Steering wheel shake/vibration while stopped/idle; steering wheel play.
Discussion in '1st Gen. Tacomas (1995-2004)' started by jmgl707, Jul 20, 2022.
  1. Jul 20, 2022 at 1:58 PM
    jmgl707
    jmgl707 [OP] New Member
    Meekz
    1997 Tacoma 2WD single cab
    What's up everyone
    I wanted to get some input from ya'll after I searched the site and internet for something similar to what I'm running into. I recently bought an auto 97 Tacoma single cab with about 278k (2RZ) and have noticed that when idle/stopped the steering wheel often vibrates/shakes considerably. I've only noticed the shaking/vibration at a stop when idling and usually this starts when something like the AC kick in but will be intermittent as I am stopped and idling. Aside from the shaking/vibration at idle it does seem like the steering wheel has some slight play and I can hear a rattle coming from somewhere within the steering column from time to time. I will try and get a video uploaded shortly.
    The culprits I'm suspecting are
    1. Bad engine mounts
    2. Something loose in steering column
    3. Harmonic balancer out of circle
    Appreciate any feedback !
  2. Jul 20, 2022 at 2:09 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Have you tried shifting into neutral while idling ........ does it still shake??
  3. Jul 20, 2022 at 2:17 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    If you up the rev’s while it’s shaking, does the vibration go away?
  4. Jul 20, 2022 at 3:18 PM
    jmgl707
    Meekz
    Steering wheel still vibrates even when shifting into neutral. Shaking/vibration goes away once I let go of brakes and start driving. At idle I can get the shaking/vibration to go away when pushing on steering wheel as well as when turning to put it under load.
