stereo wire diagram help please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jake slatnick, Nov 17, 2009.
  1. Nov 17, 2009 at 8:47 PM
    jake slatnick
    jake slatnick [OP] Well-Known Member
    jake
    San Diego
    Cement TRD Pro
    285/75r16 KO2's, Baja XL 80's on CBI ditch brackets, TRD intake, opticoat pro, clear bra running the bottom sides, morimoto LEDs, all white LEDs inside, mounted shovel and axe above wheel well in the bed, linex'd the bed...
    I am looking for the diagram for the stereo wiring harness. I mean the one that is in the dash that is connected to the back of the OEM stereo.
    I have seen several posts that describe the wiring harness that you can purchase and connect to the OEM one but this is NOT what I am looking for.
    I plan to cut the existing connector off and wired directly to the connector on my new stereo but I can not find the specs any where. I realize this might not be the best option if I want to install the old radio back.
    Your help would be greatly appreciated.
    Thanks
  2. Nov 17, 2009 at 8:56 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    My question to you is WHY? There's no benefit and the money saved would not outweigh the headache unless you know what you are doing.
    I don't know about the Tacoma but if there are two plugs then one may contain the power and ground and the other would be the speaker connections. Take a test light or multimeter and determine which leads have power.
    cajunbull61 likes this.
  3. Nov 17, 2009 at 9:00 PM
    BPachom
    BPachom Well-Known Member
    Long Island
    09 Tacoma SR5, 4cyl 4X4, Black
    Access roll-up tonneau cover, Factory radio W/Sirius, Tailgate clamp, HID head lights, Stainless nerf bars.
    I agree!
  4. Nov 17, 2009 at 9:03 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
  5. Nov 17, 2009 at 11:01 PM
    Tony D
    Tony D Well-Known Member
    Tony
    DO NOT cut your factory harness.. no reason to really, and it just makes for a PIA later. If you are worried about fidelity you should be running new wire for everything anyways.
    Just use a Metra or Schosche harness adapater.
  6. Nov 17, 2009 at 11:06 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    x1000
  7. Jul 15, 2019 at 4:29 AM
    Mimete
    Mimete Member
    Heidi
    Quebec
    2002 Tacoma Xtra Cab TRD
    Stereo, grille
    I cut off the factory harness. It wasn't the end of the world. I used a diagram like this one to match Toyota's wire colors with the equivalents on the wiring harness for my new stereo:
    It worked well for me. If you've never done wiring before, it might take a little trial and error to get the hang of stripping the wires, twisting the paired wires together, and making a neat and secure cap out of electrical tape.
  8. Jul 15, 2019 at 8:25 AM
    Mimete
    Mimete Member
    Heidi
    Quebec
    Stereo, grille
    To be clear, I don't recommend this approach. But if it's too late to buy an adapter and, like me, you have already cut off the factory harness, I hope this helps.
  9. Jul 15, 2019 at 8:32 AM
    Muddinfun
    Muddinfun Well-Known Member
    I hate to say it, but only tweakers chop the factory harness to install a stereo.
    Bumping a 10 year old thread to explain how to butcher your truck-- Priceless
    Welcome to TW.
    Taco Shepherd likes this.
  10. May 14, 2022 at 5:55 AM
    98TacoSr5-2.4
    98TacoSr5-2.4 New Member
    Red
    Magnolia,TX
    1998 Red Tacoma SR5 2.4 liter
    Only tweakers cut off and not finish.
  11. May 14, 2022 at 5:59 AM
    rtkbowhunter
    rtkbowhunter Well-Known Member
    Southeast PA
    2011 Tacoma Quad Cab SR5
    Wait. What? Twist & tape connections? Not solder or at least crimp?
