Steering sway at highway speed bumps.
Discussion in '1st Gen. Tacomas (1995-2004)' started by taco_blanco2005, Jun 4, 2019.
  1. Jun 4, 2019 at 4:01 AM
    taco_blanco2005
    taco_blanco2005 [OP] Well-Known Member
    NE Florida
    ‘02 Tacoma PreRunner V6 DC
    Driving at highway speeds and hitting bumps such as the beginning/end ramps of small bridges, my truck wants to sway me off the road. Nothing two on hands on the wheel can’t counter, but definitely want to fix.
    Is this a sign of needing new coils/shocks?
    I’m currently sitting on the stock setup (2002 107k miles).
    GQ7227 likes this.
  2. Jun 4, 2019 at 2:25 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    could be slop in the steering shaft, or your shocks are bad. Quick way to check shocks is to push down on the tailgate and let go, does the bed bounce up and down a lot? It should immediately settle in it's original position. If it acts more like a pogo stick, your shocks are toast.
    GQ7227 likes this.
  3. Jun 4, 2019 at 4:14 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Check your tire pressure. When I first picked my truck up from the dealership, on the 100 mile freeway drive home I thought I was going to lose control every time I hit a bump in the road. When I got home I realized they had my tires filled up to ~50 psi, which was wayyy too high. Let them down to about 32psi and it was a world of difference.
    jammer and GQ7227 like this.
  4. Jun 4, 2019 at 9:23 PM
    DPTacomaGuy
    DPTacomaGuy Well-Known Member
    David
    2001 Tacoma 4x4
    Front end alignment? Toe-in will definitely affect drivability. How’s your tire wear? Condition of power steering fluid?
  5. Jun 4, 2019 at 9:27 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Alignment caster/camber issues , you probably don't have enough camber which is causing bump steer
  6. Jun 5, 2019 at 10:48 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Check your tie rods.
    Lift the front of the truck up off the ground and grab one of the wheels at 9 and 3 o'clock and do a push and pull to check for movement. Any movement will indicate something is out of whack.
  7. Jun 5, 2019 at 11:05 AM
    tony2018
    tony2018 Well-Known Member
    Take a look at the steering rack bushings, while under there have someone turn the wheel all the way left or right and see how it moves.
  8. Jun 5, 2019 at 4:19 PM
    Indy
    Indy Master of all I survey.
    Ball joints and alignment check.
  9. Jun 6, 2019 at 6:43 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Look to see if one of your sway bar links is broken. Happened to me 3 times and I had a side-to-side combined with a front-rear rocking motion whenever I drove over any kind of dip on the interstates. Until I replaced the link. (IMHO whoever designed those flimsy links didn't realized the force placed on those links when off-roading.)
    Also, if the sway bar link bushings are all dried up and cracked, you should replace them with the Toyota part. And be sure to torque them ALL THE WAY DOWN to the factory spec.
