Steering rack rotational slop
Discussion in '1st Gen. Tacomas (1995-2004)' started by tomtraubertsblues, Sep 1, 2023.
  1. Sep 1, 2023 at 4:29 PM
    tomtraubertsblues
    tomtraubertsblues [OP] Well-Known Member
    Northern Arizona
    I have been having some very bad, intermittent front end shuddering lately. In chasing this down I have replaced front pads and rotors and rebuilt the calipers. I have also replaced the outer tie rod end on the passenger side and I am currently working on replacing the inner tie rod end on the driver side. In doing, so that’s when I noticed, I have significant rotational slop in the driveshaft. I am currently attempting to upload a short video, but I have very poor Internet, and it is taking forever. I instead will upload two pictures. The difference between the two is pretty subtle in the pics (but not in real life), but noticeable after applying clockwise rotation to the inner tie rod end.
    Is this much normal? Or is that impossible to tell with just these pictures. As soon as the video gets uploaded, if it does, I will post that.
    Edit: Deleted pics as the video uploaded quicker than I expected.
  2. Sep 1, 2023 at 4:30 PM
    tomtraubertsblues
    Northern Arizona
  3. Sep 1, 2023 at 4:46 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Ha Ha with my internet it would abort a few times if I ever got it down load at all.
    Just how much left to right play do you have.
    With the tires on the ground?
  4. Sep 1, 2023 at 4:50 PM
    tomtraubertsblues
    Northern Arizona
    I get that, I think there is a competition between phone data and the Internet I pay for as to which is worse. When one is bad I switch to the other and vice a versa, neither of which are very good.
  5. Sep 1, 2023 at 4:53 PM
    Bivouac
    I edited my post look again
  6. Sep 1, 2023 at 4:59 PM
    tomtraubertsblues
    Northern Arizona
    Well it is too late for me to go back to check but what I remember was a bout an inch or two, maybe. I had replaced most of the front end components about four years ago.
  7. Sep 1, 2023 at 5:22 PM
    tomtraubertsblues
    Northern Arizona
  8. Sep 1, 2023 at 5:34 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Subbed as my rack has similar play, though not as much and it’s a 2nd gen.
    See if tightening the guide helps with this looseness and dead zone of about 15° in the steering wheel.
  9. Sep 1, 2023 at 7:24 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  10. Sep 2, 2023 at 6:39 AM
    tomtraubertsblues
    Northern Arizona
    Has anyone had any luck with tightening the nut on the back of the rack to snug it up?
  11. Sep 2, 2023 at 1:01 PM
    O'Silver_Taco
    MD
    Yeah that would be first thing I'd try....
    I would take off the inner tie rods on both sides....
    and have someone turn the wheel and see if the roller is shot...
    you might even pull that roller out and inspect.......timmy videos....
    what have you got to lose....
    If its not leaking fluid ......I think you got a good chance.....
    take it to a mechanic.....and he may lie to you......or just flat be an idiot...
  12. Sep 2, 2023 at 1:02 PM
    O'Silver_Taco
    MD
    I've never seen one that loose.....So I can hardly wait for the out come...
  13. Sep 4, 2023 at 7:23 AM
    tomtraubertsblues
    Northern Arizona
    I had to replace this rack and Pinion a few years back and it is still under warranty so I will just be replacing the whole thing. I looked at the parts for replacing the guide and it looks like it would be about 100 bucks. If it was half the cost I would probably just do that.
  14. Sep 4, 2023 at 3:11 PM
    O'Silver_Taco
    MD
  15. Sep 4, 2023 at 4:03 PM
    tomtraubertsblues
    Northern Arizona
    Yup, 100 bucks. I'd rather replace the whole rack and inner tie rod ends for no more money than update for 100-although it would be a lot easier.
  16. Sep 5, 2023 at 3:57 PM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
  17. Sep 6, 2023 at 9:04 AM
    tomtraubertsblues
    Northern Arizona
    Yeah, but I would need more than just that one part- the 2001+ rack guide, the 2001+ cap, apparently the spring can be reused at least.
    So I can do that or get a new (reman) rack for “free” and replace that again. I’m leaning toward the latter.
  18. Sep 6, 2023 at 9:40 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    yes, but this is significantly more play than I had.
  19. Sep 6, 2023 at 1:34 PM
    O'Silver_Taco
    MD
    Yeah i think there is something wrong or missing in there...
    you really wont know until you dig in there....
    my guess is if its not leaking....its worth saving....
