STP intake valve cleaner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dwilliams81, Sep 10, 2022.
  1. Sep 10, 2022 at 11:03 AM
    dwilliams81
    dwilliams81 [OP] Well-Known Member
    2012 2.7L Tacoma 4x4
  2. Sep 10, 2022 at 11:50 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Should be no need to on a port injected engine like the 2.7l and 4.0l as the fuel injectors spray the back of the intake valves and keep them relatively clean.
    Direct injected engines tend to suffer from carbon buildup on the intake valves since there is no fuel spraying on them to keep them clean.
    This is part of the reason Toyota (and some other manufacturers) uses the D4S (port + direct) injection system on direct injected engines, they run in port injection mode under some conditions for better performance and to clean the valves.
    One thing you do want to keep clean on all engines is the throttle body as they all get buildup on them which can cause idle issues and poor driveability at low throttle angles.
  3. Sep 11, 2022 at 7:07 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    When I clean my MAF, I don't disconnect the battery. When I put it back together and start it up, it is easily a1,000, RPM higher than what is a normal idle. Then the RPM starts dropping in increments to a normal idle.
