Steering Wheel shake when braking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by STLTaco09, Nov 28, 2011.
  1. Nov 28, 2011 at 2:12 PM
    STLTaco09
    STLTaco09 [OP] Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    My steering wheel shakes at highway speeds only when braking. It seems very smooth around town, even when braking. I've always thought this was due to warped rotors, but I want to say it slightly changed a bit when I recently put in shims in the rear and flipped the carrier bearing - making me think it might be driveshaft related. Just curious if that is possible or if it is still likely warped rotors or unbalanced tires/wheels?
    I had the dealer check out the front brakes and mentioned the warped rotors a month or 2 ago, they said everything checked out, but I dont know how closely they looked at the rotors, I have a feeling they just checked the pad thickness...
  2. Nov 28, 2011 at 2:16 PM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
    I'm with you either warped rotors or unbalanced tires. My brother had this problem on his 95.5 taco even after having his rotors machined. His problem was only fixed when he got new rotors.
    2006offroad likes this.
  3. Nov 28, 2011 at 2:16 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Thats warped rotors!
    Kolter45, Alexely999 and DrFunker like this.
  4. Nov 28, 2011 at 3:34 PM
    Aw9d
    Aw9d That one guy
    Big time warped rotors. My dad did that to his 08 taco.. Replace them, don't machine them.
  5. Nov 28, 2011 at 4:29 PM
    saugus
    saugus Well-Known Member
    Been there. Replaced rotors and brakes and done.
    DrFunker and ChadsPride like this.
  6. Nov 28, 2011 at 4:34 PM
    YotaMark
    YotaMark Well-Known Member
    Mark
    Mentor, Ohio
    08 Tacoma 4 cyl 5 speed 4X4
    Rear Gate security Mod (although I seldom take my eyes off it) "Harsh Ride" Shocks and Springs TSB performed by "Me" New Cooper Discoverer AT3s 265/75R16s (fit well) Front "Tacoma Mike" light mod! Rugged Ridge floor mats. Bought another set of D rings and installed them in my wheel well. Perfect! Just hit the big 6000 Miles 12/19/11, Installed an alarm system to go with my factory power door locks 1/21/12
    Hello.. The dealer and I agree. your rotors are warped...
  7. Nov 28, 2011 at 4:40 PM
    taconewby
    taconewby Well-Known Member
    James
    Dallas Tx.
    06 Tacoma
    factory fogs,black projector headlights, Kenwood head unit, kicker/Infinty speakers
    If not sure use a dial indicator to check the run out of the rotor.
    SR-71A likes this.
  8. Nov 28, 2011 at 6:53 PM
    STLTaco09
    That is crazy then. I have only 42,xxx miles on the truck. Only been through water less than a handful of times but I guess it only takes one time. I know a brake job is cheap and I can do it myself. I was hoping I could get more out of them though. I suppose I could just replace the rotors and leave the pads....
    Alexely999 likes this.
  9. Nov 28, 2011 at 7:48 PM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    Warped rotors for sure!
  10. Nov 28, 2011 at 8:51 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Running the wheels on the studs with an impact gun at full speed (especially a good one) is enough to warp the shit out of rotors......torque wrench for the win!
    ColoTacoPrerunner06 likes this.
  11. Nov 29, 2011 at 6:49 AM
    STLTaco09
    That's a good point. I always use a torque wrench in the garage, but it's been at various places for wheel alignment, lift install, tire rotation with other services that they may have tightened them too much when they put the wheels back on.
    I'll have to research some new rotors then. Thanks.
  12. Nov 29, 2011 at 6:54 AM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    +1 on warped rotors, ..since it only occurs when braking..
    you might try just backing off the lug nuts a tad, and retorquing to spec w/ a torgue wrench - can do this on it as it sits in the garage... maybe they overtightened the wheels...
  13. Nov 29, 2011 at 7:35 AM
    STLTaco09
    I check them periodically with the torque wrench and they are good, right at 80 ft/lbs I believe. I've had the wheels on and off quite a bit lately and the issue has persisted for quite some time. So if it was lug nut torque related, then I'm afraid the damage has been done. Thanks for the suggestion though.
  14. Oct 31, 2016 at 2:40 PM
    override
    override Well-Known Member
    Robert
    2015 DC Tacoma Sport 4x4
    After some searching it seems most all the thread on this issue were never followed through with, so rather than making a new thread I'll just bump an old one.
    My new to me 2015 Taco with only 23k miles on it has this exact issue...I didn't notice it until after I drove it off the lot and was braking at hwy speeds, low speeds it doesn't seem to be prevalent. I have not had the chance to pull the wheels and check everything but is it safe to assume that new pads and rotors will be in order?
    Thanks!
  15. Jan 5, 2018 at 5:07 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    i know this is a thread revival. That said, I noticed the shaking in my steering wheel recently when braking at highway speeds. Just like the OP, I don't notice it around town. Only on the highway and during heavy braking.
    I had the rotors turned at Oreillys about a month or two ago because they had plenty of life. I put them back on and added new pads and all seemed well. I know that you always put new pads on new rotors, so I'm going to be very disappointed if I have to replace (new) pads and the rotors.
    I also have my sway bar off right now as I recently upgraded my suspension, and I have not had the tires balanced in a while. I'm planning to reinstall the sway bar and front skid this weekend. I'll also get my tires balanced just to be sure. If it persists after that, I suppose I'll be in the market for new rotors :(.
  16. Jan 5, 2018 at 5:41 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    It’s the rotors, but unless you do high speed racing or drive downhill 30 miles each way to and from work everyday, your rotors aren’t warped. It takes a tremendous amount of heat to warp a peice of metal as thick as your rotors. This only occurs in extreme circumstances, not in daily driving.
    When your brakes get heated from excessive use, when you stop your brake pad burns essentially an impression of brake pad material onto the rotor. Providing an uneven surface for braking. Over time it gets worse and causes shaking when braking at high speeds.
    There are many reasons why this can happen but 99% of the time it’s going to be driving habits. Braking too aggresively and too often. Slow down in the city, don’t accellerate super fast so you have to slam your brakes, anticipate stop signs and red lights, coast down before running right up to the car infront of you then stop abruptly. In essence, play the game of “your brakes are lava”, use them as little as possible.
    Also whats important is when you get new brakes is seat them properly after putting them on. Without doing this it puts you at risk for getting uneven brake pad wear.
  17. Jan 5, 2018 at 6:12 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Try new brembo blanks, worked for me.
  18. Jan 5, 2018 at 6:16 AM
    CowboyTaco
    North Georgia
    11 TRD Sport
    While I'm not going to disagree, I'm not in total agreement either.
    Rotors were turned a few thousand miles ago, so they should be smooth as can be. New pads were used and seated properly. Though I don't fully understand the point of seating them. I mean, I do, but I highly doubt every brake shop takes every car they service out to the highway to seat the brake pads. So I'm not entirely convinced that is a necessary step. Either way, I've done a half dozen or so brake jobs and never had this issue. I've also never turned rotors, as I have always just replaced them with new. This is my first time having rotors turned/machined/resurfaced/whatever you want to call it.
    I already do coast to stops and as much as possible. I'm not an aggressive driver by any means.
    After reading some other posts, I'm going to check for and remove any surface rust between the rotor and hub in addition to the other steps I mentioned above.
  19. Jan 5, 2018 at 6:29 AM
    Jengel451
    Jengel451 Member
    FYI, just picked up an 08 that had the same issue. Dealer had turned the rotors so assumed was a crap job. Picked up a set of power stop rotors and pads for 100 bucks online. Put them on, same issue, no change at all.
    So I brought it back into the garage and pulled the front wheels and put a dial indicator on things. yep, Rotor "Seem" warped....but brand new? Nahhhh. Pulled the rotors and checked the front hub with the dial indicator.....BINGO. One hub was the culprit, bearings were quiet etc. Was just off enough to seem smooth at speed but jacked up under braking.
    Replaced both sides with a set of Droman complete assemblies and all is fixed, truck is smooth as silk now.
    Mine is a 2WD, so all work is dead simple, probably an hour's work to replace Rotors, Pads, Hubs and get back on the road. This truck is awesome to work on, almost reminds me of aircooled Type 1 bugs.....almost.
    black coffee and techbill like this.
  20. Jan 5, 2018 at 6:34 AM
    CowboyTaco
    North Georgia
    11 TRD Sport
    Good to know. I'll check that out when I get everything apart to check for surface rust.
    Any info on how you checked the front hub with the dial indicator? I'm going to google how to do that....
