Steering Intermediate Shaft Replacement.....??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crow Horse, Mar 13, 2021.
  1. Mar 13, 2021 at 3:59 PM
    Crow Horse
    Crow Horse [OP] Well-Known Member
    Central NY
    2012 DCSB TRDOR
    The steering on my 2012 has become a little difficult and "notchy" (is that a word?) where it feels like it binds up a bit the releases. I believe it's the intermediate shaft. I sprayed it down with a penetrant and it seems to turn easier.
    I've found OEM shafts for around $170 and some unbranded ones for $30+ on Ebay. The cheap one's I'm very skeptical of, being that this is a vital component. I'm leaning towards getting the OEM replacement just for peace of mind. At $170, it's still a lot cheaper than brain surgery or a mortician.
    Unless someone can convince me otherwise I'm going to go with the Toyota shaft.
    Any tips on the actual replacement? I'm leaning to have a shop do the work.....
  2. Mar 13, 2021 at 5:02 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    It’s not difficult to replace. You might have to work at it to separate the joint. The one key thing to remember is not to let the steering wheel spin so that you don’t end up damaging the clock spring. The steering lock should hold it if you have the keys out of the ignition. Other option is to tie off the wheel.
    blu92in99 likes this.
  3. Mar 13, 2021 at 5:50 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    If you want my 2 cents, go OEM. The aftermarket shafts I've seen look really, really scary. And it's only your steering we're talking about. I wouldn't chance it.
    As for the job itself, as has already been said, the biggest pain is separating the old shaft at the splined coupler. Soak it with penetrating oil for a few days prior and you should be fine. And yes, do tie off the steering wheel. After you install it, I'd recommend coating it with marine (corrosion inhibiting) grease or Fluid Film to prevent future corrosion.
    vssman likes this.
  4. Mar 13, 2021 at 6:23 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    Yea, that's my feeling. Some of the aftermarket ones look a little sketchy.
    I came across this boot to protect the U-joint....
  5. Mar 14, 2021 at 3:36 AM
    Too Stroked
    Tom
    I've seen those, and I only have one concern. If water does get in - and it will - it will get trapped in there and actually cause more corrosion.
  6. Mar 14, 2021 at 5:57 AM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    If packed with waterproof grease I think it would be no different than what cv axles experience regarding exposure to the elements.
  7. Mar 14, 2021 at 6:31 AM
    Too Stroked
    Tom
    Properly packed and sealed - agreed.
  8. Mar 14, 2021 at 6:43 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    If I have to replace mine, I’d probably “paint” it first with Amsoil HD metal protect. It dries to a waxy film and has protected my frame very nicely. Boot with grease wouldn’t hurt either but make sure there’s enough room for the slider to function properly.
  9. Mar 14, 2021 at 10:47 AM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    Slider? Are you referring to the booted section? Isn't that the section that is designed to collapse in the event of a collision to protect the driver?
  10. Mar 14, 2021 at 10:52 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I wouldn’t use the boot. I rebuilt my own steering shaft with a greasable u-joint from All Balls that cost like $20
    b_r_o likes this.
  11. Mar 14, 2021 at 11:46 AM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Yes, there is a collapsible slider in there. As long you have room when the slider is completely collapsed for a boot over the joint, you’re okay. What I’m trying to say is not to add anything that would get in the way of fully collapsing.
    Edit: 20ish years ago, I used to work at the Timken Steering Systems plant in Watertown, CT. Now called Global Drive Systems. We didn’t make Toyota product but many other makes. I oversaw intermediate shaft lines for Ram, F150, KJ, XJ, TJ. They also made columns for A class, GM, golf carts, etc...
    b_r_o and Crow Horse[QUOTED][OP] like this.
  12. Mar 14, 2021 at 12:03 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    Ok, so you're the one to ask because of your knowledge and experience. Honest question, in the event of the shaft collapsing as designed in an accident, wouldn't that force be able to overcome a tie rap or a small band clamp? Again, it's an honest question.....
  13. Mar 14, 2021 at 12:17 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    You’d think so but things can jam up the slider as it collapses. In an accident, it’s a very rapid almost instantaneous shock.
    Somewhere on here, there’s a thread on replacing the u-joints. Although they aren’t supposed to be replaceable, it can be done as long as the yokes gets staked again after the joint caps are pressed in. The only thing missing with replacing them is the preload that is placed on the yoke. We would slightly spread the yoke as the caps are pressed in and the stake the cap. Makes for a very smooth tight feel without any lash.
  14. Mar 14, 2021 at 1:25 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    How does the slider deal with a build up of corrosion over time and if it does build up, how does it overcome it?
  15. Mar 14, 2021 at 1:33 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    The units I used to make were either a Teflon coated spline that was also greased or an over molded double D shape (flats on both sides) with grease as well. They only need to pass a certain amount of time in a salt spray chamber. Never saw a failure at that time but they could be made to fail (not fully collapse) given a longer time in the salt humidity.
  16. Mar 14, 2021 at 1:41 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    Interesting..... Please weigh in on this.....
    If one were to successfully replace the u-joint and leave the slider intact maybe doubling or significantly extending the service life of the shaft, the slider would have been exposed (to a certain degree) to corrosives and possibly going beyond it's design parameters regarding corrosion resistance.
    Overthinking, I know......
  17. Mar 14, 2021 at 1:50 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    I would hope that if someone was going to go thrall off the trouble to replace the u-joints, the shaft itself would be in decent condition. Honestly, if I had to replace mine, I’d review what’s available in the aftermarket world and treat it before installing. Something from a commercial auto parts store like Napa or even RockAuto not like Auto Zone.
  18. Mar 14, 2021 at 2:45 PM
    Eze1139
    Eze1139 Well-Known Member
    Eric
    Reno NV
    2020 Cement TRD OR DCLB
    Not the worst project on my 08 that I did almost 2 years ago. Couple hours in the garage total-most of the time spent trying to make room to get it to wobble its way out. Installing the new one was a breeze. Maybe 20 min tops including torqueing to spec etc and cleaning everything up. I also thought about adding my own sort of rubber sleeve/filling it with grease and zip tying it together but didn't worry enough. It made it 134k miles the first time.
    I mostly followed this advice and it was super helpful-https://www.tacomaworld.com/threads/lazy-mans-guide-to-the-replacing-the-intermediate-shaft.671990/
    My own tips below.
    • PB blast everything like it's going out of style a couple days/multiple times before you tear into it. It helps a ton. Some hammer action to rattle stuff loose helps & feels good too. This tip is advisable on every single Tacoma project-especially if your truck lives back east with the salt (mine was in SW PA for 8 years)
    • Park your truck at whatever angle you need to access the bolts. I am pretty sure I left mine nearly straight. Once you have it set-park it, lock the steering wheel (key out) and lock the door. I didn't do anything else special to keep the steering wheel from moving-note the blue rope in the picture below-bought specific for this project and didn't use.
    • Mark the connection points top & bottom (little white/yellow paint pen mark). Give's you reference for if you move the steering wheel and kept me from worrying that stuff was moving on me.
    [​IMG][​IMG]
    • Before you button everything up make sure the alignment is correct and the bolts are torqued to spec. (26ft-lbf)
    • Don't fret if steering wheel and wheels aren't aligned when it is all finished. You just need to undo the bolts and adjust a notch or two. I didn't have this problem once I locked my steering wheel and mirrored the placement on the splines between the new and old.
    Solid project that will give instant satisfaction when it is done correctly. Good luck.
  19. Mar 14, 2021 at 6:01 PM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    Thanks guys! The shaft and bolts are ordered. Warm weather is currently out of stock and back ordered. I'm going to try booting the U-joint. Time will tell....
    vssman likes this.
  20. Mar 18, 2021 at 9:32 AM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    Another question..... If I lock and secure the steering wheel and keep the tire(s) on the ground, then marking won't be necessary? As long as the flat on the upper corresponds with the upper bolt?
