Steel Wheel Lug Nuts Same As Alloy?
Discussion in 'Wheels & Tires' started by MattRaymond, Sep 25, 2022.
  1. Sep 25, 2022 at 4:39 AM
    MattRaymond
    MattRaymond [OP] Member
    2020 TRD Sport Access Cab
    Hello All, I will be changing tires soon from my stock 265/65r-17’s to 255/75r-17’s. The spare tire/rim on my 2020 Sport is 16” (sigh) and I have a 5th 255/75r17 to use as a spare. I have found several inexpensive steel 17 inch rims that are compatible with Tacoma/FJ’s etc. My question is, If I get a flat at some point and need to use the spare, will my stock lug nuts designed for my stock Sport rims work with the steel wheels? Or do I need to use old school conical lug nuts for the steel wheels?
  2. Sep 25, 2022 at 5:17 AM
    Sonofliberty92
    Sonofliberty92 T O Y O T A
    Mark
    Maryland 4 South
    2014 DCSB TRD OR, 2005 Tundra V8 4WD
    I bought a set of OEM alloy wheels to replace my stock steel ones not too long ago. Haven't got around to having them installed yet. However, the set of alloys came with lug nuts and they appear to me to be the same exact nuts as what I already have. Can't speak to what you have but mine are identical.
  3. Sep 25, 2022 at 5:36 AM
    Bishop84
    Bishop84 Well-Known Member
    Alloy lugs are different they are shouldered with washers.
    Steel lugs are simply tapered.
    These are what you need.
  4. Sep 25, 2022 at 12:27 PM
    MattRaymond
    I guess the next time I rotate the tires I’ll see if my lug nuts are tapered. They might be because my 16” spare is a steel wheel. I might be over thinking this.
  5. Sep 25, 2022 at 12:40 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    The washered nuts pictured above still have a taper designed to work with steel spare wheels for temporary use. The owners manual even outlines this, or at least it used to.
  6. Sep 25, 2022 at 12:42 PM
    Big Red 2nd Gen
    Big Red 2nd Gen Well-Known Member
    Dan
    Red 2008 TRD Access Cab 6 Speed
    TRD Cold Air Intake, Fat Bob's Vated Bilstein fronts set at 3 inches, stock rear leafs with ICON progressive multi leaf "add a leaf", MBRP Stainless dual exhaust, Sport Hood with scoop, Pedal Commander, Pro Comp 16x8 wheels with 265/75R16 KO2's, toneau cover.
    As long as they are conical seats yes. If they are different, just throw 6 lug nuts that will work with the spare in the glove box or in with the jack and lug wrench for if you need to install the spare.
