Steel Wheel Center Caps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by warrior79, Nov 18, 2016.
  1. Nov 18, 2016 at 2:19 PM
    warrior79
    warrior79 [OP] Member
    baltimore
    ARE Cap
    I purchased a set of Tacoma silver painted steel wheels (6 lug) in order to save my aluminum rims from the winter on my 2012 Sport. The center caps that came with the rims had mangled clips and none of the 4 would stay attached. I just purchased 4 new caps online and the clips on these new caps will not hold either. There are 6 locations for clips but each cap only has 4 clips, similar to the first set of caps. The steel rims are from a 2nd gen.
    I am not new to aluminum or steel wheels or the caps, but this has got me baffled.
    Am I missing something here? Seems to me they should snap on tight, but the clips don't even extend past the edge of the center hole.
    Any advice is appreciated.
  2. Nov 18, 2016 at 2:22 PM
    Pigpen
    Northwest Montana
    Mine have all had 4 clips. Once I pushed them on, I would kick them a few times to make sure they were seated. I don't bother to run center caps any more though.
  3. Nov 18, 2016 at 2:23 PM
    Pigpen
    Northwest Montana
    I've had 3 sets of center caps and 5 sets of stock steel wheels.
  4. Nov 18, 2016 at 2:47 PM
    warrior79
    baltimore
    ARE Cap
    58 Siesta,
    Thanks for the reply. These clips do not even come close to holding the rim. In fact with the rim laying flat the caps has side to side movement. On one cap, I bent the clips outward, but it still did not hold the rim. Maybe there are different versions of the wheels or caps. I am at a loss.
  5. Nov 18, 2016 at 5:20 PM
    Pigpen
    Northwest Montana
    not sure. Sorry I can't be of more help. I just painted the center of the hub to match my rims and got rid of the caps.
  6. Nov 18, 2016 at 5:25 PM
    warrior79
    baltimore
    ARE Cap
    Well I have run them without caps the last 2 winters, just wanted to dress it up a bit. Guess I will continue to run them without caps.
    Thanks
  7. Nov 19, 2016 at 12:18 PM
    warrior79
    baltimore
    ARE Cap
    I figured out the problem. The caps are held in place by the wheel hub (hub centric). With the wheel off the vehicle the cap fits so loosely that it falls off when the wheel is turned upright. The cap must be held in place when mounting the rim to the truck, but once the lug nuts are installed the cap is very tight.
    I thought the cap would fit tightly with the wheels off the truck like the aluminum sport rims. I thought wrong. All good now.
