Stock Off-road tires for the snow
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BalutTaco, Nov 23, 2019.
  1. Nov 23, 2019 at 7:33 AM
    BalutTaco
    BalutTaco [OP] Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    Will stock tires on Off-road TRD model work fine in the snow? or will I need different tires. I'm not sure if I'm supposed to use snow chains either.
    Thanks
    Hobbs likes this.
  2. Nov 23, 2019 at 7:39 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Are you running the Wrangler Kevlars? They did OK in the snow for me. Not great, but OK.
    Are you in Death Valley??
    BalutTaco[QUOTED][OP] likes this.
  3. Nov 23, 2019 at 7:41 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    There really is no yes or no to tires and snow.
    It’s all compromises and probabilities.
    Your stock tires will certainly get you to work and back on plowed roads. Tons of little corollas and civics make it around on summer tires every winter.
    However, if you don’t want to be skating and sliding around oh so delicately..
    Your first option is a three peak mountain snowflake symbol tire such as the Falken Wildpeaks. Can drive on them year around with better snow traction.
    Even better snow traction would be dedicated winter tires. This will be the biggest jump in traction by far. However the downside is having to change tires twice a year and store a second set.
    Chains are not for daily driving on paved roads. Good to have in your truck if you get stuck for sure, but only for bad ice/snow.
    Each step up in better tires has a trade off in costs and convenience. There is no right answer for everyone. Gotta find the set that fits your scenario.
    TL;DR: If you want a little better traction you can get new tires. If you’re just driving on paved roads to work and don’t want to spend the money just drive on the tires you have until they wear out and upgrade then.
    BalutTaco[OP] likes this.
  4. Nov 23, 2019 at 7:42 AM
    BalutTaco
    Sadly, My Death Valley trip got cancel.. again.. :censored: I am still running the Wrangler Kevlars. I'm planning a short trip to Yosemite on Thanksgiving weekend. Its going to be a snow shower! Will be my first time driving in the snow!!!
    Hobbs[QUOTED] likes this.
  5. Nov 23, 2019 at 7:43 AM
    Mtn Mike
    Mtn Mike Well-Known Member
    Spokane, WA
    2017 TRD OR AC
    Yep, the Wranglers do fine. Not the best but you can survive the winter with them. Generally you wont need chains for on-road/highway driving. I've only needed my chains for off road in 10+ inches untouched snow but your results will vary.
  6. Nov 23, 2019 at 7:44 AM
    BalutTaco
    Maybe i'll pick a close dispersed campsite to the main road....
  7. Nov 23, 2019 at 7:45 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Oh you’re in Cali ha. Just drive what you have. No sense in buying brand new tires for one trip a year into some light fluff.
    If the mountains are icy stay off until they thaw I guess ha. But a little snow on the ground is not the same as a snow-packed frozen winter road. You’ll be fine.
  8. Nov 23, 2019 at 7:47 AM
    BalutTaco
    Yes i'm from Cali lol. I don't have any experience with snow.
  9. Nov 23, 2019 at 7:52 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    With common sense most any tire is a lot better in snow than a lot of guys think.
    My owners manual says no chains. There is very limited clearance between tires and suspension components and sheet metal. I've found that most cables fit and do pretty decently in light snow and ice. Around here we don't get deep snow often, but we do get lighter snow with lots of icy patches. Cables actually work better for what I need most of the time.
    For heavier snow or off road use they do make some chains made for tight clearances. I've used both chains and cables on my truck but it is really close even with chains made for close tolerances. And I'd not try them on the front, rear only.
  10. Nov 23, 2019 at 7:59 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I Drive slower in the snow. Also drive right. Braking gently. A few inches of snow isn’t that big a deal. More than a few inches is kind of like driving on the beach (bump steering). Ice is a different story.
    BookieBob and BalutTaco[OP] like this.
  11. Nov 23, 2019 at 8:01 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Location matters. But generally yes if you’re on road.
  12. Nov 23, 2019 at 8:01 AM
    Inoculum
    Inoculum Well-Grown Member
    Parts Unknown
    16’ Limited
    Turn into the slide and keep your nose up. Good luck.
  13. Nov 23, 2019 at 8:05 AM
    Denny Crane
    Denny Crane Well-Known Member
    Idaho
    2020 Super White Tacoma TRD Off Road DCLB
    Kind of off topic here, but what about weight in the bed? Is that necessary on a Taco? I always did on my F250, but that was a much longer wheel base.
  14. Nov 23, 2019 at 8:07 AM
    Tallgrass05
    Tallgrass05 Well-Known Member
    They will do okay, but are not as good as the Firestone Destination A/T or Bridgestone Dueler A/T Revos I had on my previous truck. Just go slower, leave room for braking, and watch for other drivers going too fast. If there is more than 2-3" of snow I add some sandbags to the bed. That does make a difference.
  15. Nov 23, 2019 at 8:10 AM
    BalutTaco
    I also read something about adding weight to the bed too but its supposed to help you accelerate. Doesn't help you stop though LOL.
  16. Nov 23, 2019 at 8:14 AM
    john_t
    john_t Well-Known Member
    MA
    2018 Tacoma MGM Limited DCSB
    I'm facing the same dilemma right now. I don't want to spend $800 on dedicated snow tires, but I know how much better they are as well. What to do...
  17. Nov 23, 2019 at 8:15 AM
    tahoeskitaco
    tahoeskitaco Well-Known Member
    KLH
    North Tahoe
    2002 SR5 Xtra Cab + 2019 TRD OR Dbl Cab
    Stock. Custom hettich bed slide
    Funny. I went to Yosemite last may , drove through snow over Carson pass and at crane flat. GY Kevlars did just fine. Almost hit a deer in a brand new 3rd gen though....
  18. Nov 23, 2019 at 8:17 AM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    CA snow, especially in SoCal, is different than a lot of other places. Our freeze/thaw cycles make for much less consistent and much more sketchy winter driving. You don’t need chains for the front — look at your manual and get cables or chains for the rear. I saw lots of guys in 4Runners and Tacos slide into each other and parked cars (actual impact) last winter near Mt Baldy because they thought crawl control and 4wd equates to chains or cables (it doesn’t). Drive slowly, move the steering wheel smoothly, etc. have some weight in the rear.
    There is a lot of information on this out there. Read up on it or take someone who knows what they’re doing when you go out your first time. Search the threads on TW and read your owners manual.
    jamesfishn09 and BalutTaco[OP] like this.
  19. Nov 23, 2019 at 8:17 AM
    BalutTaco
    You didn't get pulled over by the CHP? or did you have chains on? Good thing i got deer insurance LOL
  20. Nov 23, 2019 at 8:18 AM
    eurowner
    eurowner Duke Sky
    Scoty
    I have been using dedicated winter tires since 1990 in NH, AZ, and CO on many different types of vehicles from VW Dasher Diesels, VW Rabbits, Audi quattro, VW Quantum Syncro Wagons, TJ Jeep Wrangler, K2500 Turbo Diesel Suburban, 1 ton SRW Square body pickup, as well as others.
    I use Toyo Observe GSi5 winters on my Tacoma from November through April. April through November I swap to Toyo Open Country ATIIs. A few times I was in snow, slush, etc with the Wrangler Kevlars, and wasn't impressed. The stock Wranglers are not as good in the snow compared to the ATIIs.
    If you live in a region where you have winter conditions for 4+ months, do yourself, family, friends, and others by getting a set of 4 dedicated winter tires. You might "get away with" 3 Peak Snowflake rated tires, but these tires still do not have the softer rubber compound with more deeper siping.
    DavesTaco68 and max_o like this.
