Stop hungry animals from eating wiring and stuff?
Discussion in 'Off-Roading & Trails' started by ke2013taco, May 9, 2021.
  1. May 9, 2021 at 8:26 AM
    ke2013taco
    ke2013taco [OP] Member
    Western New York
    2013 Silver Access Cab SR5 4x4
    My previous tacoma was eaten by animals about 9 years ago. I was parked for 4 days on a seasonal road in allegheny national forest while out backpacking. Upon my return I was greeted with no headlights, no tail /brake lights, many many warning idiot lights, and partially chewed brake lines. I was lucky to make it home. End result - insurance wouldn't cover cost of new harnesses so over 400 splices was the fix, and resulted in me selling the truck before electrical issues began developing.
    Since then, I have made 6 little mesh socks which hold moth balls. I hang them by each tire and put one in engine compartment and one in middle of rear axle. When not in use I just store them in an air tight container. This has seemed to work well. At least my last vehicle wasn't eaten!
    Soy based insulation and seat cushioning have always seemed like a bad idea to me. I know of at least three other vehicles (various brands/models) that have been eaten to some degree. Add in road salt in the winter and it seems like modern cars are becoming more and more like some critter's lunch!!!
    Does anyone else take precautions to prevent this from happening? If so, what are you doing?
    Pickeledpigsfeet likes this.
  2. May 9, 2021 at 8:35 AM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    Other that mice what other animals are you having trouble with?
  3. May 9, 2021 at 9:15 AM
    ke2013taco
    Western New York
    Never really had a problem with mice - it's critters like opossums and porcupines that probably ate my wiring. It only happened to me once but that was enough. Since then I always put mothballs out and haven't had any issues. I think they are attracted to the salt. I do park in out of the way places for days at a time while backpacking. I've also seen vehicles that had wiring harness damage just from sitting in parking lots along the allegheny reservoir. When I was younger (about 30 years ago) people used to dump mothballs out on the ground when parking along the reservoir for this very reason. I just figured why not put them in those mesh sock like bird feeding tubes and keep reusing them. And, I never liked the idea of leaving mothballs behind all over the ground.
    It takes all of about 1 minute to pop open the container they are stored in and hang them... Maybe a minute to unhang them and pack them away. My last batch of mothball socks lasted about 8 years before needing replacement...
    More than likely it was a once in a lifetime experience that happened to me, but it was very costly!!! I'd rather take precautions than have it happen again.
  4. May 9, 2021 at 9:26 AM
    Slick Taco
    Don't have opossums and porcupine issues here because we have dogs but the mice are an issue. Snap traps and peanut butter seems to do the trick but yeah soy based wiring is a dumb choice.
  5. May 10, 2021 at 12:47 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Stop using bacon fat as a dielectric grease. :D
    I dunno, that's pretty weird to have that much damage after only 4 days of being parked.
    You could probably set a trap with much more tasty treats near your truck. Or smear peanut butter on your friend's truck, so they'll go to theirs instead of yours...
  6. May 10, 2021 at 2:17 PM
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    moth balls will keep them away. put a box under your hood or on your front tires
  7. May 10, 2021 at 2:23 PM
    ke2013taco
    Western New York
    Actually pretty normal around here to see opossum, porcupine, and raccoons around nearly every parking area. Too many IDIOTS feeding them and thinking it's cute. They've learned people/cars are a source of food - especially along the allegheny reservoir. Most parking lots also have a big "bearproof" dumpster that attracts animals. My favorite is the people that take a campsite for the day, feed every critter they can see, and then leave at dusk....
    And nowadays, with the great influx of people who never used to go outside (and have no clue), everywhere seems to have a problem with idiots feeding wildlife and/or leaving trash/food behind.... Unfortunately, I think this will be the new normal, at least for a few years....
    Opossums and porcupines are attracted to salt - I blame the salty roads used to get there! It really wasn't that much chewing either. A bite here, a bit there... it adds up quickly! I was unfortunate - they ate both the front and the back. They also could have been attracted by the heat of the engine. Who knows? I'll just do what I can to make sure it doesn't happen again.
  8. May 11, 2021 at 12:30 AM
    Saguarobandit
    Saguarobandit Well-Known Member
    If you go to the Sequoia NP website and search "marmots" you'll get better details.
    I bought a tarp to wrap my Tacoma. I have it ready to go when I go to Sequoia. This is a pic from the SNP website:
  9. May 11, 2021 at 7:17 AM
    ke2013taco
    Western New York
    WOW! That looks like a huge hassle! I'm surprised they don't just chew through the tarp. That must take quite a few minutes to take down/set up. I thought hanging moth ball socks was a pain!
  10. May 11, 2021 at 2:08 PM
    stonylaroux
    stonylaroux Well-Known Member
    Seattle, WA
    2015 Toyota Tacoma TRD Offroad
  11. May 11, 2021 at 2:31 PM
    tacopeter
    tacopeter My truck isn't modded. It's well optioned.
    Peter
    Washington State
    21 DCLB TRD OR
    OEM+
    Had the same problem with my 2021 Jeep Rubicon. All the electrical insulation was being eaten by mice due to being soy based. Used Honda Rodent Tape and no more problems.
    honda rodent tape | eBay
  12. Jun 13, 2021 at 7:04 AM
    jbrandt
    Justin
    Just smear peanut butter on your neighbor's car.:D
    But seriously, I'd just put a few rodent traps near where you park.
    I'd be interested if devices like this actually work. Rats live in NY City, Vegas, everywhere... so it doesn't seam like loud noises and bright lights are a deterrent. If there's food or nesting available, they probably don't much care. According to some of the reviews it seems like it works maybe for a couple days, but they soon become accustomed to the noise and it no longer is a deterrent.
  13. Jun 15, 2021 at 10:12 AM
    gaucotaco
    gaucotaco Member
    I put one of those exact devices under my hood - wood rats didn't mind it at all, they made a nest in cabin air box and started using the fuse box lid as their bathroom (right in front of the "deterrent" device). Don't waste your money. The plastic snap traps work best for me - caught a rat this morning that I thought for a moment was a possum. Tried glue traps as well but the rats we have are strong enough to pull themselves free.
    I am trying to figure out how to put wire mesh over the entry point to the cabin air box, can anyone tell me where the entry is? I am guessing it is underneath the plastic cowling that runs below the windshield? On an older Tacoma I did the trick where you cut open the sheet metal below the windshield and sealed off a cabin air box that way - hoping I don't have to do something so drastic on my '18 o_O
