Stiff clutch pedal all of a sudden
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andreasballs, Aug 17, 2021.
  1. Aug 17, 2021 at 9:19 PM
    andreasballs
    andreasballs [OP] Member
    San DIego
    2006 Prerunner
    Has anyone experienced this before?
    I started the truck the other day and the bottom travel of the clutch pedal had much more resistance than the last time I drove it. I peeked under the dash and nothing seemed out of place or broken, of course I have nothing to compare to.
    Pushing the pedal halfway feels totally normal. It's only past the halfway point (past the point of disengagement) that the issue presents. Its like the spring becomes way heavier. I can push through this to get the pedal to the floor but it takes noticeably more effort.
    Info that might me relevant:
    • This happened immediately and was not gradual.
    • I've put ~100 miles on it since, no change.
    • Clutch was replaced at 396k miles, truck now at 437k.
    • Clutch still engages smoothly and at the same point at before. No slipping.
    • Nothing feels "crunchy" or broken. Literally just feels like there's a second, stiffer spring that engages once the pedal is pushed halfway down.
    Let me know if this sounds familiar!
  2. Aug 17, 2021 at 9:35 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The release bearing (throw out bearing) could be sticking on the shaft it slides on, I think its called a quill?
    The spring fingers on the pressure plate could be messed up
    Can't say I've ever seen a master cylinder bind up
    Have you looked under the dash to see if anything is obstructing the clutch pedal arm?
    Jimmyh likes this.
  3. Aug 18, 2021 at 2:07 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I'm afraid this is going to be one of those tear it apart and find out what is causing the problem.
  4. Aug 18, 2021 at 2:13 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    This is a second gen?
    V6?
    May have busted your transmission quill.
    If you're lucky it's just chewed up and binding and can be cleaned up and repaired with a URD transmission Quill kit.
    If you're unlucky you'll be buying a low milage used transmission.
    Also if you haven't alread try deleting your clutch accumulator valve and thoroughly bleeding the system.
  5. Feb 27, 2022 at 9:32 AM
    andreasballs
    San DIego
    2006 Prerunner
    Here's an update since nobody likes unresolved threads.
    I just kept driving the truck - it's now been 6 months and 4000 miles with no change. Truck still shifts fine & I don't notice the firmer pedal anymore. Gonna keep driving it as is!
    There was also one morning when my throwout bearing was whining. It stopped after a couple mins of driving and never made a noise again. I'm not worried about it, nor am I convinced it's related.
  6. Dec 27, 2024 at 10:41 AM
    Olyellen
    Olyellen New Member
    2094 manual 4x4 tocoma
    This is happening to me now. The only difference is that the truck will not start when I use clutch, I have to press clutch bypass button and it starts no problem. Any thoughts much appreciated.
