Stock Skid Plate Bolt Size??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mattylmbr, Oct 15, 2018.
  1. Oct 15, 2018 at 9:32 AM
    mattylmbr
    mattylmbr [OP] Well-Known Member
    2018 Tacoma TRD Sport
    Long story short, jacked up one of my skid plate bolts on my TRD Sport while installing my new suspension..
    Anyone know the size of the skid plate bolts off the top of there head (or otherwise) so I can get the proper bolt to replace it??
    Thanks in advance..
  2. Oct 24, 2018 at 11:25 AM
    Anton338
    Anton338 Ill-Known Member
    Anton
    New Jersey
    2018 TRD Off-Road DCSB
    Mostly electrical shit that nobody cares about.
    Yep. The replacements are M8-1.25x20mm. Make sure you use a large DIN 9021 washer. (Not like in the picture.)
    Four of them hold the front skid plate under the oil filter, sometimes referred to as the "splash guard". The other four hold the back skid plate under the oil pan (only on the TRD Off-Road), that one is called the "under cover". During the last oil change I found that two of the eight were slightly galled, so I replaced them with stainless hardware.
    FYI, the OEM bolts are part number 90080-11373 with captive washers and 12mm hex cap, but Toyota sells them for $5 a bolt which isn't very cash money. Every replacement I've seen only comes with 13mm hex caps which shouldn't be much of a problem. Also, Toyota recommends that they be tightened to 22ft-lb (30Nm) on both plates, but my replacement bolts are A2-70 steel and the recommendation is reduced when lubricated. I snugged em up to 18ft-lb (25Nm). Remember to use anti-seize generously since these are going to be the first few fasteners to rust on the truck.
    ST1, flx, walleye_slayer and 15 others like this.
  3. Apr 1, 2019 at 5:43 PM
    edjukappy
    edjukappy Well-Known Member
    Pennsylvania
    2019 TRD Sport 1k - 2008 SR5 185k - 1998 SR 192k
    Was looking for this info... thanks!
  4. Dec 12, 2019 at 8:10 AM
    Frank319
    Frank319 Well-Known Member
    Monterey County California
    just what I was looking for. Thank you!
  5. Dec 12, 2019 at 9:39 AM
    Carny1
    Carny1 Well-Known Member
    2019 DCSB TRD OR
    Exactly what I'm planning to do as well!
  6. Mar 15, 2020 at 7:18 AM
    terrapin_ld
    terrapin_ld Member
    Lewis
    2004 Tacoma Prerunner TRD Off-Road
    Always love Tacoma world post. Perfect answer to what I needed. Torque specs and all. Thanks. !!
    D.A.S. Taco and Anton338[QUOTED] like this.
  7. Mar 21, 2020 at 11:53 AM
    SamKha
    SamKha Well-Known Member
    I had a bolt break on me. Need to drill it out and re-tap. Any advice on how best to do this?
  8. May 4, 2020 at 3:10 PM
    dta_rattler414
    dta_rattler414 New Member
    2012 Silver TRD Off-Road
    Had 3 of 4 break on me. Was a pain in the ass drilling them out but finally got it done. Started with smaller sized drill bit and gradually increased in size until the broken/rusted bolts came out.
  9. May 28, 2020 at 6:39 AM
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    Anyone have the recommended washer OD or the OEM measurement handy?
  10. May 28, 2020 at 7:38 AM
    Anton338
    Anton
    New Jersey
    Yea man, stock captive washer is a 0.857in OD.
    I replaced them with DIN9021 washers with an 0.927in OD. (About 24mm on an M8)
  11. May 28, 2020 at 7:59 AM
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    Thanks, I'm looking to replace the mismatched set since it came to me with a diff drop, might as well move all of them to one size hex head. Making sure at least the OE washer OD was covered is greatly appreciated!
    Anton338[QUOTED] likes this.
  12. May 28, 2020 at 8:10 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    German-standard metric washers? Really? :p
    Just get 5/16" nominal washers from your hardware store and call it a day. Easier to find them in stainless too.
    D.A.S. Taco likes this.
  13. May 28, 2020 at 8:34 AM
    Greg.Brakes.Tacos
    Greg
    wanna be mods
  14. May 28, 2020 at 9:05 AM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    You're talking the OEM splash guards right? A nice member might send you an OEM bolt. Lots of us have these sitting around after swapping to a true skid plate.
    Vlady, CaptainBart45 and Anton338 like this.
  15. May 29, 2020 at 7:33 PM
    Anton338
    Anton
    New Jersey
    You know the Germans always make good stuff.
  16. May 29, 2020 at 8:07 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I will take one. I figure on putting two together with a layer of kevlar in between. Oh you were talking about a bolt, crap, well it was just an idea. The kevlar wouldn't be of any use but the two "splash pans" might not be a bad idea. hmmm. May have to drill out the upper pan bolt hole to get them bolt up. I bet I could pick up a "splash guard" at low cost. Would two layers of "splash pans" double the strength or would it actually be more than 2X the strength? My beer is empty...
  17. May 30, 2020 at 6:45 PM
    desert.taco
    desert.taco Well-Known Member
    Anyone know the size for the allen bolts for the oil filter? Toyota pretty much stripped all four when I had my two free oil change.
  18. May 31, 2020 at 8:35 AM
    CaptainBart45
    Bart
    Work in progress...
    Not sure what Allen bolts you are talking about on the oil filter?
  19. May 31, 2020 at 9:27 AM
    desert.taco
    Sorry I meant the bolts for the oil filter cover
  20. Jun 4, 2020 at 10:25 AM
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    Buggin112, desert.taco and Anton338 like this.
