Stiff Ride After New Leaf Springs - Looking to Soften the Ride
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JoeSchmuck, Feb 14, 2018.
  1. Feb 14, 2018 at 8:02 AM
    JoeSchmuck
    JoeSchmuck [OP] Well-Known Member
    Joe
    Virginia
    09 PreRunner SR5 2x4 O.R., Timberline Green
    Pop & Lock, Access LE Rollup Cover, Alpine PDX-5 Amp, Image Dynamics CS-6/CX-6 & 10" Sub
    So I had my leaf springs replaced under the recall several months ago and I noticed that I now feel every imperfection in the road. I use to have the 3 leaf pack springs but now have the 4 leaf pack. I was hoping that over time (not decades) that the springs would break-in but that was a bit optimistic. I have never hauled a heavy load and if I do, hey I got bump stops, right.
    Now I'm looking for options in order to get back that softer ride and looking for opinions other than "Hey, letting the air out of the tires will soften the ride, and ruin your tires".
    I was thinking about adding something like an air suspension system like the Firestone Ride-Rite Air Bag Helper Springs but these only assist in bringing stability to a heavy load. Then I thought that I could remove a single leaf spring and then add the air bags.
    I'm basically not sure what the proper path is here but I'd like my smoother ride back and I'd prefer that the modifications be bolt on (something a weekend mechanic could do without specialized tools).
    Any and all suggestions would be appreciated.
  2. Feb 14, 2018 at 1:12 PM
    Jared8907
    Jared8907 txtaco07
    Texas
    2015 DCLB 4x4
    Weathertechs Tint Led Interior Method NV TRD Pro Bilstein Suspension Icon AAL CaliRaised sliders
    Throw a sandbag or two in the bed...
    cruxofthebisquit likes this.
  3. Feb 14, 2018 at 1:39 PM
    Buckwheat893
    Buckwheat893 Well-Known Member
    Cody
    Tucson, AZ
    2011 AC
    Easiest way to soften the ride up would be 1. Add weight to the bed or 2. Drop your tire pressure. I’ve noticed anything above ~40 psi in my rear tires makes for a rough ride. Other than that, you could wait for those springs to break in a bit or consider a different shock/air ride like you mentioned.
  4. Feb 14, 2018 at 1:44 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    What are your tire pressures at.
    Also, trust me you DO NOT want the POS 2+1 leaf pack....
    ChadsPride and stickyTaco like this.
  5. Feb 14, 2018 at 1:44 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Out of curiosity, what pressure are you running?
    stickyTaco likes this.
  6. Feb 14, 2018 at 1:55 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I'll be the 3rd to ask.....what tire pressure are you running?
    ChadsPride likes this.
  7. Feb 14, 2018 at 2:03 PM
    Pigpen
    Northwest Montana
    If you didn't replace the shocks, I'd do that. If it doesn't make enough difference for you, add weight. A steel rear bumper or fiberglass topper should do it. Or sand.
    blu92in99 likes this.
  8. Feb 14, 2018 at 2:08 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Add a bed mat. Useful and heavy.
    MattCowsmasher likes this.
  9. Feb 14, 2018 at 4:17 PM
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    You use to have the 3 leaf pack springs, but now have the 4 leaf pack. Don't understand why you went with 4, can you go back to the dealer and insist them to either install 3 OEM spring pack or remove one of the 4 you have now?
  10. Feb 14, 2018 at 4:18 PM
    Jared8907
    Jared8907 txtaco07
    Texas
    2015 DCLB 4x4
    Pretty sure they quit using the 3 Spring pack in 2012
  11. Feb 14, 2018 at 4:20 PM
    billybob50
    Bob
    Then have them take one out! Why should you spend money fixing their screw ups, the truck didn't come with 4 springs!
  12. Feb 14, 2018 at 4:39 PM
    Toy4me
    Tom
    NNJ
    One leaf can't be taken out, they weren't designed to be able to do that. "They" didn't screw anything up, this is the correct updated leaf pack. Yes, the truck didn't come with 4 springs, though it should have, and this is Toyotas' correction. The original 3 pack (which is actually 2 leaves and an overload leaf or 2+1 pack) wore out quite quickly and left you on or bouncing off the bump stops with even moderate loads in the bed. The ops new pack will break in, and adding a bed mat or some other weight and checking for correct tire pressures are what the op needs to do now.
    b_r_o and stickyTaco like this.
  13. Feb 14, 2018 at 5:06 PM
    billybob50
    Bob
    spitdog and Running Board Man like this.
  14. Feb 15, 2018 at 6:47 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I'm kind of surprised anybody would complain about the ride in a Tacoma being "stiff." I came out of a string of seven Ford F-150 4x4's to my 2014 TRD Sport. I love the truck, but find the ride - even with the 4 leaf packs - to be mushy at best. I can only imagine how mushy it would be with the 3 leaf packs! In fact I have gone as far as adding a set of rear Timbrens and Rancho RS5000 shocks in an attempt to both stiffen up the ride and keep the truck from bottoming out when towing my 22' boat. This has been marginally successful, but the truck doesn't ride anywhere nearly as firm as my F-150s - which I really liked the ride in.
    easyrider likes this.
  15. Feb 15, 2018 at 6:48 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Could throw Firestone airbags in the back. That’d help carry load and stiffen up. Could always sell the Timbrens too
  16. Feb 15, 2018 at 6:51 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I'm calling 4th! :D
  17. Feb 15, 2018 at 10:08 AM
    Too Stroked
    Tom
    Yes, but that wouldn't help the mushy front end. I've just learned to live with it. And maybe I just like a somewhat stiffer ride than most folks.
  18. Feb 15, 2018 at 10:12 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Elk Grove, Ca
    What shocks are you running? How many miles on them?
  19. Feb 15, 2018 at 10:24 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If you want a firmer ride, there’s definitely a way. I bet if you did 5100s in the front and put them on the highest setting with stock coils, you’d like it. Most people complain about it being too firm.
  20. Feb 15, 2018 at 11:18 AM
    Pigpen
    Northwest Montana
    Some people want a "truck", but really want a car. This is not the era of compromise.
    Honda made a truck for those people.
