Steering knuckle grease?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vasqu3zk, Jan 14, 2018.
  1. Jan 14, 2018 at 12:14 PM
    Vasqu3zk
    Vasqu3zk [OP] Well-Known Member
    Kyle
    Bullhead City ARIZONA
    2006 Tacoma pre runner
    MCM fab UCA, ADS 2.5 extended coils front pushing 3”, fox2.0 rear.
    Hey guys looking for some help. Recently my truck makes a whining noise. It’s not from the pump but from the rack area it seams. It’s more at a low speed turns and doesn’t get louder when I hit the gas or anything like that. From what I’ve been reading people say to grease the steering knuckle. I have a prerunner 06. My question is what exactly am I greasing and where on it? Not sure of what a steering knuckle is. If anyone has pictures or can explain I would much appreciate it!
  2. Jan 14, 2018 at 12:17 PM
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
  3. Jan 14, 2018 at 12:17 PM
    Vasqu3zk
    Kyle
    I guess another question I have is how to know when a rack is going out? My steering feels snug no hard spots even when the noise present...
  4. Jan 14, 2018 at 12:18 PM
    Vasqu3zk
    Kyle
    So the spindle needs the grease then?
  5. Jan 14, 2018 at 12:19 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The only thing I could think of is the intermediate steering shaft. If you crank your wheel all the way right, you can access this little flap thing (one on the right) with your tire still on.
    Then grab some PB blaster and spray it on this U joint leading into the steering rack.
    I don't think that's your problem though. Generally you spray that if you have hard spots in your steering.
  6. Jan 14, 2018 at 12:19 PM
    Truggin
    Don
  7. Jan 14, 2018 at 12:21 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Good video, but ours aren't greaseable.
  8. Jan 14, 2018 at 12:21 PM
    Vasqu3zk
    Kyle
    Okay your lower picture is where I’m feeling the most vibration coming from and noise that I can isolate it down too... I’ll try that. The tie rods on the truck seems fine play wise and they are fairly new
    EatSleepTacos[QUOTED] likes this.
  9. Jan 14, 2018 at 12:21 PM
    Vasqu3zk
    Kyle
    Seen this but don’t have fittings on mine. Just replaced not to long ago
  10. Jan 14, 2018 at 12:22 PM
    Vasqu3zk
    Kyle
    W-40 same as pb?
  11. Jan 14, 2018 at 12:23 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Eh, not quite. I'd use PB or liquid wrench or something of the sort but if you don't have any, then just try WD-40.
  12. Jan 14, 2018 at 12:23 PM
    Vasqu3zk
    Kyle
    I’ll run down to the store and get some
  13. Jan 14, 2018 at 12:24 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It's good to have on hand anyways. I use it all the time when working on trucks.
    Vasqu3zk[QUOTED][OP] likes this.
  14. Jan 14, 2018 at 12:24 PM
    Vasqu3zk
    Kyle
    Hopefully that fixes it.
  15. Jan 14, 2018 at 12:25 PM
    Vasqu3zk
    Kyle
    Do racks whine when they are going out?
  16. Jan 14, 2018 at 1:06 PM
    BigBiscuit
    BigBiscuit Well-Known Member
    Mass.
    2010 TRD Sport DCSB MGM
    WD-40 is NOT A LUBRICANT. It actually removes grease and oils. It's good to clean things out and temporarily lube, but it really should be cleaned out and then add a good lubricant. I use Seafoam Deep Creep. It works exceptionally well. I sprayed my steering joint when it felt like it was binding up and it worked really well right away.
  17. Jan 15, 2018 at 8:30 AM
    Vasqu3zk
    Kyle
    It worked guys!!! Used pb on it and no more noise!!! Thanks for help guys!!!!
    EatSleepTacos likes this.
  18. Jan 15, 2018 at 8:31 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Cheap and easy are the best kinds of fixes!
  19. Jan 15, 2018 at 12:28 PM
    Vasqu3zk
    Kyle
    It came back :annoyed:
  20. Jan 15, 2018 at 12:42 PM
    Jeffs68
    Jeffs68 Well-Known Member
    2015 PreRunner TRD Sport DC
    Stock
    Racks don't whine, and neither do knuckles...P/S pumps whine and can telegraph noises making it hard to pinpoint sometimes, a technicians stethoscope or a broom handle can be used to pinpoint your "whine". (or at least get you close)
    According to your post time stamps, the fix lasted less than 5 hours?
    Could be anything, idler or tensioner pulley. When you turn the wheel it loads up the other accessories, A/C pump, alternator etc...you get the idea.
    Could also be engine internal...checked the oil lately?
