Steering whee shake at 60 MPH??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jnorris, May 4, 2019.
  1. May 4, 2019 at 2:40 PM
    Jnorris
    Jnorris [OP] Well-Known Member
    Jordan
    2005 Toyota Tacoma
    Bought an 05’ DLCB 4wd. When I bought, it would start shaking at 60mph. Needed new tires bought them and still shakes. When I went and got my alignment done, they said I had a sloppy hub and it needed to be replaced. Of course I just replaced it and still did not fix it. So it only does it at 60-65 once I reach over those it stops. I am stunned and for the life of me can’t figure it out. Check other hub and it was good to go. Any suggestions? Rebalance tires?? Or??
    New tires, and hub assembly so??
  2. May 4, 2019 at 2:40 PM
    hawaiidclb
    hawaiidclb Well-Known Member
    Maui, Hawaii
    08 Black DCLB 4x4
    Sub’d
  3. May 4, 2019 at 2:42 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Steering whee ??
    I would have a look at your ball joints (and everything else in your front suspension and steering).
    DrFunker likes this.
  4. May 4, 2019 at 2:43 PM
    DrFunker
    DrFunker Well-Known Member
    hawaiidclb and Hobbs[QUOTED] like this.
  5. May 4, 2019 at 2:43 PM
    Hobbs
    Yep…
    Ha!
    hawaiidclb and DrFunker[QUOTED] like this.
  6. May 4, 2019 at 2:44 PM
    DrFunker
    :wink:
    Hobbs[QUOTED] likes this.
  7. May 4, 2019 at 2:48 PM
    Jnorris
    Jordan
    2005 Toyota Tacoma
    Yes ball joints were new when bought from the dealer.
  8. May 4, 2019 at 2:52 PM
    DrFunker
    I agree with Hobbs, I think if it is shaking the steering wheel, it more than likely, is something in the front end.
    Start with the least expensive first, imo. If they can re-balance them for nothing, go for it.
    Hobbs likes this.
  9. May 4, 2019 at 2:55 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    check the front struts for oil leaks or replacement
    Hobbs likes this.
  10. May 4, 2019 at 2:58 PM
    Hobbs
    Yep…
    Rotate your tires front-to-rear to see if the vibration changes. This eliminates tire/wheel issues (which should have been noticed at the alignment).
  11. May 4, 2019 at 3:02 PM
    Hobbs
    Yep…
    Do you ONLY feel it in the steering wheel?
  12. May 4, 2019 at 6:19 PM
    Lthompson
    Lthompson Well-Known Member
    Are the wheels stock? if not, are they hub centric? They need to be. if your steering wheel is shaking back and forth.. Rebalance the tires, Get them road forced balanced, with the proper adapter plate. Mine would never balance unless they use the adapter. I fought it and fought it. Finally got a good balance, after several different shops.
    smw62891 likes this.
  13. May 4, 2019 at 6:37 PM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    Starting with the basics:
    Is the steering wheel shimmying side to side or do you feel and up and down oscillation of the front tires?
    Have you checked the tie rod ends and steering rack for play? Known source of shimmy
    Do you have oversized or off road type tires, aftermarket wheels and /or wheel spacers?
    What brand of tires and are there tons of balance weights installed?
    Are you sure the wheels are not bent?
    Have you swapped the tires front to back and seen any difference?
    When I was a kid my father had a '66 Chevy Impala. That thing would shimmy like crazy around 35-40 mph, nothing below that and it would stop above that speed. It was a worn out center link, an old school steering part but similar concept.
    LuckyGinger likes this.
  14. May 4, 2019 at 6:43 PM
    Jnorris
    Jordan
    2005 Toyota Tacoma
    Noted and check and they are both good.
  15. May 4, 2019 at 6:45 PM
    BillsSR5
    bill
    2014 SR5
    wheel balance/alignment
  16. May 4, 2019 at 6:46 PM
    Jnorris
    Jordan
    2005 Toyota Tacoma
    I had them rebalanced, left tire was 1/4” ounce off and the right was 1 ounce off. But, still did not fix it.
  17. May 4, 2019 at 6:47 PM
    Jnorris
    Jordan
    2005 Toyota Tacoma
    Both of them were done. Just redid the balance and still didn’t help.
  18. May 4, 2019 at 6:49 PM
    BillsSR5
    bill
    2014 SR5
    steering rack bushings/loose bolts
  19. May 4, 2019 at 10:40 PM
    Lthompson
    I had mine "balanced" many many times. at several different shops. and they were always off, even just a couple days later they would be off. It wasn't til I made sure they were road forced with the proper adapter for Toyota wheels that it fixed it. Went to a shop, they were "supposed" to do all that, then when they were done, the guy told me that he told the guy to do it, but then someone else ended up doing the balance, and didn't do it.. So, he said we can redo them now, or you can try it. I tried it, still shook. Went right back. road forced and used the adapter, and all has been well since.. Starting to get just a slight shake again after several months. also If they are aftermarket, they need to be hubcentric.
    LuckyGinger and lowtidejoe like this.
  20. May 4, 2019 at 10:42 PM
    lowtidejoe
    lowtidejoe Well-Known Member
    Joe
    2008 Tacoma TRD Sport
    This
