Steering Wheel Not Returning to Centre PART 2
Discussion in '1st Gen. Tacomas (1995-2004)' started by Carter Tacoma 03, Jan 23, 2021.
  1. Jan 23, 2021 at 7:51 PM
    Carter Tacoma 03
    Carter Tacoma 03 [OP] Well-Known Member
    Carter
    2003 Toyota Tacoma Xtracab Prerunner 2WD 2.7L L4
    A couple posts ago I was talking about my steering wheel not returning to the centre. I went to my local Toyota and they did an alignment as literally everyone told me to do. So that’s done, the mechanic said that it still may not return to the centre because of a bearing that is only in the second and third gens that allows the steering wheel to return to the centre. He said it is the steering rack that is responsible for that aswell. However, he said my whole truck looks in great condition including the steering rack so I was wondering, would I need a new steering rack for the steering wheel to ACTUALLY return to the centre or should I not worry about it as it’s not really needed and I got an alignment? Thanks.
  2. Jan 24, 2021 at 9:35 AM
    Running Board Man
    Running Board Man Well-Known Member
    Has your rack ever been replaced?
    2/3 racks that were replaced on cars I've owned were replaced wrong and needed the column centered to the rack
    Can you turn more to the left than right?
  3. Jan 24, 2021 at 10:36 AM
    Carter Tacoma 03
    Carter
    @Running Board Man i don’t notice it. It could be possible though. And he said there were not issues either he steering rack so I assume that meant it was centred properly aswell.
  4. Jan 24, 2021 at 10:45 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Is there any binding otherwise other than it not returning on it's own?
  5. Jan 24, 2021 at 10:56 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Umm....... I'm gonna throw the BROWN BS flag on the "mechanic"
    Get to another shop. Something is off with the LCA/UCA. You likely have worn bearings, bushings, pins........
    Once upon a time ago, the Kingpin would bring the steering back to center. This is now part of the suspension geometry of the control arms.
    Either this or the toe-in was set without the steering wheel being centered.
  6. Jan 24, 2021 at 1:01 PM
    Carter Tacoma 03
    Carter
    @Dm93 nope nothing else
  7. Jan 24, 2021 at 2:17 PM
    jmferg
    jmferg Well-Known Member
    LBJs.
    I had a off feeling while turning and the steering wheel wouldn’t return to center on its own.
    Replaced LBJs and the feeling went away. If you google LBJ failure, that is one of the only common symptoms I’ve seen pre failure
