STOP TRYING TO LOCATE THE DASH RATTLE! (No!!! Not another DASH RATTLE thread!)
Discussion in '1st Gen. Tacomas (1995-2004)' started by jnossoff, Jun 3, 2021.
  1. Jun 3, 2021 at 10:34 PM
    jnossoff
    jnossoff [OP] 2000 Xcab Pre-Runner with Leer 122 shell
    Joel
    Albuquerque NM
    2000 PreRunner SR5 TRD Xcab V6 A/T
    So many threads about the dash rattles! Before you tear things apart try this.
    First, drive with a passenger in the front passenger seat. Ask them if they hear the rattle and if they can identify the general location. Then, ask then to firmly press the palm of their hand against the dash, between the passenger air-bag location and the A/C-Heater vent on the right. Does the rattle stop? GOOD!
    I took my dash rattle (2000 PreRunner ExtraCab V6) to the dealer.
    Technician said, "Yes, there is a Technical Service Bulletin on that. My truck had the dash rattle also."
    He took a length of fuel hose (about 3 feet) and stuffed it down between the dash and the bottom of the windshield, from the right A-pillar to the center.
    RATTLE GONE! 1/2 hour labor charge, no parts charge, minus my Costco Auto 15% discount. I could have done it myself, had I paid attention to some of the other dash rattle posts.
    If this does not work, THEN you can start tearing your dash apart!
    rsimi72, An3, BarryF and 1 other person like this.
  2. Jun 4, 2021 at 4:29 AM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Or wedge a winter hat between dash and windshield. My formerly black one has faded to a light gray over the years
  3. Jun 4, 2021 at 4:34 AM
    tmross
    tmross Well-Known Member
    2002 Tacoma 2.4L 2wd Reg Cab
    Can confirm this works. I had a crazy rattle that sounded like it was coming right out of the center AC vents. Read here about stuffing a peice of cardboard between the windsheild and dash, didn't think it'd work for me but sure enough it did and I haven't heard the slightest rattle from the AC vents since. Gonna replace the cardboard with some hose so it'll look nicer though.
    jnossoff[OP] likes this.
  4. Jun 4, 2021 at 7:05 AM
    warmingupmymind
    warmingupmymind Well-Known Member
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
  5. Jun 4, 2021 at 7:11 AM
    Madjik_Man
    Colorado Front Range
    I have a weird one that sounds like the vent tube is actually disconnected from the passenger side dash vent. But it’s not 100% of the time.
    Also the airbag module is notorious for loosening up and rattling.
    Injust haven’t had the time to remove my glove box and investigate everything.
  6. Jun 4, 2021 at 7:30 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'm just going to go ahead and tear things apart first :burp:
    MalinoisDad and skeezix like this.
  7. Jun 4, 2021 at 9:13 PM
    jnossoff
    Joel
    Albuquerque NM
    You are not paying attention!
    Tacoma's are notorious for inducing auditory hallucinations. You don't need to know where the dash rattle originates, unless this solution does not work.
    Go back and read post #1. Do not pass "Go". Do not collect $200!
  8. Jun 4, 2021 at 11:14 PM
    Madjik_Man
    Easy, Big Fella.
    I’m well aware of the solution of jamming something between the upper dash and windshield.
    I’m just informing people there are other notorious rattles out there that said solution doesn’t fix.
    jnossoff[QUOTED][OP] likes this.
  9. Jun 5, 2021 at 6:12 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    You probably already know this, but your's might be the issue with the foam seal around the joint deteriorating. I know I've got foam blowing out of one of my vents. No rattle yet, but probably only a matter of time.
  10. Jun 5, 2021 at 6:17 AM
    Wsidr1
    Indiana
    As far as the dash x windshield area, there is at least one other thread where people reported putting rubber washers in the gap. Don't remember spacing, but I'd say you could start with every 12" or so and always add more as needed.
    BTW, it's not just Tacomas. My Camry has the same issue from about Nov - Mar when the dash is cold and shrinks just enough to create a gap.
    A lot of good ideas in various threads.
    https://www.tacomaworld.com/search/13929995/?q=dash+rattle&t=post&o=date&c[node]=4
  11. Jun 5, 2021 at 9:41 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    RIGHT ON!!
  12. Jun 5, 2021 at 10:57 AM
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    I keep a roll of TP wedged there. No rattle and a clean ass.
  13. Jun 5, 2021 at 11:37 AM
    tmross
    I stuffed a 2' strip of this stuff in the window/dash gap. No more rattle. Not adhesive so easily removable. $5 at Lowes.
    rsimi72 likes this.
  14. Jun 6, 2021 at 5:07 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Mine is from the airbag on the passenger dash. Idk if I just need to tighten the bolts or pull the airbag and put foam where it meets the dash. I get a “crack” sound when I hit a bump.
  15. Jul 26, 2021 at 6:33 PM
    canonmutant
    canonmutant Well-Known Member
    Kansas
    02 PreRunner TRD
    Hello, so are you folks just stuffing this rubber in that windshield crack from the top?
    I'm changing the ignition cylinder and, while at it, installing a full height HD head with bluetooth and backup camera and . . . I am bound and determined to fix the drone rattle from hell once and for all while I've got it all scattered. Amazing that a horrible rattle won't make a noise for a month, then won't shut up the entire time you're driving it. Mine is dead top center and you can temporarily shut it up by wedging your fingers up top in there. I am considering stuffing a fairly dense chunk of foam in behind from underneath too. Probably will . . . just don't see a way to stuff a long contiguous piece in from under the dash.
  16. Jul 27, 2021 at 7:37 AM
    Brojohanson
    Brojohanson Well-Known Member
    California
    2003 Dbl Cab Supercharged 3.4l 5 speed / 4x4
    :spending:
    Gonna jump on this. Been having rattles and it drives me crazy.
  17. Jul 27, 2021 at 5:40 PM
    canonmutant
    Kansas
    02 PreRunner TRD
    No replies so I just stuffed about 3' of some 5/16 fuel line in the dash/windshield crack from above, 2 pieces of foam wedged in between the defrost vent and the firewall from underneath, and I have that center vent duct wrapped with some left over rubber drawer mat I bought for my toolbox drawers with another wad of foam wedged in behind it. If this thing rattles now . . . I give up!
    The new ignition cylinder was a breeze. Now, on to finishing the new head - backup camera install.
    Likely won't drive it for a couple days unfortunately. But, these stupid drone rattles can disappear on their own for a month so it will likely take some time to know for sure it is fixed.
  18. Aug 2, 2021 at 1:08 PM
    98blackaustintaco
    98blackaustintaco New Member
    Jonathan
    1998 Tacoma SR5
    OME Suspension
    Here’s what I did to solve these damn rattles….For the windshield rattle, followed TW’s advice but cut a 1/4 to 1/2 x roughly the length of the dash, strip from one of those workout pads I had laying around. Every few months you have to push it back down. Grey pad and grey dash makes it mostly invisible.
    For the glove box / passenger side air bag squeaks & rattles, I removed the glove box and every screw I could find. Everywhere it looked like plastic was rubbing and on every screw location, I put 3m anti-squeak tape.
    https://www.amazon.com/0-125-5-5430...-Temperature/dp/B00KCMJTLC?pd_rd_i=B00KCMJTLC
    $15, plus a couple of hours later and no squeaks for two years and counting. Pretty sure another thread posted similar advice.
    Shout out to TW, y’all have always provided such a wonderful resource for wrenching on these beautiful tacos.
    Madjik_Man likes this.
  19. Aug 2, 2021 at 2:04 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Wish I could have told you that beforehand. There's actually 3 problems.
    1. Rattle against windshield
    2. Rattle against defogger vent channel
    3. Rattle due to broken retaining clips
    I'm currently dealing with #3, but its the least annoying thankfully
    Just shoving backer rod between the windshield and the dash will eventually accentuate #2.
    Taking dash off multiple times will cause #3.
  20. Aug 2, 2021 at 2:13 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I've fixed so many dash rattles over the years during my time at Lexus.
