Steering wheel vibration: CV axle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomax4, Oct 13, 2018.
  1. Oct 13, 2018 at 6:33 AM
    Tacomax4
    Tacomax4 [OP] Well-Known Member
    2012 DCLB TRD Sport 4x4
    Hey guys,
    After replacing the steering rack and inner and outer tie rods, getting new wheels/tires and having them rebalanced by several different shops, wheel bearings, brakes, ball joints, struts, UCA and LCA bushings, and steering intermediate shaft, I’m at the point where I’m considering the CV axles to be the culprit of my intermittent steering wheel shake at high speeds. I’ve currently got Cardone CV axles installed and they’re about 6000 miles old, although the steering wheel has always shook. Could these cheap aftermarket axles be the reason why my steering wheel is shaking? Even in 2wd?
    Thanks
  2. Oct 13, 2018 at 8:59 AM
    dreadedyota
    dreadedyota Well-Known Member
    Ernest
    Ontario Canada
    2008 Black Tacoma TRD.SR5.Sport
    Camburg UCA,Cowl Induction, ECGS, Exhaust Reroute.
    These trucks are known to have the steering wheel shake after a lift usually caused by the needle bearing in the front driver side axle housing. Look into the ECGS replacement bushing, plenty of threads on the issue seems to be the only fix.
  3. Oct 13, 2018 at 9:07 AM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Wheels hub centric?
  4. Oct 13, 2018 at 9:47 AM
    Tacomax4
    I don’t have a lift though, all OEM suspension
  5. Oct 13, 2018 at 9:48 AM
    Tacomax4
    Not sure. OEM 17 trd sport wheels
  6. Oct 13, 2018 at 9:59 AM
    303tacoma
    Rebecca
    Yep
    OEM wheels are hub centric
  7. Oct 13, 2018 at 10:07 AM
    303tacoma
    Rebecca
    Does the vibe go away in 4wheel?
    @dreadedyota has a point lifted or not
  8. Oct 13, 2018 at 10:09 AM
    Tacomax4
    No it stays the same
  9. Oct 13, 2018 at 10:51 AM
    303tacoma
    Rebecca
    Have you check your wheel bearings?
  10. Oct 13, 2018 at 11:29 AM
    Tacomax4
    Yes those have been replaced as well with aftermarket ones. Edited OP
    303tacoma[QUOTED] likes this.
  11. Oct 13, 2018 at 11:34 AM
    CBenfell
    CBenfell I don’t know sh*t about f*ck
    Christian
    Western Washington
    21 DCSB TRD OR Midnight Metallic Black
    Crippling Debt
    Warped rotors?
  12. Oct 13, 2018 at 11:36 AM
    Tacomax4
    Maybe... but I doubt it, shaking is the same while braking and feels nice and smooth, they were replaced about 6000 miles ago with the CV axles when the frame was done
  13. Oct 13, 2018 at 11:38 AM
    303tacoma
    Rebecca
    I’d lean towards a bad balance
    I know every time I get my tires balanced I have to go back and get them rebalanced
  14. Oct 13, 2018 at 11:41 AM
    Tacomax4
    You could be right. I wish there was a shop in my city with the Haweka adapter. All 4 of the dealers in my area think I’m crazy when I bring it up. They don’t have road force balancers either, only my local Canadian Tire. I had them do it twice to my wheels and didn’t change anything
  15. Oct 13, 2018 at 11:44 AM
    303tacoma
    Rebecca
    Maybe you have a bad tire
    Change them front to back to see if it changes.
    Any othe Tacoma people in your area that you could switch out wheels and tires for a test run to see if the vibe goes away.
  16. Oct 13, 2018 at 5:36 PM
    CBenfell
    Christian
    Western Washington
    Crippling Debt
    I had something like this until they were road force balanced, then I was fine.
  17. Oct 13, 2018 at 6:21 PM
    Tacomax4
    I took your advice. My brother has a Tacoma that doesn’t have a shaking steering wheel, so I took the wheels off of his truck and put them on mine a couple hours ago. The shake was almost gone, but still minimally there. Out of curiosity I put my wheels on his truck, and they were fine (no shake). Hmmmm
  18. Oct 13, 2018 at 6:21 PM
    Tacomax4
    Did they use the haweka adapter as well?
  19. Oct 13, 2018 at 6:31 PM
    303tacoma
    Rebecca
    Hmmmmm is right
    Well at least it rules out your wheel set up I think
  20. Oct 13, 2018 at 7:39 PM
    peteyfresh
    peteyfresh Well-Known Member
    Pete
    13 Taco DCLB, 04 4Runner, 97 Jeep ZJ, 86 VW GLI
    What kind of tires do you have? My BFG K02s give me a slight intermittent vibration, usually around 45-50. They will balance out fine though. Vibration is always a little different after each rotate.
    Edit: just saw you already swapped wheels/tires and it's still there.
    Try removing your rear prop shaft. Put it in 4hi and see if the vibe goes away. This will eliminate u-joints as a culprit
