Steering rack replace
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EastVanTaco, Sep 29, 2022.
  1. Sep 29, 2022 at 12:39 PM
    EastVanTaco
    EastVanTaco [OP] Well-Known Member
    2017 super white Trd Sport DCLB
    So I just dropped my truck off for a "service 2"
    I am in Canada and have 62000 kms on my 17.
    They called to tell me my steering rack is leaking. Cost to replace is around 2k.
    Wtf why would this happen so early? Options instead of 2k?
    Thanks
  2. Sep 29, 2022 at 2:47 PM
    mangler
    mangler Well-Known Member
    Saskatchewan, Canada
    2016 TRD sport DCSB MT white
    I was told the same thing 15 months ago truck was at roughly 90k km , leaking steering rack, never any signs of leaks on my driveway, quoted $3k to replace , talked to a mechanic at an independent shop, he suggested throwing in some stop leak and monitoring it . Fluid level hasn't changed since, and I never did notice it being low to begin with.
    I also went to look at a 2018 a month ago that was used with only 40 k km on it , and it was in the shop getting a new rack installed . Not sure if this is a known issue with certain model years ?
  3. Sep 29, 2022 at 2:51 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I've heard it from a number of 2nd Gens also.
    whatstcp[QUOTED] likes this.
  4. Sep 29, 2022 at 2:54 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Look at the tierod end boots. Are they wet on the bottom? If so, the rack end seals might be weeping or leaking. I had that and needed to add a little bit of fluid. I had some fluid for our Mazda PS, which like the Taco, is Dexron III compatible. That little bit seems to have conditioned the seals and life has been great since. Like, 40,000mi or more. My need boots are dry since.
    https://www.amazon.com/gp/product/B00GKGCP5G
    shotgunbilly420 likes this.
  5. Sep 29, 2022 at 3:26 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I flushed mine and added this back in. I need to redo it and use the rest of the quart.
    tonered[QUOTED] likes this.
  6. Sep 29, 2022 at 5:16 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Awesome!
    Save the rest for top up. The first time, it was only the difference between the two lines. I was surprised.
    Skydvrr[QUOTED] likes this.
  7. Sep 29, 2022 at 5:19 PM
    Bishop84
    Bishop84 Well-Known Member
    Very common on Tacomas. One of the few weak points.
    Pain in the ass to change. I only recommend them if it’s leaking actively.
    I’d estimate 50% of all Tacomas 2nd and 3rd gens have oil in the rack boots after 100k
    I’ve changed them as early as 10k
  8. Sep 29, 2022 at 7:07 PM
    EastVanTaco
    They said it is an interal leak. So the part just failed semi prematurely. So now I'm wondering how they found? Or assumed a leak...
    They did say the fluid was low then a bunch of non str8 answers it seemed. I asked if it was topped up. O I assume so not sure...
  9. Sep 29, 2022 at 7:08 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Definitely get a second opinion. Internal leak? Very suspect.
    What do you see? The dealer is not pulling things apart to evaluate.
