Steering rack needs to be replaced after 50K miles - 2019 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FranklinsDad, Dec 19, 2023.
  1. Dec 19, 2023 at 6:23 AM
    FranklinsDad
    FranklinsDad [OP] Member
    2019 Tacoma SR5
    Roof Racks - Emblem blackouts - TOYOTA emblems- inserts on the tail gate.
    Hello,
    I just brought my 2019 Tacoma (V6 4WD) in for it's state inspection. I was shocked to learn my steering rack needed to be replaced as the stearing fluid was leaking out. I'm retired and mostley drive around locally. I baby the truck, no off road or agressive driving. Has anyone else experienced this kind of failure with only 50K miles on a Tacoma? Thankfully I purchased an extended warranty when I got the truck which just saved me close to $2,300.00.
    AmateurTaco1313 likes this.
  2. Dec 19, 2023 at 6:26 AM
    TacomaAddict23
    TacomaAddict23 There's no cure for dumb
    2023 Lunar Rock DCSB
    Ditch Lights 4wp Sliders Bed side molle panels Taco garage DMM mount More to come
    Huh thats weird. My 2009 never had a steering rack problem and it had around 200k on it when I sold it. And ya good thing you have the warranty. Just watch those dealers! They like taking all your $$$
  3. Dec 19, 2023 at 6:28 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Maybe the seals dry rotted
  4. Dec 19, 2023 at 6:35 AM
    Bishop84
    Bishop84 Well-Known Member
    Very common on Toyota trucks, I've replaced them first year. It's one of the weak points of tacoma. It's covered so no biggie.
  5. Dec 19, 2023 at 6:59 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Very common. All 4 of my buddies Tacomas (17-19), including mine, have weeping leaks from the rack. boots are wet.
  6. Dec 19, 2023 at 7:02 AM
    TacomaAddict23
    Well I need to drive mine hard so I can get it replaced before the warranty is up lol
  7. Dec 19, 2023 at 7:10 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Is that after subtracting the cost of the extended warranty?
  8. Dec 19, 2023 at 7:15 AM
    Hpen123
    Hpen123 Active Member
    Harry Pence
    21' TRD OR Tacoma
    Wheels/ 275/70 R 17 AT's, OME Suspension, CBI front bumper, RCI Skids/sliders, prinsu rack.
    Anyone know if they beefed them up on the new Tacoma? Mine isn't yet having trouble, but a friend I wheel with has a 4runner and his went pretty quickly.
    Canadian Caber likes this.
  9. Dec 19, 2023 at 8:44 AM
    rascott95
    rascott95 Well-Known Member
    Dallas, TX
    2019 DCSB TRD Off Road
    I recently had to replace the rack on my 2019 as well but I figured it was from off-roading the truck. It sounds like it may be predisposed to failure anyway. I also have an extended warranty that saved my butt on this one.
    TacomaAddict23 and Greg-tacoma like this.
  10. Dec 19, 2023 at 11:38 AM
    AZ_Tumbleweed
    AZ_Tumbleweed Well-Known Member
    Wilmington, NC
    2020 TRD OR DCSB Cement 4x4 AT
    Do you typically see oil leaking/puddles from it when it’s leaking? Just noticed this on my 2020 but haven’t noticed any actual leaks anywhere. Passenger side is fine. Wondering if I should be concerned. 45k miles on it
  11. Dec 19, 2023 at 11:46 AM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    keep an eye on the power steering reservoir level, if it doesn't change I wouldn't worry about it. Both sides of mine has looked about like that for years, and hasn't gotten worse.
  12. Dec 19, 2023 at 3:03 PM
    Technique
    Alex
    Utah
    Same here.
  13. Dec 19, 2023 at 6:29 PM
    The Mink
    The Mink Well-Known Member
    Happyrock, Oregon
    2017 OR AC
    Just had my rack replaced in August with 40,000 miles on the clock (extended warranty covered it). Drivers side started weeping then the passenger side started a few months later. I cleaned everything and monitored but it came back pretty quickly and my fluid level started dropping slowly. Since you paid for the warranty, I’d use it. No issues since the repair and took it on a 1000 mile trip in September to do some wheeling :thumbsup: IMG_0885.jpgIMG_0884.jpg
  14. Dec 19, 2023 at 8:36 PM
    TacoTuesday1
    FL
    you saw with your eyes your rack is leaking?
    or heard some guy say some words
    mine has a slow leak
    Older year more miles
    I put some StopLeak and it’s fine.
    if I ever take it out it’ll either be to slap in a cheap replacement or hopefully better, upgrade.
  15. Oct 24, 2024 at 5:41 PM
    Van_island
    Van_island Well-Known Member
    Isaac
    2019 taco
    Had the same thing on my 2019 trd sport. Dealers said I needed a new one. Only cost me 2700$. They said that they have been seeing lots of the steering racks leaking on the 2017 -2019 my truck has 113,000km. Next time I will just keep an eye on the fluid levels and top it up.
  16. Apr 7, 2025 at 5:35 PM
    Cinderblocko69
    Cinderblocko69 New Member
    Riley
    Cement gray 2019 tacoma
    I just had the same on my tacoma 2019 only 80 000 km i just don't understand how companies get away with seeing the same thing with soo many trucks and not covering it. Unfortunately did not get the extended warranty .....
  17. Apr 7, 2025 at 7:37 PM
    Mikeybuck
    Mikeybuck Well-Known Member
    SW WA
    2018, 2010, Tacoma
    Mine started leaking (weep) around 120k. I'll just add some more fluid till it becomes more of a weep then I'll replace.
  18. Apr 7, 2025 at 8:32 PM
    ST1
    ST1 New Member
    East Tennessee
    17 Tacoma Limited Metallica Grey
    My 2017 is at 119K and it started leaking recently as well. It must be a small leak because the fluid level has remained OK, so I'm just going to keep an eye on it for now.
  19. Apr 7, 2025 at 11:54 PM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    I have so much Fluid Film on my truck, it'll be impossible to spot a steering rack leak. I'll just add power steering fluid as needed, if it ever happens.
    akimmel, Irons, doublethebass and 2 others like this.
  20. Apr 8, 2025 at 8:24 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Mine started to leak around 30k (out of warranty though). I drained the old fluid from the reservoir and refilled with the mazda fluid (0000-77-112E-01). From the posts I have found on here, its the same specs as toyota, but is better on the seals.
    I put it in, and now at nearly 60k miles I have not had the level drop at all. No seeps, leaks, or drips.
    Canadian Caber and Darkice like this.
