Steering wheel jolt's/jerks when I hit the brakes suddenly. Normal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cfrea, May 16, 2012.
  1. May 16, 2012 at 9:04 PM
    cfrea
    cfrea [OP] Well-Known Member
    2012 Tacoma Double Cab TRD Sport
    Lets say I'm doing 60-70mph on the highway and like suddenly hit the brakes, not smoothly applying them but suddenly tapping them with moderate force. When I do that, I feel the steering wheel slightly jerk to one side maybe 1inch either way. Truck is a 2012 with like 400 miles. Any ideas? Normal?
  2. May 17, 2012 at 4:15 AM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    Possibly warped rotors?
  3. May 17, 2012 at 4:34 AM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    Normal sign of wheel bearings going bad. Mine were doing it until I replaced them. J hope yours aren't bad though. Your truck is grand new!
  4. May 17, 2012 at 4:49 AM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) Your braking needs to be more gentle and solid with your braking till you have broke in your rotors and pads. Your rotor needs to build up a layer of braking material on the rotor to help the brake pads bite. By suddenly applying the brake and releasing them is causing uneven braking and your pulling from side to side. You will usually pull toward the crown as uneven braking upsets the balance of your handling. Just brake differently and you should not have any more problems.
  5. May 17, 2012 at 4:58 AM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    What? I break in rotors by standing on the brake pedal!
    OP - you likely have an alignment issue that is exaggerated when you brake hard, because you are loading the front end. IMO it's not so odd for a new car to have alignment issues after being strapped to a hauler. Have the dealer check it out for you.
  6. May 17, 2012 at 5:25 AM
    Ga tacoguy
    Rudy
    Augusta Ga.
    :) I guess my choice of the word Solid may incur some disagreement. Let's use the Gentle and FIRM braking then. Since you have a 07, you also have the standard ABS braking and for the system to work safely, you need to gentle but firm and not apply brakes with a quick stab. The ABS system is quick, and when it has a sudden application, the system goes to work and either helps apply or remove braking from the Taco.
  7. May 17, 2012 at 5:34 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Like Rudy says, probably just not broken in yet. It wasn't clear from your post whether it is always to one side, which might indicate a problem if it was, but you need to get a few more miles on it.
    I had to jab the brakes quickly going about 40mph in my 2012 TRD OR the other morning, the ABS kicked in and it felt like I ran into a tree it stopped so dang fast. I have about 2K miles on mine now, definitely no braking issues.
  8. Dec 19, 2018 at 5:13 PM
    shaftu2
    shaftu2 New Member
    Eddie
    jeep Cherokee Laredo
    bunch of dummies, either your spindle or bearings
  9. Dec 19, 2018 at 7:46 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Holy thread resurrection Jeep owner...
    Jimmyh likes this.
  10. Dec 19, 2018 at 7:48 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Cheebus H Cripes! 2012 people! Live and let die.
    And his first post too! Oh, sweet Cheebus! Welcome to TW, shaftu2.
  11. Dec 19, 2018 at 7:55 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What was that about a dummy?
  12. Dec 19, 2018 at 7:58 PM
    Notoneiota
    Oakdale, MN
    First post he resurrects a thread that died in 2012 and his vehicle is a Jeep Cherokee? GTFO. Someone alert a mod.
    MuddyJackson likes this.
  13. Dec 19, 2018 at 7:58 PM
    Bebop
    Nick
    Don’t see how a solid piece of steel can cause a pull... a bearing maybe, but a spindle?
    Jimmyh[QUOTED] likes this.
