Straight Piped Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08tacoma2.7l, Aug 1, 2021.
  1. Aug 1, 2021 at 10:02 PM
    08tacoma2.7l
    08tacoma2.7l [OP] New Member
    2008 Silver 2.7l Tacoma
    So recently my cat went out and i’ve decided to straight pipe my 2008 2.7l Tacoma to gain more outflow/horsepower. I want a deeper tone but not a very loud muffler to go with it. I’ve looked at other threads and saw some some good sounding mufflers but they all had cats on the truck and i’m assuming mine would sound much different. Does anyone have any suggestions?
  2. Aug 1, 2021 at 10:23 PM
    TacoTuesday1
    FL
    typically you would have a cat, muffler, and resonator, all of which offer a bit of damping on their own
    more horsepower?
    I'm sure putting a straight pipe on a 2.7 gives it 1000hp and Ferrari songs
    because cats are required for smog and rotten egg smell when there is no cat
    most people would fix the cat issue
    New4x4 likes this.
  3. Aug 1, 2021 at 10:30 PM
    Bishop84
    Bishop84 Well-Known Member
    All you're gonna get is backfire popping and buzzing. The exhaust on a 2.7 is not causing a restriction.
    SR-71A and Key-Rei like this.
  4. Aug 1, 2021 at 10:46 PM
    Foster1
    Foster1 Well-Known Member
    California
    2023 SR V6 4x4
    Why not delete the cat but keep the stock muffler for now? Might be the sweet spot, getting a different muffler might make it too loud.
  5. Aug 1, 2021 at 10:52 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    A straight piped 4 banger sounds like a cacophony of shotgun shells in a blender and more than likely you will actually loose power, definitely some low end torque will be lost, at most +3hp at the high end.
    Replace your cats, leave the rest alone, if you want a deeper tone get a muffler but they drone is going to drive you insane.
    If you want more power from your exhaust you need an equal length header to replace your cast manifold and even then it makes almost no difference until you go forced induction.
    You have a 2008, you best bet for cheap power is to replace your in tank pump/filter combo with a URD remote filter kit and high flow pump and then have your injectors sent out and cleaned and flow marched by Witchhunter Performance, but again your talking high single digit gains at best.
    tinker_troy likes this.
  6. Aug 1, 2021 at 11:03 PM
    New4x4
    New4x4 Well-Known Member
    AZ
    2017 Tacoma 4x4 TRD Off Road DCSB
    All-Pro Sliders Dirty Deeds Industries Exhaust
    I want Ferrari songs. I guess I'd be better off getting a Ferrari and not a Taco.
  7. Aug 1, 2021 at 11:14 PM
    TacoTuesday1
    FL
    Ferrari engine swap into a Tacoma
    SamFransico13, SR-71A and skeletron like this.
  8. Aug 1, 2021 at 11:20 PM
    Key-Rei
    Key
    Florida
    Not a Tacoma, but, Ferrari into Toyota isn't a first.
    https://youtu.be/obUnEqsTmLg
    As for Ferrari songs, you need a flat plane crank and 8+ cylinders for that or you'll never achieve it.
  9. Aug 1, 2021 at 11:49 PM
    wiggler
    wiggler Well-Known Member
    HILO
    2013 OR AC 6MT & 1998 4Runner sr5 auto
    Just do it. Add a resonator if it’s too loud. Auto or manual?
  10. Aug 2, 2021 at 1:27 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    If my memory serves me right by removing the cat you removed an oxygen sensor so your ECU has no way to regulate the air/fuel mixture and believe it will lean out and engine will run hotter and could blow the head gasket.
  11. Aug 2, 2021 at 1:31 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Maintain a little self dignity and just don't do it.
  12. Aug 2, 2021 at 1:42 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers and a skewp
    Nope, just fix it. No gains to be had on the 2.7
  13. Aug 2, 2021 at 6:36 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Ahhhhh..... the early 70's power adder.......
    Didn't work in the 70's. Don't expect it'll work in the 2020's.
    FWIW, modern engines are tuned with all the intake and exhaust doodads to balance fuel efficiency, EPA regs and power. Whatever you do will likely unbalance the system.
    Do as you wish. Good Luck.
    BTW, don't forget to flip the air cleaner lid......:rofl::rofl::rofl:
    Jimmyh and blu92in99 like this.
  14. Aug 2, 2021 at 6:42 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    You guys need to get on board with the outflow.
  15. Aug 2, 2021 at 7:27 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Mine is straight piped and i added three borla straight thru mufflers to tone it down. Im happy with how it sounds and its not loud by any stretch. If u run any muffler other than stock without cats its gonna be very loud unless you add more mufflers or resonators
