steering wheel starts shaking at 70+ mph in the morning only
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kcourter, May 20, 2015.
  1. May 20, 2015 at 9:27 AM
    kcourter
    kcourter [OP] New Member
    Kyle
    Phoenix
    06' Tacoma
    I just got new tires and I was hoping that would fix the shaking but it didn't. It starts shaking about 5 minutes in to my drive and doesn't stop until I slow down significantly or stop. Putting it in neutral doesn't help. Braking seems to make it worse at first. I'm pretty sure I need a new brake booster
  2. May 20, 2015 at 9:33 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Steering wheel shake is usually a tire balance problem.
    Did the shop that sold you new tires road-force balance them?
    Are you using wheel spacers?
    If you're using aftermarket wheels, are you using acorn nuts to center them on the lugs?
    Try borrowing another set of wheels and lug nuts from another tacoma owner who's not having a wheel shake problem. If the problem goes away, you know it's somewhere in the combination of your tires, wheels, and lug nuts.
  3. Jun 11, 2015 at 6:57 PM
    kcourter
    Kyle
    Phoenix
    06' Tacoma
    I have stock wheels and I just replaced the tires (discount tire, Bridgestone alenza) and I got the same shake/vibration. Some times it moves from the steering wheel to the cab and my seat shakes. I'm starting to think it is in the drive line...
  4. Jun 11, 2015 at 7:37 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    You have an 06' have you checked your steering rack bushings ? I would bet a cold hard $1 they are toast which means your tie rods are no longer connected to something solid and you can get insane vibes that feel like seriously unbalanced tires. It is a common prob with these trucks, just had to replace mine last year, felt like I had square unbalanced tires on the highway...Energy Suspension makes urethane replacement bushings for it. If your in Phoenix give SDHQ a call and have them check it out for you, they can get the parts and do the work for you too.
    kcourter[OP] likes this.
  5. Jun 11, 2015 at 7:55 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    I once bought a set of tires that appeared to "take a set" after a drive on the hot road. Then the next morning it felt like they had a small "flat side". After driving, that shaking would warm them up and it would quit. I took them back and had the tire shop check them. Claimed they were made "out of round" and tried some sort of "shaving process." Stupid idea. Took about 1/4" of tread off on one side. Refused to leave with those tires. Moved to a different brand and didn't notice it. Whether that is your problem or not, I can't guess. But it has happened. You can either tolerate it or return to the store and make 'em fix it (without shaving which is still a stupid idea).
  6. Jun 11, 2015 at 8:00 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    ...he said he had the shaking before the new tires and the new tires did not solve the problem, now I'm not a bright man but me thinks = problem is not the tires :evil:
  7. Jun 11, 2015 at 8:20 PM
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    Hmmm, I dunno man... that makes a little too much sense ME thinks :D
  8. Jun 11, 2015 at 8:26 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    hey... that kind of crazy talk has no place on TW :crazy: I want a TW window sticker that says " Tacoma World - where opinions matter more than facts and logic and science and geometry "
  9. Jun 11, 2015 at 8:36 PM
    millertime89
    Erik
    Saskatchewan
    Yes sir
    @tcBob
    I'll take one as well!
    tcBob likes this.
  10. Jun 11, 2015 at 8:41 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    aw shit I shoulda' copyrighted that :facepalm:
  11. Jun 11, 2015 at 10:32 PM
    wolfeinstein
    wolfeinstein Well-Known Member
    Orange County, California
    Mean Machine
    Only in the morning that means you woke him up too early and he is throwing a fit.
  12. Jun 12, 2015 at 8:11 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I think that's Bridgestone thing. My two cars did that with Bridgestones, I changed one to Yokohamas and it is gone. My friend has Bridgestones and he gets the same thing in totally different car.
  13. Jun 12, 2015 at 8:14 AM
    BlueT
    NorthEast
    I have the same thing on one of my cars, I replaced old tires that had shake (Bridgestones) with new tires (Bridgestones) and shake is still there.
    On my pickup I replaced (Bridgestones) tires that had shake with new tires (Yokohamas) and no shake...
  14. Jun 12, 2015 at 8:29 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Seat shakes? When is the last time you greased the driveshaft u-joints?
