Steering pop at low speeds
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drewbert41, Dec 16, 2018.
  1. Dec 16, 2018 at 5:49 PM
    drewbert41
    drewbert41 [OP] Well-Known Member
    Champaign, IL
    21 Cement DCSB 4x4 TRD OR
    Started hearing a loud pop when wheel was cranked all the way left. Now it is popping in either direction at really low speeds like in parking lots. Saw a thread about it before but I can't find it.
  2. Dec 16, 2018 at 5:59 PM
    HillJackJDS
    HillJackJDS Well-Known Member
    Dale
    2008 Tacoma 4WD
    Eapecially slow or stopped pops should be easy to find. One person stears while another is at ground level looking for the pop. Look at spindle/steering stops
  3. Dec 16, 2018 at 6:25 PM
    drewbert41
    Champaign, IL
    I feel like I remember someone saying something about greasing the steering stop.
  4. Dec 16, 2018 at 7:56 PM
    jproffer
    jproffer Well-Known Member
    Jim
    Perryville, MO
    '15 MGM Sport DCLB, V6
    I'm sure you already thought of this but on that 1% chance I'll ask anyway.... :) ........
    It's not in 4WD is it?
  5. Dec 16, 2018 at 7:58 PM
    Texas Aggie
    Texas Aggie Well-Known Member
    Michael
    TEXAS
    2013 SR5 4x4 Lifted
    King 2.5's Front and Rear 700# coil, 2" wheelers aal, 315/75R16 BFG KM3's Pelfreybilt Front and Rear Steel Bumpers, All Pro Sliders, 4.56 Gears
    How’s the ball joint looking in your lower control arm?
    HillJackJDS likes this.
  6. Dec 16, 2018 at 8:02 PM
    drewbert41
    Champaign, IL
    not in 4wd
    jproffer likes this.
  7. Dec 16, 2018 at 8:14 PM
    ellocodetroit
    ellocodetroit Well-Known Member
    Louie
    Alhambra, So Cal
    2008 PreRunner DCLB Eaton Truetrac 4.11
    Bilstein 6112/5160, Icon RXT Stage 3, Cooper ST Maxx, MF-1050 OBA. 348,000 Miles. Coupe battery tie down, Homertaco Grille, Weathertech Floorliners, Front shocks @1.94", ARE camper shell, TRD skid plate.
    I had the same popping sound when turning left onto driveways. It went away when I replaced the front sway bar links, outer tie rods, and lower control arms.
  8. Dec 17, 2018 at 11:40 AM
    drewbert41
    Champaign, IL
    Damn, that's a lot. Mine will be taken care of a no charge since I left the dealer and noticed it and they are my friends. However, I would like to know what it is and if it is safe for now. Only happens at low speeds so seems safe? The popping noise is loud and scares the crap out of me sometimes. Especially while backing. A few times I have thought I backed into someone.
  9. Dec 17, 2018 at 11:44 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    mine pop crackles and snaps.... but I already know its the lower ball joint only does it while turning, low speeds or a hit a fat pot hole
  10. Dec 17, 2018 at 11:59 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Had this happen once on an 80s 4 banger Toyota truck - 2WD - control arm bushings. Will require investigation.
  11. Dec 17, 2018 at 6:45 PM
    drewbert41
    Champaign, IL
    I remember something about a loose lca after an alignment on here too. Not going to be able to get back to the dealer until after the holidays. Wonder if I should get it on a lift somewhere or not worry about it.
  12. Dec 17, 2018 at 6:48 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Some say loose LCA bolts, some say bushings. I’m convinced it’s the bushings. Mine aren’t seized by any means but I’ve had the reverse/full Steering wheel lock pop since like 70k miles. My LCA bolts are torqued appropriately.
    Edit: some threads you’ll see say it’s the brake clunk of the pads setting in place, but it’s definitely not that. I have caliper click/clacking and it’s not near the same as the clunk/popping the LCAs make.
  13. Dec 17, 2018 at 6:54 PM
    drewbert41
    Champaign, IL
    How many miles u have now?
  14. Dec 17, 2018 at 6:56 PM
    JdevTac
    Josh
    GA/WA
    2nd gen
    ~97k. Still clunking on my way out of the garage in the morning. Sometimes they actually shut up though.
  15. Dec 17, 2018 at 7:01 PM
    007fodo
    007fodo Gold Member
    Ian
    Coastal North Central CA
    4X4 V6 5AT DCSB 07
    I recently developed the same clunk, it sounds like its somewhere around my driver’s side LCA when turning left at almost full-lock. No sway bar. I am in the process of replacing my outer tie rod ends and lower balljoints so I will post if the clunk goes away when I’m done.
    Unfortunately, today I had a major mishap and installed my passenger LBJ upside-down; but I’ll save the info on that for a thread I’m gonna start ASAP.
  16. Jan 18, 2019 at 1:35 PM
    drewbert41
    Champaign, IL
    FYI- Dealer came and got my truck today. Says it needs a new steering rack.
  17. Jan 18, 2019 at 3:11 PM
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Lower ball joint
  18. Jan 18, 2019 at 3:15 PM
    1rooster
    1rooster TACOMA31750
    Georgia
    2007 Tundra crewmax
    5100's ALL WAY AROUND, 885X COILS, DRIVER SIDE LEAN SPACER, ICON PROGRESSIVE AAL W/O OVERLOAD, 265/75/16 KENDA KLEVER M/T. 1 1/4 SPIDERTRAC WHEEL SPACERS, GEN 1 TRD COLD AIR INTAKE, STOCK MUFFLER WITH CHOPPED TURNDOWN, 5% TINT OVER FACTORY, DEBADGED, TOYOTA RUBBER BED MAT, WEATHERTECH MATS,UWS TOOLBOX, UNDERCOVER SE, LOCKER MOD, REAR BUMPER, PIONEER DOUBLE DIN WITH PARKING BREAK OVER RIDE, CUSTOM OIL CATCH CAN, FULL LED INTERIOR, ARB BUMPER REPLACEMENT. COVERKING SEAT COVERS. MORIMOTO H1 MINI COVERSION WITH MINI GATLIN GUN SHROUDS AND 5000K MORIMOTO BULBS. TRAILER PLUG RELOCTED TO BUMPER. 20 INCH LED LIGHTBAR MOUNTED BEHIND CUSTOM PAINTED GRILL. STUBBY ATNENNA
    Mine ended up being my lower control arm bushing. I tack welded them in and has been pop free for some 30k miles
    Marc70 likes this.
  19. Jan 18, 2019 at 3:29 PM
    007fodo
    007fodo Gold Member
    Ian
    4X4 V6 5AT DCSB 07
    My popping / clunk went away after I replaced outer tie-rod ends, LBJs and aftermarket UCAs (including UBJs and UCA bushings)
  20. Jan 18, 2019 at 3:47 PM
    devkurf
    devkurf Member at Large
    midwest
