013 at 3:58 PM
    Monster1
    San Antonio, Texas
    What he said ^^^, but mine is a touch to the left.
  17. Jun 5, 2013 at 8:42 PM
    Grieby54
    Grieby54 Horsebit
    Sam
    Castle Rock, CO
    Anybody?
  18. Jun 5, 2013 at 10:14 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Lengthen the drivers side and shorten the passenger side.
  19. Jun 5, 2013 at 10:15 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    That's for a first gen, opposite for a second gen.
  20. Jun 5, 2013 at 10:18 PM
    Agro
    Agro Well-Known Member
    San Diego
    2015 Ford F-150 XLT 3.5L Ecoboost!
    Funny I see this thread. I had my truck aligned and it came in spot perfect. They made tiny adjustments, but its good to go, but the steering is maybe at 1150 on the clock to go straight, i mean sooooooo minor. I took it back and they said it was staight perfect. The thing is, it is not absolutely perfectly straight. If I straighten it just that 5 degrees it will pull right. Otherwise the car is aligned perfectly.
    I installed my front struts and rear shocks, rear airbags, and tons of other stuff, but not sure about steering. i'd need a picture to know which rod it is and yes I could do 1/4 turn on each side and torque it down to whatever spec is needed and see until it corrects it. anyone take pics? got torque spec for the nut?
