Step by step DIY Alternator Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nj636, Jul 26, 2015.
  1. Jul 26, 2015 at 9:09 PM
    nj636
    nj636 [OP] Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    Had to change the alternator on my 2006 Double Cab 4.0 this afternoon so I decided to take some pictures along the way:
    Tools Needed:
    WRENCHES
    · 10mm ratcheting preferred
    · 14mm ratcheting preferred
    RATCHETS
    · 3/8" DRIVE
    · 1/2" DRIVE
    · 1/2' BREAKER BAR
    -EXTENSIONS-
    · 3/8 DRIVE 3 INCH LONG
    · 1/2" DRIVE 3 INCH LONG
    SOCKETS
    3/8" Drive - 10mm deep / 12mm deep
    1/2” DRIVE - 14MM shallow
    This is what you will be left with when you are done with the job
    Step 1
    you will remove the 10mm nut attached to battey hold down
    Step 2
    Remove the hold down - Remove the positive & negative battery cable & remove the battery
    Alternator can be see
    The plug in the rear can simply be unplugged and put to the side
    Unplugged
    Next step would be working the plastic cover off of the 10mm nut attached to the battery cable stud. It take a little finesse to work the plastic cover off by hand
    Now you can get the ratcheting 10mm wrench onto the 10mm battery cable nut
    Here the cable is off
    There are two small 10mm nuts that hold a bracket onto the side of the alternator. I used a ratcheting wrench to access both bolts.
    front 10mm bolt
    rear 10mm bolt
    bracket moved out of the way
    now you can remove the alternator belt
    the tensioner has a 14mm head on it. It can be reached with the 1/2" breaker bar, 3" extension & shallow 14mm socket
    (here you can also see the 12mm deep for the top alternator bolt)
    better look at where the tensioner is for the belt
    Push the bar towards the passenger side of the truck to remove tension
    take the belt off the alternator pulley and set is aside
    now you can move onto the top alternator bolt, 12mm
    here can see the 14mm socket sitting on the lower alternator bolt.
    Remove the 14mm bolt
    after those bolts are removed, the alternator is ready to come out
    It's take a bit of maneuvering the alternator to get it up and out of the engine bay.
    This is what you are left with.
    Installation is reverse of removal. Check the idler pulleys and tensioner while you are there.
    New alternator installed
    I put some dielectric grease in the plug before installing it back into the alternator.
    Elkhart, knottyrope, dk_crew and 30 others like this.
  2. Jul 26, 2015 at 9:09 PM
    nj636
    Kev
    Jersey
    Just something I put together for those who many have trouble figuring these things out for the first time.
  3. Jul 26, 2015 at 9:09 PM
    nj636
    Kev
    Jersey
    SAVED\
  4. Jul 26, 2015 at 9:09 PM
    nj636
    Kev
    Jersey
    SAVED
  5. Jul 26, 2015 at 9:13 PM
    nj636
    Kev
    Jersey
    WILL be finished tomorrow
  6. Jul 26, 2015 at 9:24 PM
    Manwithoutaplan
    ID
  7. Jul 27, 2015 at 7:18 AM
    Manwithoutaplan
    ID
    well done sir. Done might one to many times.
  8. Jul 28, 2015 at 6:59 PM
    nj636
    Kev
    Jersey
    thank you sir. figured I'd add to the DIY writeups
    Crom and Manwithoutaplan[QUOTED] like this.
  9. Sep 22, 2015 at 6:31 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Thanks for the write up bud!
    nj636[OP] likes this.
  10. Jan 15, 2016 at 10:43 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Very good! Thank you.
  11. Jan 15, 2016 at 11:24 AM
    Holeshot
    Holeshot Well-Known Member
    Gary
    Alabama
    15 Doublecab TRD Off Road 4 X 4
    Excellent write up with very clear pictures and detailed instructions.
    Many thanks.
  12. Jan 16, 2016 at 5:44 AM
    nj636
    Kev
    Jersey
    Welcome :thumbsup:
  13. Mar 2, 2016 at 12:13 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Finally found one! Great write up, will hopefully be doing mine this evening now that I know how ;)
    Crom likes this.
  14. Mar 3, 2016 at 2:53 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Thanks for the pics and writeup. Looking to upgrade my alternator with a remanufactured 200 amp output from these guys:
    http://stores.ebay.com/BNR-PARTS-ALTERNATORS-AND-STARTERS?_dmd=1&_nkw=tacoma
    $195 and includes free shipping, and no core required (OEM can be my backup). $215 for 250 amp model, but then I'd have to upgrade my solenoid relay for my 2nd battery isolator. 200 amps is enough for me.
    Crom likes this.
  15. Mar 3, 2016 at 3:17 PM
    benbacher
    Anchorage, AK
    A quick google pulled this up, careful with those 'good deals'. My alternator was over 500 at 250 amps. Sometimes a deal is too good to be true. The top five postings off google are all warnings. DCPower is no joke.
    https://www.youtube.com/watch?v=fioclq18Mng
  16. Mar 3, 2016 at 3:21 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Great write up, I suggest purchasing a pressure washer ;)
  17. Mar 3, 2016 at 3:24 PM
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
  18. Mar 3, 2016 at 5:03 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Seen that. That's about the only negative entry on youtube I saw, assuming that is even a BNR alternator. Someone posted in the comments they get most of their parts from BNR and have not had problems. Their eBay rating is pretty good. Plus, I understand BNR is the parts supplier for a TW vendor. I do intend to shop there but I will have a local electric shop bench test the alt before putting it in my truck. Actually planning on getting one of their alts first for my daughter's Corolla
  19. Mar 3, 2016 at 5:17 PM
    benbacher
    Anchorage, AK
  20. Mar 4, 2016 at 12:40 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Sub'd!
